Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire washer my frigidaire washer 8022 C seems to have no button to put it on. I don't have a manual and I just cannot put it on somehow.
    President:
  • 1,294 Answers
Click on your brand Frigidaire (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line. And dont forget to rate me, on this great site.
Posted on Dec 13, 2007
How do i get the door open on a frigidaire front load washer?
check underneath the washer below where the handle is for a ring. pull to manually release lock.
Dec 02, 2014 | Frigidaire Washing Machines
How do I put my Frigidaire front loader into test mode?
Hello Angel BriBri, that's a great question!
I see that you would like to put your Frigidaire washer into test mode and you do not have the available buttons listed on the average test. Could you please provide me with your model number? You can usually locate the model number on the serial tag which can be found on the door frame of your washer. With that information I can look over your manual to see if I can locate the diagnostic mode. I look forward to assisting you. -Matt
Oct 18, 2014 | Frigidaire Washing Machines
Clean tub options keeps blinking on affinity frigidaire fafs4474lwo model
Hello Jodi, thank you for your post!
Your Frigidaire washer (FAFS4474LW0) will automatically prompt you to run the CLEAN WASHER cycle typically every 50 cycles. If you wish to begin the cycle, press SELECT when prompted. This maintenance cycle uses hot water and two rinses to remove residue that may cause odor. For best results, I recommend to use the CLEAN WASHER cycle once a month
You may press the CANCEL button to manually perform the cycle at another time if you prefer. You can do this by following these directions:
    ·Rotate cycle knob to Rinse & Spin
    ·Then press the CLEAN WASHER option button
    ·The LCD screen will display "SYSTEM CLEAN"
    Hope this helps! - Z
Jul 19, 2014 | Frigidaire Fafs4474lw Affinity 3.81 Cu Ft...
I need a manual for the Frigidaire FAFS4272LW Front Loading Steam Washer
Hello Ann Todd - I located the manual on the Frigidaire website. Here is the manufacturer link and according to your model it seems like the direction of the door swing cannot be change. If you have difficulties pulling up the requested information, I recommend taking off the last letter of the model number so you can pull up the data.
Feb 16, 2013 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer won't stop spinning with 1 minute on timer- it continues until I hit cancel. I don't like to babysit a machine but have to make sure it doesn
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
Sep 14, 2012 | Frigidaire Affinity ATF7000E Front Load...
When i turn on my frigidaire affinity front load washer it beeps and LOC comes on the screen it will not do any thing I have unplugged for a while it still says samething with the door open or closed ....
The control lock feature has been activated. To toggle this off, press and hold Options and Select for 10+ seconds. There is a small padlock indicated in the middle of a line between the buttons that toggle the lock on and off. This feature prevents anyone from changing a wash program when in use or a child starting a cycle with the cat or another child in the washer.
The manual for most Frigidaire appliances are available here: http://www.frigidaire.com/manuals . Enter the model number and click Search. Frigidaire lists several models of the Affinity ATF7000E. The direct link to the operating instructions manual for the ATF7000ES0 is here: http://manuals.frigidaire.com/prodinfo_pdf/Webster/134602700ef.pdf . In this manual, the control lock is described on page 2.
I hope this helps.
Oct 30, 2011 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire front load washer will not start. anytime I push a button on the front panel the "LOL" sign flashes. on the front of the washer panel d wash rinse final spin control lights are...
Is the message "LOL" or "LOC"? I suspect the child lock "LOC" has been activated. To toggle this off, press and hold Options and Select for 10+ seconds. This feature prevents someone from accidently starting or changing a cycle selection.
There is a small padlock icon in the middle of lines linking the two buttons that let you toggle the child lock on and off.
There are two Frigidaire washers with the model ATF6000ES (the S is followed by a 0 or a 1). The manuals for both are available here: http://www.frigidaire.com/manuals?model=ATF6000ES . The child lock feature is described in the Operating Instructions. For the ATF6000ES0, the direct link to the appropriate manual is http://manuals.frigidaire.com/prodinfo_pdf/Webster/134604400.pdf . See page 2 under Washer Features.
I hope this helps.
Sep 21, 2011 | Frigidaire ATF6000ES Front Load Washer
My frigidaire GLTF2940ES3 front load washer keeps making beeping noises even when not on. I have unplugged it until using it. Seems to work somewhat but it stops in between cycles, beeps and blinks...
frigidaire has problems with their computer boards and it sounds like this is your problem,i've seen them shut down and then after a while start beeping on it's own just like your machine is doing and it was the board part 137006000
Dec 04, 2017 | Frigidaire GLTF2940ES Front Load Washer
How do I go to clean cycle-Frigidaire affinity ATF6000fs
I was doing a search for infor on how to clean my affinity front load washer, and came across this infor and this did not work for me either, but when I turned my dial to rinse and spin then hit clean the clean option appeared.
Jan 21, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity/dr error
dr code means door not closed
get some crc spray and spray into lock on machine
that will lube the workings and should fix problem
Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
133 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
