Question about XFX GeForce 6200 Graphic Card
Problems after installing drivers
I purchased a SFS GeForce6200 AGP card and it works in standard VGA mode. When I install the NVidia drivers, the screen goes blank with some occasional narrow colored streaks and stays that way and the power indicator light turns amber. The computer is not locked up because I can access it from another computer on the network. XFX suggested some other versions of the video driver but that didn't help. I installed the card on another computer and got the same results. I never tried restarting the computer a few times after the drivers were installed. I don't know if that would make any difference.
  • sammyjay Jan 02, 2008
    Thanks for all your suggestions. You may have realized my typo, but the card is a XFX not a SFS as I stated earlier! I have tried all the suggestions, and I still can't get the card to work correctly. The card works fine in safe mode. It also works in normal mode IF I first uninstall the drivers. But either of these conditions are no good for day to day use. The card I was replacing is a MSI FX 5200 which is working fine but I was trying to set up two monitors, and the DVI connector on the MSI card was DVI only, not the usual DVI/VGA combo connector. The drivers I'm using for the XFX card work fine on the MSI card. I have also tried this card in two other computers with exacly the same results.
  • reklampost Jan 05, 2009
    I have the same problem...
    The card will only work in VGA-mode.
    The problems seems to be related to the drivers. When i install the latest drivers i just get lines of white diamonds or bars along the screen.
    When i reboot, the screen goes bland after boot ( i see the blue progress bar at startup). Then the monitor goes to sleep.
    I have a HP LP2465 monitor.
I'm afraid to share my sympathy with you mate, but your card seems to be knackered. If its the one that came with a standard heatsink, and you get those streaky lines then its time to thrown that card away. Its done its time.
In future I will buy a fan for any graphics card I buy even if already has a heatsink built in to the card. The temperature can go as high as 80 Degree's C and at those running conditions its less then obvious why these cards fry up and give folks streaks.
I've wrote to innovision multimedia and await an answer soon. Just trying my luck if they can sort my card out over the coming months.
Posted on Jan 02, 2008
    Scholar:
  • 42 Answers
Does this happen AFTER Windows has done a full boot up, or before?
If this happens after Windows has started, then the problem may be with the vertical refresh rate. Some monitors will shutdown if the refresh rate is set too high. To correct this, I would suggest loading your computer into Safe Mode, which should allow the video to work, and go into your video properties (right click "Desktop", select "Properties", click "Settings" tab, click "Advanced"). On the "Monitor" Tab will be a drop box for Screen Refresh Rate. If it's set to something above 80Mhz, try selecting a lower rate, such as 70Mhz. Other than that, I'm not sure. And no, you cannot use Remote Desktop to change the refresh rate as it doesn't use the video card to display with.
Posted on Dec 24, 2007
Enable AGP 4x
you don't need to reinstall or format c:\ ..all you need uninstall al the drivers and install the correct driver of your VGA add on card.
Jan 18, 2008 | ASUS VIA 694XDP Dual Processor Chipset...
Need help with a new video card I install in my dell precition 360 don have video
Hello there,
This is the supported Graphics Cards the computer you have can use
Graphics Support . . . . . . . . . . . . . . . . . . . . . . nVIDIA® Quadro 4 280 NVS 64MB DDR, AGP 8X, available in single or dual VGA and single or dual DVI
nVIDIA QuadroFX 500, 128MB DDR, AGP 8X, dual monitor (VGA and DVI or two VGA)
ATIæ Fire GLô X1, AGP 8X, 128MB, dual monitor (VGA and/or DVI)
3Dlabsæ Wildcat4ù 7110, AGP 8X, 256MB DDR, Dual monitor (VGA and/or DVI)(Desktop chassis only)
let me know the Model of the Video Card you are trying to install and we can start fixing the problem
Thank you don't forget to Rate
Jan 25, 2011 | Dell Computers & Internet
I have a nvidia geforce4 mx420 64mb agp video card. When i installed windows 7 it said that i now have a standard vga graphic card. I was wounder can you help me with this problem? bascily windows 7 is not...
That is because you have a very old card that cannot meet the minimum requirement to be used in Win 7 - to be Dx9 compatible. This video card will never work, replace it with a better one - at least an 7 series one like
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3092427&CatId=318
May 19, 2010 | Computers & Internet
I have windows 7 Operating system installed on Intel Original D865GBF motherboard. The processor is 3.2GHZ. Ram is 2 GB dual channel (!GB x 2). I have added a graphic card PNY Ge Force NVidia 6200 AGP. The...
sounds like yo had the same Probles that I had with my 5200 geforce The install did not go well. what was happening was the direct x was binding to the old mother board graphics system and not the new card . to make it rebind just change the refresh rate in the nvidia icon in your task bar . disable the display adapter from device manager for the motherboard graphics .put the card in the slot change the montior cord boot up check you direct x by typing in run dxdiag and test directx to be sure it is runing with your card you can also see that fron the about nvidia you must have the driver for the card installed to do all this.. hope I helped
Feb 27, 2010 | Nvidia GeForce 6200 AGP Graphic Card
Dell Precision 450 new Graphics Card problem
drivers vga.dll version 5.01.2600.000(english)date 2/28/06 04;00:00 whql logo'd:yes mini vdd:vga sys vdd:n/a ddl version:unknown directx feture directdraw acceleration:not available direct 3d acceleration: not available agp texture acceleration :not available teste draw test direct3d the system is using the generic video driver please install video driver probided by the wardware manufacture. directdraw test result:all test result: all tests were successfull: direct 3d funtionality not available.you should veryfi that the driver is final ;from the harware manu facture. ram 512 mb storage capacity 160gb raid no graphics card:intel graphic media accelerator 900 gm primary optical driver dual-layer dvd+/-rw
Dec 03, 2009 | 3Dlabs AGP Video Cards: Wildcat VP560 64MB...
NVIDIA GeForce 8500 GT (Microsoft Corporation - WDDM v1.1)
HELLO YOU HAVE TO GO INTO THE DEVICE MANAGER AND DISABLE THE STANDARD VGA ADPATER. SHUT DOWN THE COMPUTER. RE BOOT. THEN INSTALL THE CARD DRIVERS
Mar 28, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
Geforce 5500 fx for agp ultra screen flickers
use the build in video card to install the AGP card drivers first and install the card and go into the bios and make sure its set to boot from the agp slot first not build in . Thanks
Nov 26, 2008 | Palit Microsystems GeForce FX5500, (256...
XFX GeForce 6200 Graphic Card Logo
172 people viewed this question
Top XFX Computers & Internet Experts
David
David
Alun Cox
KG John Justin
KG John Justin
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
