Question about Linksys Computers & Internet
How to Connect Cisco Router To Linksys Router ?
    Brigadier General:
  • Linksys Master
  • 414 Answers
Configure connected Cisco Port to Linksys Router
interface that connects to linksys router has to be configured with an ip address and made active
https://www.cisco.com/c/en/us/td/docs/routers/access/800M/software/800MSCG/routconf.html
then
a static route has to be set up to tell cisco that the linksys router ip address is on the port you connected it to .
https://www.cisco.com/c/en/us/support/docs/dial-access/floating-static-route/118263-technote-nexthop-00.html
Posted on Oct 10, 2019
SOURCE:
obededom99
  • 24 Answers
SOURCE: unable to connect 2 routers need help!
Do you have any funky subnets for your Cisco router? Do not connect the wireless router to your network yet, as it may have the same IP address as your other router.
Basically the easiest way to do this is to set a dedicated IP for the 2Wire router on the Cisoo router. Then make them stay on the same subnet, but give an IP range for your Cisco router, like 1-50 or something. If you give the 2Wire router IP .51 for instance, then give the Wifi users on the 2Wire IP range from .52-75 or something.
Make the 2Wire router only use wifi and not serve DHCP addresses. Then you setup the 2Wire router to get its info from the Cisco router.
I searched and there is no howto out there for doing this with a Cisco router. However, here is one I used to setup a similar scenario with a Netgear router. It worked. If you are able to translate a bit, it might work for you:
http://kbserver.netgear.com/inquira/default.asp?ui_mode=answer&prior_transaction_id=306896&action_code=5&highlight_info=16778323,235,239&turl=http%3A%2F%2Fkbserver.netgear.com%2Fkb_web_files%2Fn101236.asp&answer_id=6056802#__highlight
Here is another article:
http://kbserver.netgear.com/inquira/default.asp?ui_mode=answer&prior_transaction_id=306896&action_code=5&highlight_info=16777285,246,260&turl=http%3A%2F%2Fkbserver.netgear.com%2Fkb_web_files%2FN101496.asp&answer_id=6056800#__highlight
Let me know if you are able to work through this. You need to give the 2wire router a static IP and you need to NOT use it for wired connections, and not use it to serve DHCP settings.
Posted on Jan 21, 2009
  • 233 Answers
SOURCE: I have a cisco router linksys. I connect internet
If you can plug the cable that you have ran into your router into your computer directly and it works, then you can plug the router back in. Then connect the computer to the router via cable and unplug the router for about 15 seconds and plug it back in. If you connect the computer by cable directly and it doesn't work, then try unplugging your router for about 15 seconds and then plugging it in. I have found many networking items that need to be reset whenever a network cable is plugged in when the device is powered on.
Posted on Jun 08, 2009
router-user
  • 550 Answers
SOURCE: forgot password for wireless router
Are you speaking about the password of the router or the password of the wireless network ?
If you don't know the password of the router , then you will need to reset the router and use the default password of the router.
Once you reset the router, you will need to reconfigure it.
If you are looking for the wireless password, you can find it on the set up page of the router.
You will need to open the set up page of the router.
Click here for step by step instructions
Posted on Jul 22, 2010
  • 170 Answers
SOURCE: CANT ACCRS WIRELESS ROUTER WRT110 BY LINKSYS CISCO
Sounds like the router needs to be reset..
Before you do a reset try to login to the router by typing 192.168.1.1 in the webrowser ..
If that fails then look on the back or under the router and there is a reset button. Press and hold for 10 sec ... The let sit for a min or 2 then try logging into it..
Note: That the router will have to be setup again. Default login admin for the password .. don't enter any usernames
nkrcs
  • 94 Answers
SOURCE: no dial tone on cisco 504G phone
to use an Ethernet phone you will need a VOIP supplier ( You will need to Google this for the country you are in ) . You will not be able to use it until you have these set up. Ethernet phones are not like a standard home phone which use your local exchange to route your calls they use servers on the internet to do that and route your call to landlines.
I hope this helps if so please give me a thumbs up
Posted on Jul 23, 2010
Verizon dsl and cisco valet
Connect your computer directly to the Internet modem and make sure that you have Internet access directly from the modem.
If that is working properly then connect the modem to the Internet port on the router. Connect the computer to port 1 on the router.
Reset the router and configure it manually.
Here is link which will help you troubleshoot Cisco Valet M10 or M20 router
Mar 01, 2014 | Linksys by Cisco Cisco Valet Plus Wireless...
Have a linksys router trying to connect need default password or cisco password
By default, the router has a SSID ID of 'linksys', with *NO* security, and *NO* password. Configure the router to enable security, and to set the SSID and to set a password.
Sep 15, 2012 | Linksys E2500 Wireless Router - Ieee...
How to connect 2 cisco linksys E100
You can easily connect two linksys router for internet access.......here is simple example .....connect two linksys router for internet access
Sep 04, 2012 | Linksys Cisco WRT320N Wireless Kit
Help!!!!!!!!!!!
