Question about HP Office Equipment & Supplies
Replacing cartridge for HP printer office Jet Pro 6978
SOURCE:
  • 25 Answers
SOURCE: Paper jam in HP 4255 office jet all in one printer
Clearing paper jams
Paper jams can be real or false. The unit may report a paper jam even when there is no jammed paper. The solution to a real paper jam or a false paper jam is the same.
CAUTION:
Jammed paper must be removed using the rear access door with the power cord disconnected to avoid mechanical damage. Do not remove jammed paper from the front of the unit.
  1. Turn off the HP product and turn it around so the back of the unit faces you.
  2. Disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the paper feed rollers to turn freely.
  3. Locate and open the rear access door by pressing in on the left side tab and then pulling the door toward you.
Figure 2: Removing the rear access door
  1. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to Buy on this page to order replacement parts.
  2. From the rear access door opening, remove the jammed paper.
  3. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  4. Reinstall the rear access door.
  5. Reconnect the power cord to the unit and turn the unit on.
Preventing paper jams
The following information will help prevent paper jams from occurring:
  • Never use paper that is torn or wrinkled.
  • If you are having problems using paper that has already been printed on once (recycling), replace it with new paper.
  • Remove and then reinstall the rear access door. Verify that the access door is fully locked in place. The paper can skew if the rear access door is not locked.
  • Every six months to one year, clean the paper feed rollers with a rag lightly moistened with water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
  • When printing envelopes, tuck the flap into the envelope and crease the folds before printing.
Posted on Jul 08, 2008
  • 14 Answers
SOURCE: Office Jet pro L7500 paper jam - how to open printer?
hi!!! in your case my advise to you is to open the duplexer located at the back of the printer and look if there's a stock paper or any material that can cause paper jam to your printer.
Posted on May 18, 2009
  • 6 Answers
SOURCE: hp 6500 office jet refill
to refill 920:
1. If you have the plastic cap that covers the 9 mm. hole where you can see the sponge, then tape this cap to the cartidge with scotch tape. If not, use some duct/masking tape to cover the round hole.
2. Use the dry hypodermic needle to find the hole that will be found at the very center of the 920 label. With the needle, pierce the label.
3. Fill the hypodermic needle with 4 cc of ink.
4. Insert the needle 2-3 cm. into the hole made in step 2. Draw out 1 cc of air, then slowly force the 4 cc of ink into the sponge. Use toilet tissue to absorb any ink that might have escaped.
5. Let the catridge stand overnight (if possible) so as to allow the ink to evenly saturate the sponge. If not, insert it into your printer immediately.
Note: If you are going to refill catridges, be certain not to allow the sponge to dry completely. Thus, you might want to do step one immediately and to enclose it in a sealed sandwich bag upon removing an empty catridge from your printer even if you are not going to fill it immediately.
www.catherinecollege.net
Posted on Aug 12, 2009
  • 6 Answers
SOURCE: hp 920 xl ink cartridge filling instructions anyone have them
to refill 920:
SOURCE: hp office jet j5780 cartridge error: cartridge on right must be replaced
Switch off, Remove catridge and Clean any leakage in the printer.
Clean the catridge with saliva if u do not have any cleaning liquide. Put the catridges back switch on and you are there. My hardware officer just tried it this morning and it worked like magic.
Note make sure all leakages are removed.
Posted on Jan 13, 2010
How do I replace the yellow ink cartridge?
Open up the Panel It has the writing HP office jet pro Etc. on it, then the cartridge/head will move toward you, push in on the yellow cartridge until it clicks and release it will disengage and you can remove old cartridge.
Installation is exactly like removal insert new cartridge until it clicks release and it will engage.
Close panel and the cartridge/head will move back to previous position
Jun 02, 2015 | HP Officejet Pro 8600
Printhead has a problem HP Office Jet Pro L7590
I suggest you go to the HP support website and see what assistance you can get for this model.
Start by downloading HP Assistant
Oct 06, 2017 | HP Office Equipment & Supplies
I have an HP L7680 Officer Jet Pro All-in-one. It is telling me that the toner is low? I can change the Ink carteidges no problem but how do i change and where do i buy Toner?
According to the HP L7680 this is an inkjet printer and therefore does not use a toner cartridge.
Toner cartridges are used in laser printers and there are no printers on the market that are both an inkjet and a laser printer.
Apr 26, 2011 | HP Officejet Pro L7680 All-In-One Printer
How do I change the ink cartdrige in the HP Officejet Pro
Please CLICK HERE to find the instructions on replacing the ink cartridges
Regards
Riztech
Aug 18, 2010 | HP J4680 Office Jet All-In-One Printer
I have an hp officejet pro l7600
I have an OJ l7600, and the colored ink cartridges pod out on their holdings rendering the printer inoperable. I have tried replacing the cartridges,even though there was ink still available. Even with new cartridges this still happens. What gives?
Jan 20, 2010 | HP Officejet Pro L7680 All-In-One Printer
Where is the ink cartridge located on the HP office jet 6110 prin
if you are to lift the top part of your printer you will see the cartridges inside as shown below:
Lifting the scanner bed exposes the entire paper path and gives your hands plenty of space to replace ink or clear paper jams.
Apr 11, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Open Questions:
HP Wireless Printer Tech Support pHoNe%%[+l26O{0O64}^]:~%%NumbER Wngjsery HP Wireless Printer TeCh SuPpOrT Number +[185526O{0O64}]WngLogin HP Wireless Printer customer service phone Number Repair service center to resolve all HP Wireless Printer products. HP Wireless Printer is an American multinational company which was founded by Michael HP Wireless Printer using its company headquarters in Round Rock, United States of America. Contact HP Wireless Printer for Setup & Installation HP Wireless Printer Setup Free & Installation HP Wireless Printer TECH FREE number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for HP Wireless Printer Connect, HP Wireless Printer TECH Free Phone Number you'll be searching out HP Wireless Printer Connect setup as well. So, here we're with all cthe setup process and for your to HP Wireless Printer Connect. Get HP Wireless Printer Setup Instant Free HP Wireless Printer TECH FREE Phone Number Usually, the setup TECHnique takes a number of time. One TECHnique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may locate the approaches simplified tdako help you even if you aren't TECH-savvy. Let us undergo the method of HP Wireless Printer Connect setup for Windows and for Mac. So, right here we go vikki TALATUMAS
Oct 19, 2019 | HP Office Equipment & Supplies
16 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
