Question about Tappan TGF657 Gas Kitchen Range
Tappan oven i need to clean under the burners of my stove but dont know how to open it up
  • 833 Answers
Remove the burner grates. Below that are 'trays' that can be lifted out.
Posted on Dec 12, 2007
I have an older Tappan gas range. There is a
If you are referring to the top of the oven cavity itself (the ceiling in the oven) you may be describing the flue gasket and flue that is mounted on the top of the oven cavity. The part numbers are 316116600 and 316204401, respectively.
If you are referring to the top panel of the stove directly under the console, and in back of the surface burners, you may be describing the oven vent opening. It is normal for this vent to have oven heat escaping it. That's what it is for. That's also why you do not leave anything on the stove top while baking. There is a vent cover that is supposed to install over the opening. The part number is 316104500.
If the model number is correct, you can refer to pcappliancerepair.com for illustrated parts listings. The flue gasket and flue are listed under the "Body" section as items 35 and 36, respectively.
The top vent cover is listed under the Top/Drawer section as item 25.
Please review the parts listings for clarification. If I have identified the wrong parts, based on your description, or if the model number is not correct, please post back and let me know. I hope this helps you.
Dec 20, 2009 | Tappan TGF320 Gas Kitchen Range
THE STYAINLESS STEEL COOKTOP
I NEED TO REPLACE MY STAINLESS STEEL 5 BURNER WITH GRIDDLE COOKTOP ON MY 36 I TAPPAN RANNGE BUT DONT KNOW WHERE TO FIND ONE. I CANT SEEM TO FIND THE SRIAL NUMBER/MODEL NUMBER ON THE STOVE. HELP! DAN WILLIAMS
Jun 16, 2008 | Tappan MGF500PBW Gas Kitchen Range
Burners and oven not heating tappan range 560s111po1
You need to check the connection at the back of the unit that hooks to the house power. Turn off breakers or pull fuses before checking. It sounds like you only have half of the voltage you need. One of the wire connectors may be burnt or you may have a problem with the house wiring.
Apr 23, 2008 | Kitchen Ranges
Tappan Stove 5 burner with Oven
does the pilot seem low?you can remove the pilot then clean it out,let me know.
Nov 10, 2007 | Tappan TGF320 Gas Kitchen Range
Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Tappan Gas Range Oven Will Not Light
probable displaced burner assembly, faulty flame failure device or blocked burner or jet. Regards Engineer
Jul 20, 2007 | Tappan TGF320 Gas Kitchen Range
Tappan TGF657 Gas Kitchen Range Logo
81 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Sal De
Craig Butler
Craig Butler
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
