Panasonic tx37lzd70 the infrared controller only seems to work when very close to the tv. from a short distance (the sofa) approx 8 feet away it seems to be on a delay?? there is nothing blocking the area. any thoughts?
    Sergeant:
    Champion:
  • 362 Answers
How old are the batteries sounds like they are weak, use a digital camera and point the remote at the camera the light infrared should show uo in the camera if it dont your batteries are weak..
Posted on Dec 12, 2007
My remote control is working near the tv but at a distance its not working,itry changing batterias still not workingnot
If battery in the remote control is weak; this can happen. Repalce the batteries with new ones' and check. Still it behaves so; either the infrared sensor inside your TV; or the infrared lED, that emits infrared rays, is weak. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
There is details about how to check a remote control, using a mobile phone camera.
Nov 10, 2014 | Samsung HP-R5072 50 in. Plasma HDTV
Headlight bulb
At night , Park on level ground approx. 6-8 feet away from a garage door, block wall... Somewhere you can see the level of your headlights. Under your hood , their should be screws, 1 controls vertical movement, & 1 controls horizontal movement. Some cars have a bubble level.... either way, turn each screw slowly to your desired placement. Then adjust the other too match. there are other ways. Wall, Plus Distance, Plus Tape on Wall, Intersect light to tape on wall
Apr 18, 2014 | 2004 Mini Cooper
How do i fix my remote
Check it with fresh batteries. If batteries are weak, this might happen. If batteries are good, and still it does not give you distance range, the infrared emitting LED inside it is faulty. To replace it, you have to open the remote control. Check this link. http://electronicshelponline.blogspot.com/ It has details about how to repair a remote control. Pull up older posts. The fault can also be due to a faulty remote sensor inside the TV too. The sensor can be located just behind the infrared sensor window at the front of the TV. Will look somewhat like this.
Infrared LEDs [remote control]
Jun 12, 2013 | Televison & Video
Remote control won't work 10 feet away but if two feet away it works. What gives?
the remote uses light to send a signal to the tv. make sure there isn't anything interfering with the light signal. it could be dirty or the receiver could have dirt obstructing the light.
Mar 20, 2013 | Panasonic TC L42E50 - 42" VIERA E50 Series...
BOSE LIFESTYLE TV SENSOR PROBLEM
Usually on any equipment with a remote---if you hold remote real close and it works you have either a dirty lens for the receiver or a defective infrared receiver in the unit-----odd that moving things would cause this.
If it is only the on/off function having a issue--that would rule out both of the possible solutions I suggested.
Be sure batteries are new/good and no indirect light is hitting front of unit where receiver is located.
May 18, 2012 | Audio Players & Recorders
Cannot use remote control to switch on TV, but I can manual switch the TV. Guess the receiver board has problem.
Hello
If front panel contols are working and set does not works with its remote control, first check the remote control for its infrared emission. You can check it with the help of a cellphone set to camera option. Eventhough, human eye cannot detect the infrared rays, electronic cameras can. Just hold the remote control at about a feet away from the cellphone camera lens, and press each button on it. if there is any infrared radiation comes out of it, the cellphone camera will sense it, and you can get an image of it the screen. If it is there, still the TV does not respond to it, the infrared sensor inside the circuit board of your tV is faulty, and should be replaced with same typw and number. OK.
Jul 17, 2011 | Hitachi Televison & Video
Tv remote not working
Hello
Check the remote control for its infrared emission first. You can check it with the help of a cellphone with camera. Eventhough human eye cannot detect infrared rays, electronic cameras can. Put your cellphone to camera mode, place the remote control [ replace its batteries with new ones]; at about one feet away from the camera lens, and press each button on the remote control. If infrared emission is there, you can see its image on the cellphome camera screen. If there is infrared emission for all button press of remote control; the infrared sensor inside your TV is faulty. It should be replaced with same type and number. If there is no infrared images, the remote control is not working, and should be replaced. Check the battery contacts of the remote battery compartment for any rust or dirt. Clean it well before replacing new batteries into it. OK.
Jul 06, 2011 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
I have a sony Bravia KLV-S40A10E 4 years old.Remote controle device is no ore working. Batteries have been changed without solving the problem .. Other Remote device ( DVD-Sony ) is also not working...
Hello
You just check your remote control handset for its infrared emission. There is an infrared light emitting diode [LED], in front of your remote control handset from which infrared light rays are send to your TVs infrared sensor, fitted inside it, behind the infrared window on its front panel. Infrared rays are invisible to human eye. We can check if it is there by using a cellphone with camera option.
Put the cellphone in camera mode, and place your remote control's LED side towards its lens, for about a feet away or so, and when you push its each button, you can see an image in the phones' screen. If it is there, and still your TV don't work with remote control, TVs infrared sensor inside is faulty, and needs replacement.
If there is no infrared image from your remote control, you have to buy one new remote control. OK.
Dec 18, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Not able to program my remote for my new sanyo t.v. It will not blink tv after I touch setup .. seems there is no connection somewhere .. I just installed new batteries
Hello
You first check your remote control for its infrared lightup. Infrared rays comes from it infrared LED on its front end in invissible to us. It can be checked with a cellphone which has a camera option in it. Set the cellphone to camera mode. and place the remote control handset in front of its lens about one feet or so away from it, and press each button on it. For each button press, you can see the infrared image on the screen of the cellphone, if the remote contol works properly. Just press the setup key especially for this test, as you says it is not seem to work.
If there is infrared image gets on the camera screen for all button presses, and still your TV doesnt respond to it, your TVs infrared sensor has damaged, and should be replaced. If you want furthermore assistance, feel free to contact me through Fixya. OK.
Dec 06, 2010 | Televison & Video
Samsung LN-T4042H 40" LCD
This may not really be a solution to your problem, but here it goes. If you are not sitting a particular distance from your tv you will experience slight pixelation. I have this tv myself and I think it looks great. Now when I am sitting up close on a station that is broadcasting in 720p(which is pretty much every HD station) It looks only pretty good...I sit back and it is fantastic. The good rule of thumb is take the number or inches your TV is in yours and my case 40, divide by 10 and then multiply by 2...and that is the number of feet you should be for optimal viewing distance. So 8 feet, you would be surprised to see how sitting this magic number away makes a difference.
Feb 01, 2008 | Samsung LN-T4042H 40 in. LCD HDTV
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
