Question about HP Business InkJet 2300 Printer
HP 2300 Manual Tray Issues
I have a printer that, when I print, I want the first page to come out of the manual feed tray and all the rest of the pages to come out of the second drawer. This has not been a problem, but recently, I have been having some problems. It will print the first page out of the manual tray, then it says something like "load manual feed plain paper" or something similar. If I push the big green check mark, I can make it print from tray 2, but I would rather not have to do that every time I print. I am curious as to what I need to change to take care of this issue.
Soulvisitor
  • 1113 Answers
SOURCE: tray 1- load plain letter
Linda,
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover it...post back
Soulvisitor :-)
Posted on Dec 18, 2007
  • 3422 Answers
SOURCE: hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Posted on Jun 18, 2008
SOURCE: HP P3005 Will not pull from Tray 1
Click File > Print > Properties to check your settings.
To verify that tray 1 is working, put paper in tray 1. Press green check until you see Information Menu. Scroll using arrows until you see Print Menu Map then press green check. If it prints from tray 1, your problem is not with the printer, but with the PC settings.
i has follow this step, but need to press green check button to resume print menu map.
tray 1 manual feed set to A4 paper plain size
manual feed is on.
there is paper on tray 1
ps setting tray1 manual feed is A4 plain size paper.
send print to tray1 manual feed even there is paper at tray 1
i still need go to the printer and press green check button to resume print
Posted on Jul 25, 2009
  • 40 Answers
SOURCE: hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Posted on Jul 27, 2009
SOURCE: HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Posted on Aug 31, 2009
How to fix this error in printer hp p2055dn ''manual feed press ok for available media into tray 1
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P2055d Printer
My HP P2015DN only prints one page at a time. If I have a 5 page document, the first page prints and then I must print the go button for each page to print.
Is the paper feeding from the manual tray or tray 2. If you are printing from tray 2 and have this problem then it is likely that your driver or software is looking for different paper types than you have loaded in the printer. For example, if you have plain paper in tray 2 and your software wants to print on letterhead, then the printer will stop after each page and by pressing the button you are telling the printer that it is ok to print on different paper. If you have the paper in the manual feed tray (tray 1) then I would check to make sure you are telling the pirnter to print to tray 1 and not manual feed when you send a print job.
May 02, 2011 | HP LaserJet P2015dn Printer
Manual feed isnt working. once tray 1 is open i thought it would automatically know i want to use manual feed.
Not necesarily so, it depends on how you have the printer configured. To test the MP tray, use the arrow keys to get to troubleshooting menu, press check, use arrow keys to get to paper path test, press check, set tray option to tray 1, then print test page. Printer should feed from MP tray. If it does, then the problem is that you do not have the printer set to print from MP tray first or you have the tray options set to exclusive which means that if your print job asks for tray 2 then printer will not print from MP tray unless you specify MP tray in the print options.
Mar 18, 2011 | HP LaserJet P4015 Printer
When i print it defaults to tray manual feed. i
change paper size setting on printer preferences on your pc
Apr 21, 2010 | HP Office Equipment & Supplies
HP Laserjet 4700 Always Defaults to Tray 1
Your tray 1 might be open (even just partially) or your manual feed setting might be on. You can find this setting under > Configure device / Printing / Manual Feed
Jun 25, 2009 | HP LaserJet 4700 Printer
HP Laserjet 5000dn
if you using office go to page setup and select the tray(s) that you want to use for the first page and other pages ( both must be the same ) unless you only want the first page as letter head and the rest on plain paper or something along those lines ?
Also if you go into the properties of the printer and go to advanced and then click on the printing defaults button and see if the options in there are the same or different to whats in printing preferences.
If they are set to tray 1 then it will default to tray 1
Apr 13, 2009 | HP LaserJet 5000dn Printer
Printing problems - i can only print manual feed...
the manual tray is the is the one above the tray,
1-either your tray is set incorrectly must be set to Letter/Plain
priority is tray 2 not tray 1
tray one is the by-pass / manual
since this printer does not have a screen on it everything is setup through the PC.
print a configuration page and you will see all the settings
Aug 05, 2008 | HP LaserJet 1022 Printer
Xerox 8560MFP won't print first page from one tray and rest from another
Microsoft word overides the print driver for page choice. Choose from within word File | Page Setup | Paper.
Tray one on this printer is the manual feed tray. tray 2 is the first drawer.
Ensure the printer driver is set up for the additional trays
Jul 02, 2008 | Xerox Phaser 8560MFP Laser Printer
202 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
