FixYa.com
Tags:
Washing Machines
Generic problem for all Washing Machines
Washing machine won't spin (by 2 users)
posted by sissy3 on Dec 12, 2007
My washing machine won't spin
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by golfteacher, posted on Feb 08, 2008
Can hear pump draining water.....pump continues to run, but drum does not spin.
Solution #1
posted on Dec 12, 2007
Not Rated (0)
mikemilw
Rank:Wiz Wiz
Rating: 83%, 192 votes
From http://www.diyfaq.org.uk/electrical/washing_machine_faq.htm
Why won't my washer spin? There are several reasons for this fault. First a washer will not spin if there is water in the tub. If this is the case, then check “Why won't my washer empty?”. Even though the washer might have emptied the water, the machine might be misled into 'thinking' there is still water left in the machine due to a blocked pressure barrel (see “My washer is leaking, why?”). If the belt has become detached or loose, the drum will not spin, nor will it spin if you have a faulty motor, module or timer. Usually a motor will have carbon brushes which slowly wear away. There needs to be enough material left to touch the commutator and have enough spring left in them to make sure there is a good contact. If the brushes in the motor are OK then you need to check the circuit across the terminals on the motor, because there is a thermal overload switch inside which may have tripped. Should the motor be OK, or be the type that doesn't have brushes (induction), then the chances are you need to test the speed control module. This is a circuit board that directly controls the speed of the motor. It may be found on or near the timer, or sometimes at the base of the machine, and usually requires specialist equipment to determine its worthiness.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: GE Energy Star WCVH6260F Front Load Washer GE WHRE5260E Top Load Washer Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Bosch Logixx WFT 2806 Front Load All-in-One Washer / Dryer Bosch Classixx WVF 2402 Front Load All-in-One Washer / Dryer Bosch Axxis+ WFR 2460 Front Load Washer Haier HLF11P Washer&Dryer, Top Load, 6 cft Capacity, Fuzzy Logic Electronic, Hamper Door Design
Can you Help with these Washing Machines problems?
Washing Machines
fluff left inside the door...
After a dying cycle a lot of... Answer This...
Washing Machines
Washing machine Hoover AM120...
whatever program I use, machine... Answer This...
Washing Machines
Zanussi Progress 1200 isn't...
Zanussi Progress 1200 isn't... Answer This...
Washing Machines
PROBLEM FOR LG MOD.WD-10150FB...
problem for lg mod.wd-10150fb... Answer This...
Washing Machines
no drive between motor and
no drive between motor and... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