Leave the user name blank and enter the password admin ( admin once only ).
Try this.
If that doesn't work then search for the Cisco connect software on your main computer. You might have installed the cisco connect software on your main computer while installing your router.
If it is windows computer then cisco connect software might be under All Programs.
If is a MAC computer then cisco connect might be under Applications.
Open cisco connect software.
Click on router settings. You will see the router name and password. If you click on Advanced settings, it will open the setup page.
If nothing is working then you will need to reset the router and reconfigure it.
Remember once you reset the router, you will need to reconfigure it from the scratch.
Click to see more information about cisco connect software
Apr 12, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Can not get into e2000
Who is your Internet service provider?
If it is a DSL company then in some cases the router IP address may change to 192.168.0.1.
What happens when you try to open 192.168.1.1.
Does it ask you for user name and password?
Did you install router using cisco connect software?
go to router settings.
Click on Advanced settings.
It will open the setup page.
See Linksys E2000 router setup
Mar 05, 2012 | Cisco Linksys E2000 Advanced WirelessN...
When I try to access my cisco e1000 router on firefox or google it keeps saying that it is busy and will not connect
Are you trying to access the setup page of the router?
Did you install the Cisco connect software on your main computer?
If you have cisco connect software installed then open Cisco connect.
Go to Router settings. Click on Advanced settings. It will open the setup page of your router.
If the cisco connect is not installed then try to power cycle the router. Unplug the power to the router, wait for 30 seconds. Plug in the power cable. Wait for 30 seconds.
Now try to access the setup page.
If that is also not working then I will suggest you to reset the router and reconfigure it manually.
Watch video.
How to reset Linksys router.
Watch Video:
Linksys router setup
Feb 24, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Where do you get cisco connect
Cisco connect is the software that comes with the router.
You might have installed the Cisco connect software while installing your router for the first time.
Once you open the Cisco connect software for E1000, you will find the password to access the wireless network.
If you have not installed Cisco connect then you can open the setup page of the router and check the wireless settings.
Dec 17, 2011 | Linksys E1000 IEEE 80211bgn Wireless...
I lost y E1000'spassward and cannot access wireless connection
Have you installed Cisco connect software while setting up Your E1000 router?
If you have installed the Cisco connect then you will find all the settings there. If not then you can open the setup page of the router and check the wireless settings. Read Linksys E1000 Cisco connect
Nov 20, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Hello, I have a Linksys SRW2016 and 2048 switches with one cisco 1800 series router. I have successfully created two vlans on one switch and when i try to connect a trunk port to cisco router it...
Make sure that the frame encapsulation is set on the router to 802.1q on each of the sub-interfaces. You could also try fixing the speed and duplex on both the router and the switch in case there is a problem negotiating the speed and duplex.
Hope that helps!
Oct 04, 2010 | Linksys SRW2016 (745883562435) 16x1000...
How do i remove devices from the wrt54g v8.2 router
Step 1:
Launch Cisco Connect and select Computers and devices.
NOTE: To launch Cisco Connect on a Windows computer, go to Start > All Programs > Cisco Connect. To launch Cisco Connect on a Mac computer, navigate to the Applications folder in Go, and then start Cisco Connect. For detailed steps in launching Cisco Connect, click here.
From there select computers and devices you want to remove.
Sep 24, 2010 | Linksys Wireless-G WRT54G Router
Open Questions:
Linksys Router CUSTOMER service pHoNe:~{-1\84433O+2330-}nUmBeR USAas Linksys Router CUSTOMER service Number +1{\84433O-2330}Wireless Repair service center to resolve all Linksys Router tEcH SupPoRt pHoNe nUmBeR products. Linksys Router ROUTER is an American multinational company which was founded by Michael Linksys Router ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Linksys Router ROUTER support number, and selling of computer-related services and products. Linksys Router ROUTER Tech Support Phone Number Recently, Linksys Router ROUTER has been named the number Linksys Router ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, Linksys Router ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a Linksys Router ROUTER Service Tag or a Linksys Router ROUTER Get Linksys Router ROUTER Technical Support Phone Number and Customer Services. Linksys Router ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Oct 16, 2019 | Linksys Computers & Internet
Linksys Router tEcH SupPoRt pHoNe nUmBeR:~{-1\84433O+2330-} USadA Linksys Router ROUTER Tech Support Number +1{\844:*33O*2330}Wireless Repair service center to resolve all Linksys Router customer service phone Number products. Linksys Router ROUTER is an American multinational company which was founded by Michael Linksys Router ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Linksys Router ROUTER support number, and selling of computer-related services and products. Linksys Router ROUTER Tech Support Phone Number Recently, Linksys Router ROUTER has been named the number Linksys Router ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, Linksys Router ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a Linksys Router ROUTER Service Tag or a Linksys Router ROUTER Get Linksys Router ROUTER Technical Support Phone Number and Customer Services. Linksys Router ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Computers & Internet Logo
14 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
