Question about LG WFT1071TP Top Load Washer
LG WFT1391TP TOP LOADER WASHER PROBLEM
THIS MACHINE IS 6 MONTHS OLD. I THINK SOMEONE MAY HAVE PRESSED BUTTONS (KIDS) AND NOW THE MEMORY IS SCRAMBLED.
WHEN I SELECT THE FAVOURITE WASH, IT USUALLY JUST POURS IN THE WATER WITHOUT THE DRUM MOVING. NOW IT POURS IN WATER AND THE DRUM IS SPINNING, AND THE WHOLE DRUM GOES OFF BALANCE.
I WANT TO CANCELL THE FUNCTIONS AND RESET THEM, BUT CANNOT FIND MY BOOKLET.
PLEASE HELP !
  • 25 Answers
Use stick to hit the kids - the booklet will leave them with the feeling they haven't been punished
Posted on Dec 12, 2007
How to set up favourites on foxtel
  1. Press the active button .
  2. Select setup.
  3. Select favourite channels.
  4. Highlight the channel then press the yellow button and an F symbol will appear next to the channel name. ...
  5. Press select to save your favourites.
How to set up my favourite channels on iq3
https://electronicshelponline.blogspot.com/
Aug 12, 2018 | Televison & Video
How to clear error code SC302, Dsm615 nashuatec
Yes, mine were successfully RESET from the error code SC:552 and SC:302. Machines runs good, but i about to wander what could be faulty inside, it took one month after error code 302 exist. Mine was exactly DSM615 same model same error code 302 (this is really 302) which resolved by reset. Hopefully machine will run good for two months.
To RESET it
1. Press Yellow button
2. Press 1, 0, 7
3. Hold Orange button for 3 seconds
4. Select MODE 5
5. Select Clear Memory (or something like it) (801)
6. Select 002-Engine
7. Select EXECUTE
8. Turn the switch off and leave it for a minute
9. Turn back machine On.
10. Done, or else there could possibly something else.
Good Luck....
Thanks for using Fixya.
Mar 04, 2013 | Office Equipment & Supplies
Maytag maxima door locked
Similar problem here - pump was set for a 58 minute normal cycle, I look in and see it is now showing 67. Hmm. Attempt to shut it off because it is just sitting there pumping and pumping. Power shuts off but pump keeps running and add garment light flashing red. Cannot open door (to add garment or not) Unplug the unit and the door will not open. Anybody got a clue what's up? I have a wash in, service is closed due to a storm today. Just bugs me that it is 6 months old and seems to act up a fair bit electronically.
Dec 09, 2011 | Maytag Washing Machines
How do I clean my washing machine? My clothes and the washer have a mildew odor.
Add the entire packet of "TIDE WASHING MACHINE CLEANER" directly into the tub (no laundry) and close the door.
Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent usage.
After this--use the correct amount of "HE" detergent & perform a "TUB CLEAN" cycle every (4) months using the *tub clean* option on the control panel.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 18, 2011 | LG WM-2277HW Front Load Washer
I have a whirlpool awm 8121 6th sense front loader. when i select the cycle, usually rapid, and press the start button the machine commences to fill with water. when it comes time for the actual washing...
If your machine is reasonably old, perhaps take a look at the bushes of the motor . Before that, take the manual and run the test cycles by following the instructions; it might provide you with answers
Oct 14, 2017 | Whirlpool AWM8123 Front Load Washer
I have a fisher & paykel aqua smart WL26CW1. I just replaced the module. I am now getting an error code of 9. What does that mean?
Hi dear.That's related to size error.When you replace the motor control module you need to set the machine wash capacity like:5Kg or 7.5Kg.To do that please follow the steps: Phase 1 to 6 Size Switch Error
The Display size switch setting does not match that stored in the memory.IW machines, Phase 5 and 6
To access Size Setting Mode. Push and hold the Fabric care button and then press the Power button to enter Size Setting mode. Select the correct size on the display by pushing the White button next to the correct size (phase 5) or using the Adjust button to highlight the right size (phase 6). Size setting is then achieved by pressing the Power button. Powering off will set the size into the memory. Check the size is set before starting a cycle.
I hope that helps.Thanks.
Sep 03, 2010 | Fisher and Paykel WL26CW1 Top Load Washer
Hotpoint aquarius washer dryer wd63 1100 spin - my fuse went just as i was switching the machine on - so the door locked and wont open - changed the fuse, door was still locked so thought id let the wash...
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Wand won't release
Quoting from page 6 of the manual:
"Select the radio band and tune in a desired radio station you wish to store in the preset memory.
Press and hold, for at least 2 seconds, any one of the preset buttons (1 through 6) that you want to store the station on. The selected station is stored. The display shows the band, preset number and station frequency memorized. A total of 18 stations can be stored in the preset memory (6 stations for each band; FM1, FM2 and AM). If you store a station in a preset memory which already has a station, the current station will be cleared and replaced with the new station."
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=934dc6a1672f80b9d320c470df81f04d&q=Alpine+CDE-9842
Feb 25, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
CL on display panel - washing machine will not respond
CL stands for child lock to take it off press and hold TEMP and TIME DELAY at the same time and this should remove it
Dec 11, 2007 | Washing Machines
LG WFT1071TP Top Load Washer Logo
176 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
