Question about Saitek USB Action Game (p220) Game Pad
P220 digital gamepad not recognized by XP
Can't find drivers for this model, and device is not recognized on USB port by XP Home
0 characters
1 Points
I cannot get my gamepad work on games on pc?
Hello, My old controller is like this, and it can be detected in windows XP now that i am using Windows7 and it is still working fine, make sure that the device is being detected by your Operating System and the make sure that the USB port that you are using can detect USB device. Thank You For Using Fixya
Mar 05, 2011 | Logitech Precision USB Gamepad PC Game...
Do i need an installation disk for the extreme 3d pro joystick if I'm using it with a mac
Follow the below guide from Logitech.....
The following Logitech gaming devices will function on a Macintosh computer running Mac OS 9 with Input Sprockets 1.7 or higher. You must also have a functioning USB port.
Logitech® Freedom™ 2.4
Logitech® Dual Action™ Gamepad
Logitech® Extreme™ 3D Pro
Logitech® Attack™ 3
WingMan® Attack™ 2 on the USB port
WingMan® ActionPad™
WingMan® Formula™ GP on the USB port
WingMan® Precision GamePad (USB version only)
WingMan® Extreme™ Digital 3D
WingMan® Formula™ USB
WingMan® GamePad USB
These devices will use the Mac OS Human Interface Device (HID) support. If you are experiencing detection problems using one of the supported devices on a Mac, please contact Apple to ensure your computer meets these requirements. If you are experiencing problems in a particular game, please contact the game manufacturer.
To determine if your Logitech game controller is detected please do the following:
  1. OS 9.x
  2. Click the "Apple Menu".
  3. Click "System Profiler".
  4. Click the "Devices and volumes" tab.
  5. Look at the USB tree to confirm that the controller is listed.
  1. OS 10.x (Traditional View)
  2. Double click the "Hard Drive" icon.
  3. Double click the "Applications" folder.
  4. Double click the "Utilities" folder.
  5. Double click "System Profiler".
  6. Click the "Devices and volumes" tab.
  7. Look at the USB tree to confirm that the controller is listed.
Jul 19, 2010 | Logitech Extreme 3D Pro Joystick
When i conect him to computer, i get an error
try the logitec support site for drivers it may be ur usb
May 10, 2010 | Logitech Precision USB Gamepad PC Game...
I have a Twin USB Vibration Gamepad i need the driver for Windows 7
there is no driver for windows 7 as sitek (the chinese manufacturer of the device that sells it as in "white box license" for others to print its logo on discontinued such a device since 2005. Mind you itself has vanished and a new firm has taken over that address.
Thus end of story , problem on relaying on a small time manufacturor , however i do have the xp drivers and they do work , windows 7 would not accept them and insists that the generic driver it uses is up to date (which works fine except the vibration a.k.a force-feed-back wont work)
I am working on a new uproach on injecting the xp driver into windows 7 registry and if it works i'll let you know :)
Mar 05, 2010 | Genius G-12U Vibration, USB, PC gamepad....
USB gamepad is not detected.
Get the latest dirvers from the manufacturers website and install it on your pc.After that connect the gamepad.It should work fine.
Code 10 error is due to incomplete drivers or driver malfunction
Aug 13, 2009 | Logitech Rumblepad 2 Game Pad
Trying to install Gravis Eliminator Gamepad Pro/USB under Windows XP SP3. When i plug it into a USB port, I get the Windows message "USB Device Not Recognized". If I go to Control Panel > Game...
I have encountered a similar issue before. What works, is to try the update of your chipset's driver. This could be an error once present in your chipset's initial release, but has since then been fixed by your chipset's manufacturer. Also this could another among the millions of peculiarities in the windows operating system, i say this for it is very possible the the controller will function well if a game is started while the controller is already plugged in. Just see if it works, but an amendment to the chipset's instruction set would be optimal.
Jul 20, 2009 | Gravis Eliminator GamePad Pro Game Pad
I used one like that for my windows xp home PC (It looks just like the Playstation 2 controller) and it worked with MAME (original arcade games that were downloaded on my computer) It comes with a little CD that has the drivers on it...Look on ebay..they are very cheap coming from China and Hong Kong
Apr 24, 2009 | PC Game Controllers
Gigaware controller on vista
You don't (and can't) disable DEP for the controller (a gamepad controller isn't an application, it's a device which uses a driver, Data Execution Protection applies to applications ie .exe files), it's the game or emulator you disable DEP for, so that you the game can run, completely free of security bindings, and then you would be able to go into the game configuration menu and select your gamepad, and calibrate it. Calibrating means the game detects you gamepad and applies the specific functions to each button.
One way to be sure is to disable DEP for everything, then install a game, and THEN plug in your gamepad. Then start the game/emulator and go to the configuration menu within the game/emulator and set up the gamepad calibration in there.
If it doesn't work, then you haven't installed the drivers for the gamepad properly, or haven't installed the correct driver.
Before doing any of that, you would have checked in Control Panel and Gamepad Controllers, double clicked the Gamepad in the list and pressed Calibrate, to enable generic gamepad functionality.
If you hadn't done that, do so now.
If it still doesn't work, then NOW disable the DEP (either all DEP or for the game/emulator you want to play). Unplug the Gamepad and load up a game. Then plug the game pad in. Set up the gamepad from within the game/emulator config menu, which differs from game to game, of course, but is more or less the same.
If it doesn't work.. re-install the correct driver for the gamepad.
Also make sure your operating system is fully updated and you're plugging the gamepad into a usb2.0 port. and have rebooted after installing the gamepad usb driver.
That's everything you need to know..
Good Luck!
Chris (ziraffa)
Dec 27, 2008 | PC Game Controllers
Most likely you dont ahve the right drivers or are putting it in the wrong USB port.Try looking for drivers for it.Maybe your PSU Unit doesn't have enough power.
Jun 03, 2008 | PC Game Controllers
Find me the driver for my joy stick: HCL double vibration controller
go to
search for 1022
download hcl gamepad drivers
Apr 19, 2008 | PC Game Controllers
Saitek USB Action Game (p220) Game Pad Logo
164 people viewed this question
Top Saitek PC Game Controllers Experts
Jeff Turcotte
Jeff Turcotte
Are you a Saitek PC Game Controller Expert? Answer questions, earn points and help others
