Question about IBM Wheelwriter 30 Typewriter
Every key I press chirps. Don't know how to turn it off.
I leaned over the machine and accidentally hit some buttons, now everytime I strike a key it chirps. It's making me crazy..
  • jsign Dec 13, 2007
    It Worked!! Thank You.
THE KEYS ARE STRIGHTING THE PRINTWHEEL BUT THE THE PRINTWHEEL IS NOT PRINTING ON THE PAPER, THIS HAS HAPPENED BEFORE AND WE USE SOME CODE TO CORRECT IT, BUT I CAN'T FIND THE MANUAL. PLEASE HELP ANYONE!!!!!!!
Posted on Jan 24, 2008
  • IBM Master
  • 3,594 Answers
I believe you have turned on the "clicker" press and hold the code key and and press the "s" key
Posted on Dec 12, 2007
  • Dick O Reilly Dec 12, 2007
    Press and hold the code key and press the "s" key this should turn off the "cligker".
    Hope this helps
    dickyo
Will the keyboard still be paired when I turn it back on?
yes if you have paired it origanally but you donot have to turn it off if you are not using it it does not consume energy unless you hit a key and it only consumes energy for each key strike .
I only turn mine off when travelling in case of prolonged accidental key strikes
Oct 21, 2016 | Computers & Internet
There is a code CL on panel. Cannot start machine.
CL means the front panel child lock has been activated. Without knowing the make and model of your washing machine, I can't identify the correct keys to press and hold. On some brands, you need to press two keys and hold them for 5+ seconds. For others, you may need to hold a single key for 10+ seconds. You have to hold the appropriate key(s) until you hear a chime or the code disappears.
Often, there will be a tiny lock or child's face symbol on the key, underneath it or in the middle of a line between two keys on the control panel. The font for the symbol is much smaller than the rest of the type on the washer.
The model number is critical with some brands. One LG washer can toggle the child lock with the Tub Clean button. Another needs the Dry and Spin buttons held simultaneously. Yet another model, you need to press and hold End of Cycle. A fourth LG model toggles the child lock with the Options & Select keys.
If you add a comment with the make and model of your washer, I should be able to help you identify the child lock key(s) that you accidentally pressed.
May 11, 2015 | Washing Machines
Shift Key Problem , Royal Quiet Deluxe
There is a carriage shifting screw on both sides of the typewriter. You will recognize this because it is a screw that has a big bump head with felt on it. It is being hit when you hit that shift lever. You will have to loosen the securing nut first before adjusting.
Nov 17, 2013 | Royal Office Equipment & Supplies
Python 476p
May depend how it was programmed. My Python 476P was setup with Lock and Unlock pressed to get it to remote start. Then, get in the vehicle, put the key in the "on" position and press lock / unlock to get it to end the remote start cycle. Then Drive off ...
I got a second remote, followed some directions via YouTube to program. Key in the on position, then hit the valet button once, then press and hold. One chirp, hit lock on remote. Let go of valet button . Press, then press and hold, two chirps. Hit unlock. Continue for 3 (aux) and 4 (panic). End result was Lock would also unlock. Unlock did nothing. And Aux started the remote start sequence.
Having bought a vehicle used, then no manual made this a bit difficult. I will continue to test alternate programming to try to match the original remote so accidentally firing up the rig doesn't happen. My suspicion is I have to maybe do Lock, Aux, Lock/Unlock, panic instead. Good luck.
Oct 30, 2012 | Python Vehicle Parts & Accessories
Viper remote start system just installed. When I use the remote to lock the car--there is no longer a chirp noise that confirms I hit the lock key. Thanks, Mary
I don't know which remote starter you have, but I have a Viper 5101. To fix this problem, I started the ignition, then turned it off, leaving the key in the ignition. I pushed the Valet button (it has a blinking blue light, mine is near my rear view mirror) and held it. Then, I pushed it 3 times, then held it down a 4th time. Then, I pressed the lock button once. I pushed the Valet button again to take it out of programming mode, and it worked! I got this sequence of steps from the installation manual online: http://www.scribd.com/doc/45065156/Installation-Viper-5101 Hope that helps!
May 12, 2011 | Remote Start System
I accidentally hit the shift button 5 times and
Hit the shift key again another 5 times to disable sticky keys.
Regards.
Jun 29, 2010 | Computers & Internet
Factor disarm wire can not locate it? checked the drivers kick panel, door locks are not disaming the system from the door lock moduel
To turn off the auto locks 1 turn the key on 2 press the unlock button 3 times, 3 turn the key from on to off, 4 press the unlock button 3 times, 5 turn the key back to on and the horn will chirp, 6 press the unlock button, then the lock button. the horn will chirp once if the auto locks are deactivated, or twice one short and one long chirp if activated. 7 turn the key off and the horn will chirp once to confirm exiting the system
Apr 21, 2010 | 1998 Ford Expedition
How to program a remote control for a phyton 1400 xp car alarm and remote starter
open s door turn on the key to the on position press the valet button once and then press one more time and hold it , you will hear a chirp and then you hit the lock button on your remote and then you will hear another chirp. Once you heard that you can let go of the button and turn off the key and your new remote should be program. Now if you have special settings set to the other remotes then you must also program them as well. The only way to program those settings would be using a bitwriter, and only authorize shops have those
Jun 10, 2009 | Vehicle Parts & Accessories
IBM Wheelwriter 30 Typewriter Logo
65 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
