Question about Infinity BassLink II Car Subwoofer
Basslink II problem running off speaker input
Just trying to install my new basslink II and have come across a problem. I am using speaker level inputs but am finding Im getting no sound with the plug pushed all the way in to the basslink, it works when it's kind of pushed half way in, but not all the way. I've tried it with both sets of cables but still get the same results, any ideas anyone?
Thanks in advance for any help.
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
Definately a wiring issue. Go to this site and backtrack to see where you went wrong. hope it helps.
Posted on Feb 18, 2008
Infinity Basslink. I wired and connected everything and sounded amazing. I removed my center console to construct a box to put the Basslink in. When I was putting the Basslink sub into the box (tight fit)...
I would get a test light and see if the remote line is still working. Otherwise, yes you probably fried it. Doesn't take much in car audio to fry an amp.
Jan 17, 2014 | Infinity BASSLINK Car Subwoofer
Power light
Hi Bill, I believe the power problem is related to the Remote wire which should be blue or yellow. The remote wire is suppose the turn the Basslink on and off when the radio is turned on and off. The yellow wire is normally used for power antenna. Traditionally the remote wire is blue. You can use a Speaker level adapter and splice in with the L/R rear speaker wires, and the adapter will convert the speaker level to line level. The output of the adapter will go to the Rear speaker input on the basslink., Write back if you need more detail on the adapter.
Oct 07, 2007 | Infinity BASSLINK Car Subwoofer
Need schematic diagram infinity basslink subwoofer
Design: The BassLink brings together a 10" subwoofer (treated paper cone, foam surround), a 10" passive radiator (to increase efficiency and limit distortion), and an extremely efficient, specially designed 200-watt Class D amplifier that work as an integrated system. Special circuitry monitors voice coil position to maintain linearity at high power levels, so you hear loud, clear bass.
Enclosure Type and Materials: The enclosure is made of an acoustically inert polymer which is rigid enough to resist flexing and dampens any resonance.
Servo-Control: The servo-control system continually monitors the performance of the speaker and ensures that the amplifier delivers exactly the right amount of power.
Class D Amplifier: This unit has a built-in 200 watt Class D amplifier which is highly efficient and designed specifically for use with the subwoofer and passive radiator combination.
Auto Turn-On Feature: When the speaker level inputs are used, the system will automatically turn on and off with the radio. Note: The auto turn-on feature does not operate when the preamp level inputs are used, unless the remote turn-on lead is connected.
Low-Pass Crossover: The low-pass crossover frequency can be varied from 50Hz to 120Hz for a seamless transition between the output of this unit and that of the other speakers in the vehicle. The crossover has a slope of 12dB per octave.
Bass Boost: The amplifier includes a continuously adjustable bass boost from -6 to +3dB centered at 40Hz.
Phase Switch: Allows you to select normal or reverse for best bass.
Mounting: You will be able to put BassLink in a variety of in-vehicle locations, thanks to its compact size and mounting feet that enable the rigid polymer box to be mounted vertically or horizontally.
Vertical Mounting Dimensions:
Width: 14.625"
Height: 13.375" (including feet)
Depth: 8.675" (10.076" including feet)
Horizontal Mounting Dimensions:
Width: 14.625"
Height: 9.5" (including feet)
Depth: 12.75" (15.1875" including feet)
BassLink LC Remote Level Control
Overview: The BassLink LC allows you to adjust the volume of BassLink powered subwoofer.
Installation: The BassLink LC may be mounted under the dash or may be dismantled and mounted inside the dash for a factory appearance.
Under-dash Mounting: Select a mounting location that allows easy, safe access to the control while driving. The BassLink LC has mounting "ears" to use as a template for drilling pilot holes. Attach screws through the "ears" to secure the BassLink LC to the mounting surface.
