Question about GoVideo R6530 DVD Recorder
Split Screen Same image on left & right on Screen
When I put on my Recorder it shows split Screen.
Same Image on both sides
I can't record or play any Disc.
I've had Go Video R6530 for almost 4 years and this is the first time I 'm
having a problem.
Please help.
Tony Mongillo Sr.
(tonymsr@msn.com)
  • weare66 Apr 16, 2008
    I had the same problem,until I saw that the player was set for progressive scan, the "P" on the front display.Turned it off and the picture came back in color and in playing ok now. I haven' tried to copy yet. Will let you know. Good Luck
Press the prog scan button this should fix it
Posted on May 01, 2008
Our Phillips flat screen TV picture is split down the middle vertically. One side shows a mirror image of the other side, and then sometimes one side is a lighter shade than the other, when it is full...
This may be due to a faulty Timing Control board (TCON board). I had a similar problem with my Samsung LCD TV picture being split vertically down the middle. The image on both halves appeared fuzzy and in reverse (mirror) including the menus. I replaced the TCON board and the problem was resolved.
Aug 18, 2011 | Televison & Video
Image split with black bar in middle
check leads if they are connect in the normal video slot on dvd player and chek the player settings what out pot it is on
Aug 21, 2009 | JVC HR-XVC18B DVD Player/VCR
Dvd player split screen
I had the same problem. It turned out to be my cable that went from the dvd player to the TV. I replaced with new cable & everything worked fine again. Hope this helps & please remember to rate my answer. Thanks.
Feb 06, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
No picture on tv when i turn on dvd. get split screen black & whi
Give this a try. Using your user's manual, locate the "Configuring your recorder" section. Under this section there will be "System setup - general" subsection. Being that you are unable to see anything on your tv display you will need to use your manual as your display. Press the "SETUP" key on your remote. Once again using your manual as your display, scroll down to "Restore factory settings" and press "ENTER" As long as you are located in North or Central America and using interlaced video outputs you should have your normal display back.
Hope this helps.
Nov 24, 2008 | Protron PD-DVR100 DVD Recorder
T30 always comes up with record-ready display screen
T30 defaults to an opening display screen based on where you were when you last used the device. When leaving from the record folder and record mode, you will always open with the record-ready screen. If you left your T30 while in the music folder playing a music file, you will be returned to that.
This record-ready display screen has a numeric and bar time line. The numeric values of the line are in hrs:min:seconds. This line is also split: the right half of the line indicates the total amount of available recording time, while the left half indicates your time as you record. If you compare the values of the right and left sides of the numeric bar while you are recording, you will see that the right side is diminishing as the left side increases in numeric value. When you complete your recording and save your track, the right side will now indicate the new total time (the amount your screen first displayed LESS the time value of the track just recorded).
When you are playing a music file, if you watch the time display, you will see the numeric information changing in the same way. The left side indicates how may hrs:min:seconds your track has played while the right side indicates the total time value for that file and will be correspondingly decreasing while you play your music file.
So in the short, you don't need to worry much about your display screen unless you open in the wrong folder or you need more recording time than is available. Then it has a message for you.
Nov 06, 2008 | iRiver T30 MP3 Player
VHS play back
I am having the same split screen black and white problem. I don't think anything simple will fix this. I have looked into the unit and almost all the video processing happens on one little PC board under the DVD. I think that the capacitors on the bottom of this board are at fault, as there have been MANY noted failures of Panasonic Professional DVC decks due to these type capacitors failing.
Oct 22, 2007 | Panasonic DMR-ES40V DVD-Video Recorder
Screen split into 2 colours - vertical split
I think it is degaussing problem if any thing is lying which has magnet please remove it. &then put of monitor for 15 minutes & then put on again.do not move when it is on. please let me if it gets ok good luck
Sep 09, 2007 | Philips 170B4MG 17" LCD Monitor
Panasonic DMR-ES40VS
I called Panasonic, and they told me to try a reset. I'm sorry, but I forgot which button to push and hold to reset it, but it has worked GREAT ever since! A local shop said it was a loss when I described the problem to them. Call the Panasonic Service Center, and they can tell you how to do a reset.
Feb 20, 2007 | Panasonic DMR-ES40VS DVD Recorder/VCR
GoVideo R6530 DVD Recorder Logo
392 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
