Question about Fujitsu Plasmavision PDS-4221 42 in. Television
Fujitsu Plasma 42' approx 4 yrs old
When switched on I get the grren light for approx 5 secs then a flashing red light. No picture. Any ideas/.
HI , i have the same problem . it is either the power supply unit or the plasma display panel . I am problem solving it currently . generally the cost is about $1000 (aus) to fix . it is worth doing as fujitsu are outstanding plasmas .
if u need service manual pls email me at and will send service manual .it has the the checks to do so u know which part needs replacing . U need some experience to do the checks
hope this helps
Posted on Dec 21, 2007
Fujitsu plasma vision monitor. Pds42211 red flash 5 times, long number displayed lhs.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there.
There is details about the blinking codes to Fujitsu Plasma Display.
Oct 31, 2012 | Fujitsu Plasmavision PDS-4221 42 in....
Fujitsu P42HHA30ES Plasma TV screen has stopped displaying
It sounds as though you have a fault on the Power supply, the fan doesn't not normally fail on this model. If you'd like your screen repaired, please call 0208 731 3432
Jul 11, 2010 | Fujitsu P42HHA30ES (Bundle) 42 in....
Philips flat screen 42" flashing red light 7 times it stops for 5 seconds and 7 more flashes if i unplug and plug it a few time it will come on
my 42 inch phillips, i turn it on green light comes on for 10 sec then red light comes on and flashes 4 times then stops for 5 sec then repeats.
Apr 20, 2010 | Philips 42PF9631D 42 in. Plasma Television
Picture goes out and red power light flashes
Up , i also encountered the same problem 3 days ago. 42" Fujitsu Plasmavission. I'll try to call an expert, i hope its not a digital board again for me, it will cost around $2,000usd so better buy a new Korean made LCD for better and cheaper parts. I guess you also experiencing trmendous heat at the back of your plasma right?
Dec 19, 2009 | Fujitsu Plasmavision 42" TV
I have a Fujitsu 42'' PDS4221 - 10 years old - shuts itself off
See Fixya tips and tricks:-
'Fujitsu Plasma 42" random shutdown - continuous flashing red'
While the model of your set is slightly different, the checks described generally still apply, as it is very similar.
Nov 18, 2009 | Cars & Trucks
42 Fujitsu PDS4221W-H, no power
A user manual is available from this link:-
Check for a hidden power switch under the lower left or right under corner of the screen, ensure it is ON (- not sure if this switch is fitted to your model, but it does exist on other Fujitsu models).
Fujitsu no longer support or manufacture plasma screen TVs - therefore no parts are available from them. [Fujitsu only serviced to board replacement level - very expensive].
The Fujitsu models (generally, after 4 or more years use) suffer from cracked solder joints on circuit boards (due thermal cycling stress).
See Fixya tips:-
"Fujitsu Plasma 42" random shutdown - continuous flashing red led".
Oct 28, 2009 | Fujitsu Plasmavision 42" TV
Power Issue 42" plasma flat HDTV Pixel Plus
you ip board is bad go t0 this site typ in the modle of tv and buy it . works like brand new .trust mr it did and saved a lot
Apr 07, 2009 | Samsung SPN4235 42 in. Plasma HDTV
42" Fujitsu Plasma TV (About 10 yrs old)
You have not fully identified the model number of your unit, but
this is most likely caused by the Main Power pcb.
For models P42HHxxxxx and P42HCxxxxx see Fujitsu Service Bulletin on this problem. -see link below
A competent service technician should be able to implement the service bulletin.
Sep 29, 2008 | Fujitsu Plasmavision 42" TV
Fujitsu plasma went blank
Need to have the power supply checked by a qualified technician.
Feb 12, 2008 | Fujitsu Plasmavision 42" TV
Fujitsu Plasmavision PDS-4221 42 in. Television Logo
368 people viewed this question
Top Fujitsu Televison & Video Experts
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
