Question about Hitachi 43UWX10B 43" Rear Projection Television
Hitachi 53UWX10B Projection TV - Color Separation
From what I understand, the problem I am having with the color separation on my TV, it has something to do with IC and STK. From what I've read, a TV repair expert must fix it due to welding issues and alignment issues. It first started in the upper left corner of the screen with a blue outlined loop down into the screen. Now, it has progressed much further down the screen and all colors are misaligned. Is it true that we cannot fix this ourselves? And is there something else it could be, or is this a pretty standard problem.
  • bigmax Dec 30, 2007
    Color Seperation problem
  • Anonymous Mar 28, 2008
    Same issue...Darn I liked that TV. Now it's trash because it will cost too much to fix.
    Genius:
  • 1,694 Answers
Common problem on all rear projection TV's...............
Somewhat difficult,requires chassis pull and solder in new parts.
Part # stk392-110 subs to upgrade stk394-160E part # CZ 01341
Posted on Dec 17, 2007
How to set color, verticl and horizontal lines
Not all universal remote control's operate MENU button on TV!!!
If you have >>COLOR separation ( red blue green) and CAN NOT adjust via MENU button then you must replace conversion IC's>>
part number: STK 392-xxx.....easy repair!!
May 19, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Hitachi tv no picture or sound.
my hitachi projection tv 53uwx10b screen is black with no sound or picture when the power button is on
Dec 29, 2009 | Hitachi 53UWX10B 53" Rear Projection...
I changed the IC chips on my hitachi 53uwx10b tv like you guys said that helped alot but still have wavey lines on both sides of the screen what do I change on the con. board now? Thanks alot Jim
Resistors " RK42 3.3ohms
RK46 1.8ohms RK50 2.7ohms RK54 1.5ohms RK58 3.9ohms RK62 2.2ohms After you replace all of them then enter convergence by pulling OFF bottom front panel there on front of convergence board is a small blue button press it and a convergence pattern will come up now aline each color red then blue.
Sep 24, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Convergence settings on hitachi 53uwx10b
Yes - You will need to either remove the circuit board or lift up the tray. If you are not sure how to do it yourself read the link below.
  • This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 10, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Picture is clear but with a yellow tint .
Make sure, if your using component cables ,that they match up color for color and are plugged in.If it looks good try adjusting your colors on the TV.You can also try unplugging the TV for 5 min. and then plug it back in.This might be a TV issue.
Jul 07, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi projection hdtv has 3d effect and bowed shape
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 15, 2009 | Hitachi 53SWX01W 53" Rear Projection...
Color convergence problem
I'd suggest either replacing the ICs and resistors on the convergence board (requires soldering skill by yourself, someone else or an electronics repair shop) or purchasing a new convergence board from Partstore for $299 and swapping it out yourself.
While it may sound daunting, it really isn't once you find out more regarding this issue and dig into it a bit.  There's a wealth of info at the Digital Home Forum regarding this particular issue and ways to resolve it.
Good luck...  -TD
Apr 30, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Color separation
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 03, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
593 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
