Question about Cameras
My chart has stoped zooming in fully on 2 units
  • Cameras Master
  • 6,098 Answers
Well, now, there's a thing. Care to vouchsafe further information about the equipment, or shall we play twenty questions ?
Posted on Oct 10, 2019
SOURCE:
My lowrance elite 5 hdi won't go past the "elite lowrance" screen when you turn it on. Its only 2 weeks old!?
Make sure that your battery is fully charged. Try a hard reset if it still won't start up.
This will erase all user information on the device, so you will have to set it up again.
With the unit off, press and hold the zoom in (+) zoom out (-) and power buttons. Release the buttons when the map displays.
Article Details
Jul 19, 2014 | GPS
How do you reset the lms334c?
Hi, continually hold down the zoom in and zoom out buttons while you turn the unit on, keep holding them down until the screen fully loads. Regards Phil.
Jul 07, 2012 | Lowrance Lms332c Lms334c (Lowrance)
Need fuse boxs Diagrams or chart for 2003 Mercedes Benz C320
http://www.google.com/imgres?um=1&hl=en&sa=N&biw=1440&bih=716&tbm=isch&tbnid=y4pGKcdF8Pm7HM:&imgrefurl=http://mercedesforum.com/forum/mercedes-c-class-10/c240-fuse-map-please-33057/&docid=alzpd6Coz9btVM&imgurl=http://i724.photobucket.com/albums/ww243/kristastjames/fuse1.jpg&w=744&h=1023&ei=64XuT5KrNafs0gGnqtT6Ag&zoom=1&iact=hc&vpx=555&vpy=223&dur=710&hovh=263&hovw=191&tx=105&ty=156&sig=110991140176858162707&page=2&tbnh=166&tbnw=121&start=18&ndsp=24&ved=1t:429,r:2,s:18,i:140
Jun 30, 2012 | Cars & Trucks
Beep sound, key tone and fish alarm sound, was suddenly changed to very small as hard to hear. The sound menu makes no change. It seems that the sound period is very short. I have once changed the sound...
Hi Toshio, I have the same unit and I am not aware of a sound period adjustment. The unit most likely needs a hard reset because of a software glitch. To do this hold down the zoom in and zoom out buttons while turning the unit on. Keep holding both zoom buttons until the start up screen is completely loaded. This procedure returns the unit to its factory settings and should solve your issue. Regards Phil.
Sep 24, 2011 | Lowrance HDS 5 Fishfinder GPS Chart...
Nikon Coolpix 5700 Over-exposure of image whilst zooming in brigh
I now have the exact same issue. When not zoomed or fully zoomed the exposure is correct, however when partially zoomed the aperture does not engage and stays fully open. So basically I cannot really use the zoom or the picture is over exposed. Note - actually about 2/3 mechanical zoom and on works, so I can use a bit of the zoom.
Suggestions?
Sep 20, 2009 | Nikon Coolpix 5700 Digital Camera
Lcs-20c GPS slow with HotMaps Premium 09 card
Does the image come back by itself if you slow down or stop and wait? If not, make sure you are not leaving the coverage area of the chart you are set to. In the LCX-20, that Navionics chart is split up into several sections, if you have one section selected and are on the border and then leave that area, the map usually goes all white depending on your zoom level. If you are on a border like that you will have to learn to quickly switch the charts from the MAP DATA menu.
If the map does catch up when you slow or stop, and just can't redraw fast enough...
Make sure the LCX-20 has the latest updates which can be downloaded from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
These updates often add additional Navionics support.
Most likely though, this is just going to be the way it is with that particular map and the LCX-20. If you zoom out it will be much much better. So if updating doesn't help, zoom out. Experiment to see how close you can be zoomed in while running above 20mph. If you can get a good zoom level to where the map can keep up and you can still see the information you need then you should be good to go. If not, use the LakeMaster card or go get a different mapping option...or upgrade your display unit.
Jun 24, 2009 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
OLYMPUS DIGITAL ALL WEATHER
1) Make sure that the batteries are in good condition
2) Check and clean any dirt or corrosion from the battery terminals.
If the power supply voltage suddenly drops during initialization,
or when the lens is trying to extend itself, it could produce this
kind of error.
3) Make sure that the lens extension tubes are not mechanically
jammed.
4) Remove the batteries, turn the unit ON and wait for it to fully
discharge any internal capacitors, then put the batteries back
and try to turn the unit back on. This should fully RESET the
internal CPU.
Generally this kind of error means that the camera's internal
computer is trying to activate the lens zooming motors, but
the motors fail to move as expected.
Other causes could be:
a) burned out ZOOM motors
b) burned out motor drive circuitry
c) bad motor positioning sensor
d) defective computer components
e) failed internal firm-ware.
none of these cause are user fixable.
Hope this helps
Martin
Nov 10, 2008 | Olympus Stylus 700 / 700 Digital Camera
Card is locked and my zoom in and out button stoped working
Hello, I'm sorry, my PC power went OFF and I lost contact in chat yet I will assist you here.
Aug 13, 2008 | Canon PowerShot A720 IS Digital Camera
How do you get the gps to show depth and markers on the water?
It depends on what model you have. Most chartplotters require a chip with regional chart data. Most Lowrance models use Navionics charts. If you have a chip in the GPS, go to the map screen and press the "menu" key. Somewhere in the map setup menu will be a field where you can specify which chart to display.
For example a Navionics gold chart may cover the entire east coast, but it is broken down into a few sub regions. If you are boating in New England you would select the sub region labeled Northeast. Some of the earlier models didn't name the regions, they used model number for each region such as "XL904G". In that case your best bet is to try each one until you can view the charts in your area. Zoom in to 1/2 mile scale to make sure you can see charts.
If you have done all that and still can't see the chart details, there is also a setting in the map setup menu that allows you to set the level of detail. Make sure it is set to normal, more, or most. If you see a declutter setting on the setup menu, try setting it to off.
Jul 21, 2008 | Lowrance GPS
Raymarine RL70CRC GPSRadar
Hi Matt,
There is a feature in these chartplotters called "Plotter Mode" that is often misunderstood and causes the exact problem you describe.
Press menu.....chart setup.....and scroll to the bottom until you see Plotter Mode in the list of options. It should be set in the OFF position.
If you have more than one display networked onboard check the setting in each one invividually.
What Plotter Mode does is allows the chartplotter system to access range scales not supported on the chart. It is not normally used for map-based navigation but more so for chartless electronic plotting (it can display routes, waypoints and track-recorder breadcrumbs.) open-ocean cruising, or for ultra-precise GPS operations (like a precision anchor drop, finding a very specific location etc. When plotter mode is on you can zoom in to a very, very small working area. The indicator it is enable is the cross-hatch background on the screen, the lack of map information, and the NO CHART DATA watermark on the screen.
Jul 30, 2007 | Raymarine RL70CRC GPS Receiver
Cameras Logo
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