In-dash Mounting: Disassemble the BassLink LC by removing the Phillips-head screws on the front, rear, and top panels. Remove the bottom and side panels and disengage the RJ11 connector from the back panel. Choose a mounting location that allows easy, safe access to the control, and provides 1-3/4" clearance behind the mounting surface. Drill a 9/32" hole in the mounting surface. Feed the BassLink LC's potentiometer (with the knob removed) through the hold and use the nut provided to hold the control in place.
Connecting to BassLink: Route the cable behind the dash or other interior panels and under the carpet. Do not route the cable outside the vehicle. Connect the cable on both ends.
Inputs and Controls
Universal Interface: Front and rear, left and right Universal interface speaker-level inputs (for use with the supplied speaker-level input wiring harnesses)
Line Level RCA Inputs: Front and rear, left and right female preamp level inputs
+BATT (+12V): Gold-plated screw terminal, 0.350" wide
REM (remote turn-on): Gold-plated screw terminal, 0.350" wide
GND (ground): Gold-plated screw terminal, 0.350" wide
Fuse: There is an installed 20 Amp fuse
Remote Gain Control: Phone type jack for included remote gain control
Gain Control: Rotary control that sets gain (variable from 250mV to 4V)
Crossover Control: Rotary control that sets the low-pass crossover point (variable from 50 to 120Hz)
Bass Boost Control: Rotary control that sets bass boost level (variable from -6 to +3dB, centered at 40Hz)
Phase Switch: Selects normal or reverse phase (0 or 180 degrees)
Power LED: The power LED glows red when the BassLink is on
Servo LED: The Servo LED glows green when the servo circuit has determined that the woofer has reached maximum excursion and power to the woofer has been modified to provide maximum performance. The LED should light momentarily during high-level bass transients. Note: Avoid adjustments that cause the LED to remain lit for an extended period of time
Apr 01, 2012 | Infinity Bass Link Subwoofer Car Audio...
Power indicator light won't shut off.
Is you remote turn onwire (usually blue) always on? Check voltage with a meter or test light. It's possible that the wire is on all the time.
Larry T
Winona Lake, IN
Jan 27, 2009 | Infinity BASSLINK Car Subwoofer
Basslink keeps cutting off into protection!!
From what i have heard, If you have a speaker level input connection. this sympton does occur. You buy a scosche LOC and try giving the input to Basslink, it should work fine
Jun 24, 2008 | Infinity BassLink II Car Subwoofer
Infinity Basslink killing battery
Both issues sound like they are related to a non-connected or loosely connected remote wire on the Basslink.
If you're using RCA preamp wires to connect your stereo to the Basslink, make sure the remote wire input on the Basslink is solidly connected to the stereo's remote output.
If you're using the speaker level inputs on the Basslink and not the RCA preamps, make sure the remote input is not connected, as the Basslink will automatically turn on when it senses the speaker level inputs are active.
Mar 19, 2008 | Infinity BASSLINK Car Subwoofer
No power
Other than the +12V, the ground (-) and the 2 RCA inputs, normally external amps have also a remote trigger which switches it to active on. The remote trigger is activated by a wire from the head unit. Colors would either be yellow or blue but depends on manufacturer of head unit. Alternately, you can connect a simple toggle on/off switch to activate the external amp.
Additionally, pls verify that the 2 RCAs from your head unit are audio out and not audio in for aux source.
Good luck and kind regards.
Nov 01, 2007 | Infinity BASSLINK Car Subwoofer
Basslink drops out.
The auto on switch should only be in the on position when the REM wire is NOT connected. Auto on can be flaky. Basslinks respond better to RCA inputs then the high level ones. You might try getting an RCA line converter, they work very well with the Basslink.
Oct 02, 2007 | Infinity BASSLINK Car Subwoofer
Light is always on!
yes the problem is in the installation.the power supply usually has 2 to 3 positives one positive which is usually red go directly to battery. the other,either yellow,orange,or blue go to car stereo(not to battery or ignition) this supply,turn off the amp when u turn of the stereo. hope this help u....
May 09, 2007 | Infinity BassLink II Car Subwoofer
Infinity BassLink II Car Subwoofer Logo
408 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
