Question about RCA F32450 32" TV
An Annoying High Pitch Sound
I have A RCA Television, In the last month or so there has been a "High Pitch" comming from the TV it can be annoying, It can last from 1 second to all 4 hours then stop . and stat up again or it will not do it all day then when i turn the TV back there it is again. I Have A great Picture and sound but that annoying only a dog should hear high pitch sound is there. Please someone tell what the problem is ?
  • 3 more comments
  • loran25 Dec 12, 2007
    I have an RCA model 20F510TD with the same problem. I have to turn the tv off when it starts because the noise is so shrill.
  • alyy Dec 28, 2007
    tv will not turn on but when plugged in , it will make a high pitch sound
  • jay11780 Jan 18, 2008
    I have a 52 inch hdtv RCA tv. When I first turn it on there is no high pitch noise, but then the high pitch sound will start. At first it would only last for a little while. Now it just stays on my TV is only 2 and a half years old. what could be causing this problem.
  • shrb Jun 01, 2008
    I have the same problem with my RCA tv it has a high pitched sound when I turn it on and the tv will not come on.
    What did you do to get your tv working properly?
  • Anonymous Jul 05, 2008
    My RCA tv does the same thing. As soon as the tv gets good and warmed up, the high pitched sound starts. My husband does not hear it. I am going to call a repairman for free advice, but will probably just by a new one.
I have the same problem. Mine seems to deal with the brightness of the screen. I turned down the brightness and it got better. It still makes the noise and I am going to take it in to see if it can be fixed. I just don't want to do with out my TV - Isn't that horrible.
Posted on Feb 04, 2008
    Genius:
  • 1,694 Answers
Can be either noisey yoke or noisey flyback transformer........T.
Posted on Dec 13, 2007
Posted on Sep 12, 2008
RCA HD52W59 makes a high pitch internal squeal sound
coil LL0037 resolder then with a glue gun glue top of coil and down.OR replace coil.
Feb 17, 2009 | RCA HD52W59 HDTV Projection Television
I have got a polaroid flat screen tv. model no. polaroid TLU 03711C. I have had this tv for less than a year, and it is still under warranty just. however over the last 4 months or so, when i first turn...
I had the same problem - It was due to these two tiny devices called "capacitors" which had blown. I replaced them (it only cost me £1!) and was really easy.
I wrote a guide on how to change the capacitors, there are pictures an d the guide is easy to follow. You can print, download or view the guide here - http://www.scribd.com/doc/13515584/Polaroid-TLU03711C-Replace-Capacitors-Guide
Oct 16, 2008 | Televison & Video
Rca hd52w59
ok does the set show a picture durring this whinning
i have ran into this problems .. sometimes it has to do with a coil that is oscillating...ll037 or ll029...the fix for this is simple if it is the problem. dampen the coil with silicon.
Mar 26, 2008 | RCA HD52W59 HDTV Projection Television
High pitch sound from the speakers
Is the noise present even when there is no input?
Jan 27, 2008 | Olevia LT32HVE 32 in. LCD Television
RCA D52W19 52 in. Rear
open it up and see if any liquid is spilled on the boards, most squeals are from the high voltage transformer and or splitter
Jan 17, 2008 | RCA D52W19 52" Rear Projection Television
Sound problem
sounds like a fan issue that would be myfirst guess
Mar 21, 2007 | LG RZ-37LZ30 37 in. LCD Television
High pitch sound for Sony FD Trinitron WEGA KV-27HS420 27" TV
The high pitch squeal you hear is usually caused by a coil vibrating, normally in the horizontal circuit. I've also seen the ferrite bead on the horizontal output transistor do this, but, it is rare. I normally will repair this by finding the coil and "tightening" it. To tighten a coil, technicians use different chemicals, such as, a hot glue gun, rubber silicone or even finger nail polish. I will find the coil that screams by starting with the usual suspects and using a wooden dowel, barely touch the coil and if the pitch of the noise changes, then, thats the coil that needs repaired. If you do not know your way around the inside of a television, I never recommend you do so, since, this procedure must be done with the set turned on and you poke your hands around the inside of the set by the high voltage circuit. Hope this helps your decision.
Mar 04, 2007 | Sony FD Trinitron WEGA KV-27HS420 27" TV
High pitch noise..from TV
Feb 28, 2007 | RCA P46924 46" Rear Projection Television
High pitch noise when tv warms up
High pitch noise is created mostly by a Coil or a transformer,is not easy finding the source if you are not familiar with this type of coil since there many sizes and shapes,the set needs to be on while trying to find wich part is doing it SO if you dont know where and how better call a Technician and you will be safe.
Sep 12, 2006 | Philips 55P8241 55" Rear Projection...
RCA F32450 32" TV Logo
1,524 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
