Question about Lanier Office Equipment & Supplies
MY LANIER LDD130 IS TELLING ME TO REPLACE INK TO THE DRUM. WHEN i DID I NOTICED THE INK BOX WASN'T EMPTY. I TRIED PUTTING TWO BRAND NEW BOXES OF INK IN IT AND IT KEEPS SAYING THE SAME THING.
SOURCE:
  • 1019 Answers
SOURCE: ink in hp photosmart 3310
the printer should have software installed enabling you to opt, for a printer-ink cartridge change.
If the cartridge has a chip fitted, it may be discharged.
The chip is supposed to be charged up, for the printer to recognise the newly installed cartridge.
view your settings in control panel/printer/properties to see what options you have available.
Mike @ Compurepair.
Posted on Jul 23, 2008
efs_perpends
  • 1996 Answers
SOURCE: ink empty-not!
You may have to reinsert the new cartridges, making sure to follow the machine prompts and press the up arrow key or 1 or + for each color cartridge you install. (See directions here. and here) Make sure the lock levers click when you insert the cartridge.
If you continue to have problems, see other support pages for your printer here and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Aug 05, 2009
  • 3 Answers
SOURCE: sx100 printer replaced black ink
Similar problem, originally posted this as a solution elsewhere
Heya, heres my own theory on why this doesnt work. I've encountered thesame problem with my printer. Read article on my blog. Let me knowabout your views through comments.
http://sweetboredom.com/?p=115
Posted on Nov 10, 2009
cns assoc
  • 677 Answers
SOURCE: my epson rx595 keeps saying replace ink cartridges
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Mar 23, 2010
  • 67 Answers
SOURCE: I have replaced ink cartridge that was low but it
Press the left arrow and the setup button together..
You will find Support Menu.. press the arrow key to come to Prit test menu.. click ok on that ..
now, press the arrow button to choose Nozzle test..
even after that if it continues to show the error, and if you are not able to print anything from the computer..
You may try by doing a L2 uninstall and then reinstall ..
Posted on Aug 12, 2010
SAVIN C7570 BLACK INK PRINTS FADED (INCONSISTENT)
Hi Linda
Is this ink or toner? Ink will expire if it is on a shelf too long. Toner is a powder that is applied with heat to the paper. It does not expire but will appear faded if the printer is in economy mode or low on toner. on a 4 drum system each drum is independent of the others and can run low or out at separate times. Therefor to save money only replace the empty drums. Have you changed the drum recently? If it is toner try removing it and shaking it, then reinsert it. If you have other boxes of this drum see if you can find a date on the box. ink over three years old may not work well.
Apr 28, 2014 | Savin Lanier Ld275c Lp138c C7570 4 Drum...
Selphy cp780 continues to say ink cartridge empty even after installing new one. Tried 2 new ones to be certain it wasn't the cartridge, same thing...tells me ink cartridge empty install new.
try and reset your printer,unplug the power cord and wait 10 min, then plug back in,understand that Canon has installed a chip so you cannot use refilled cartridges,or cartridges you refill,if this doesn't work,then contact Canon,and you could get the same message I got take it in to be repaired, (to costly), so I end up buying a new one,,
Oct 10, 2012 | Canon SELPHY CP780 COMPACT PHOTO...
I have changed the empty ink cartridges but each time I try to print, it tells me that they are empty and to go to hp.com/recycle. Again, the ink cartridges are brand new. I was able to go to the...
Are you sure catridges are brand new? check any where ink is leaking? if its leaking try to arrest it or replace ink tube assm.Dont try to clean print heads every time it will consumes ink...
Sep 07, 2011 | HP Photosmart C6180 All-In-One InkJet...
My lanier is making dark copies
One of the most common reasons for a Lanier 5222 or 5227 to make dark copies is a problem with the drum unit or developer. Fortunately on those machines, the drum unit and developer are all self-contained in one easily-replacable unit, called the PCU (photoconductor).
If you don't have a new PCU handy, you can order one from the same company you get your toner from. The PCU should generally be replaced every 60,000 copies, but sometimes it may need to be replaced sooner (especially if you run a lot of dark copies or make a lot of copies of images) and it can often run longer than 60,000.
Replacing the PCU is easy -- it sits right next to the toner bottle, and all you have to do is slide the old PCU out and slide the new PCU in (once you remove all of the tape and other trappings from it). Instructions will be included in the box with the new PCU.
Please rate the effectiveness of this solution. Thank you!
Oct 10, 2010 | Lanier 5222/27 Laser Printer
Installed a new Lexmark ink cart and got an incorrect message
take out the cartridge , turn off your printer and take out all the cables behind your printer and wait for 5 minutes and put everything back in.. if the same error shows.. im sorry but your printer needs to be replaced.
Aug 15, 2009 | Lexmark X2500 All-In-One InkJet Printer
HP 2840, black ink drum q3964a
Hello, these printers tend to be finicky.
In other words, just replace the black toner. When the printer says its low, or empty, regardless of wether or not it is, just replace it.
Replacing the drum, when it says black toner needs to be replaced will do nothing to rectify the issue.
Buy only HP Toner and Drum cartridges for this printer. Do not try to refill toner cartridges, and do not reset drum. You will only end up destroying your printer in the process.
Feb 26, 2009 | HP LaserJet 2840 All-In-One Printer
Ink was low I put a new cartridge in still says low wont print.
Hi
try reinstalling the ink. if all fails call epson for replacement ink at 562 276 1300
Jan 02, 2009 | Epson Stylus 2200 InkJet Photo Printer
Epson STYLUS CX3900 All-In-One... Problem:
check in the printer driver properties to see which cart isn't recognising, usually it is a faulty or empty cartridge but can also be a faulty logic board or ink cartige board especially if ink has been spilled inside machine.
I have seen faulty brand new cartridges out of the box.
if another known good cartridge doesn't fix it take it in for service.
May 09, 2008 | Epson STYLUS CX3900 All-In-One InkJet...
20 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
gggg
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
