GE WBVH6240F Front Load Washer
Problem for GE WBVH6240F Front Load Washer
Im needing to know how to install the replacement
By candiemeacha on Sep 17, 2009
im needing to know how to install the replacement door boot-bellow seal on my front load washing machine. i purchased the seal that i was told is a universal seal due to the original seal part no longer being made and now replaced by the universal.
the machine is model: WBVH6240FOWW and SERIAL#LL202749T
Best Solution
posted on Sep 17, 2009
Helpful)
VtToolMan
Rank: Guru  GE Expert
Rating: 97%, 653 votes
Candie, The tub gasket (door seal) is part number #WH08X10022 with a new substitution part #WH08X10036. However, since each model can be slightly different, depending on the serial number which denotes when it was manufactured, you might want to confirm that the above gasket is the correct one for your particular washer.
I'd suggest you call the folks at Sears Parts Direct at 1-800-252-1698 and give them your complete model number AND serial number before you start in on the repair, so you can be sure you have the correct substitution bellows gasket.
It's a relatively easy repair, all you need to do is remove the spring retaining wire around the outer edge of the bellows gasket, just peel it back at the edge to see it. Now locate the locking loop by going around the rim. Once you find the locking loop, you can remove it using a couple pairs of small needle nose pliers as they make it easier to get off.
Once you've done that, you'll see the locking plate that holds the back side of the bellows gasket onto the outer washer tub. Remove those fasteners and you can get the bellows off and start in on putting the new bellows onto the washer, just reversing the order you used in the removal process.
Here's a line drawing that shows the exploded view of the tub section, with the gasket (item #306). Just take your time removing the old gasket so you remember what you're doing and when installing the new gasket so as not to rip or tear it in the process. I'd also suggest you let the gasket relax for a good 4-5 hours (to get the kinks and folds out of it from the packing box) before you do the installation.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WBVH6240F0WW&productCategoryId=0153200&brandId=0432&modelName=WASHER&diagramPageId=00004&componentDescription=TUB%20&%20MOTOR&documentId=G6090504&backToLink=Return%20to%20Sub%20Components%20list
Here's another link to one of my other solutions for installing a bellows gasket on a GE front loading washer that you can also review for more installation tips, etc.
http://www.fixya.com/support/t2730376-need_help_in_installing_door_bellow_ge
Hope you find this Very Helpful and best regards!
Was this helpful?
Yes
No
5 people thought this was helpful
Popular Solutions for GE WBVH6240F Front Load Washer
Questions and Unsolved Problems for GE WBVH6240F Front Load Washer
Do you recommend GE WBVH6240F Front Load Washer?
Answer
Answer
I need to replace the time on my GE WBVH6204F front loader washer. I have removed the screws I can... (More)
Answer
Our machine keeps turning off during use. We used the machine on and off all day and night yesterday... (More)
Answer
my ge front loader will not spin. the door is locked and shut. it goes into the cycle just fine and... (More)
Answer
Horrible agitation. I can't even wash bath mats or anything heavy and large. Have had it checked by... (More)
Answer
washer wont start. says dl error then F. Is this the door problem or what/
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
