How can I hook up my Toshiba DVD/VCR player?
Hello:
How can I hook up my Toshiba DVD player/VCR recorder to my Sony DVD/VCR recorder. Someone has hooked these up for us, but we cannot record on the VCR. He has the Toshiba hooked up to Line 1 on the Sony, as there aren't any more free connections on the TV.
Could you please tell me the proper procedure to correct this problem?
Thank you for your help.
SOURCE: Toshiba D-VR650KU vcr/dvd video recorder
I talked to some very nice people at tech support 1-866-583-7353 and found out that my satellite reciever must be set to 480i, which of course is a pain since like I wanted High Definition. The composite a/v cables (red, white,yellow) are not high def and are part of the reason. I have TiVo and when recording a movie from TiVo to the DVD it states there as well to set the reciever at 480i. Once I did this I was able to record from the Sat to the DVD. I did a quick review and I couldn't find a combo set or just a dvd recorder that has component video cable (red,blue,green) or HDMI inputs at all, I'm thinking that all would have to be recorded at 480i.
Posted on Dec 22, 2007
  • 142 Answers
SOURCE: dvd/vcr without cable hook-up
If ** cable TV hookups exists, then the only inputs you can use are the line-in along with audio left/right. You've probably got a slew of output connections. Your unit does **t contain a tuner (which would allow you to use a cable input). You need to have a cable box or other device (vcr/tv) that has outputs compatible with the input of your dvd/vcr. A lot of dvd/vcrs are that way. It actually saves you some $$ since most cable boxes (especially HDTV compatible) already have the required outputs on them.
Posted on Mar 10, 2008
SOURCE: hook up
Purchased a rf modulator and hooked in to the tuner out to modulator and from modulator to tv that made everything work
Posted on Apr 13, 2008
VOTIT
  • 2071 Answers
SOURCE: Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Posted on Jul 16, 2008
SOURCE: How to Record TV Programs w/o Cable Box/Satellite Receiver?
if there are rca ports on the front of the vcr which are output, connect those to the tv input 3, the input to input connection is definitely not going to work...
Posted on Aug 05, 2008
Sorry it is D-VR610 made by toshiba
I think that the tape is copy protected, I remember this error.
Sep 27, 2016 | Sony Televison & Video
How do you find a dvd recorder that does not need and external tuner? Does the new tv's have a tuner that you can use with the current dvd recorders
U have cables or satallites tvs services hook up.U can record VHS tapes and used any DVD/VCR recorder machines hook up.Because the pay services does convert the signal back to analoge tv signal so u can record VHS tapes.
May 12, 2011 | Toshiba DVR620 DVD Recorder/VCR
How do I hook up my vcr to my dvd recorder so I
You will need one RCA video cable it will have a yellow, red and white plugs. On the back of your VCR locate where the color inputs are find where it says VIDEO OUT hook it up there. On the back of the DVD Recorder look for the same color input jacks NOW find where it says VIDEO IN hook it up there. You may have to turn on your TV,DVD recorder and VCR to get the right channel. your Recorder may have one or more video inputs if it does turn on all three. Use the channel on your TV you use to watch DVDs make sure you see your DVD screen. Now to record to a DVD. Change the channel on the DVD Recorder. Look for the input channels It may be Video 1 Video 2 etc... depends on the inputs you have. ( A great way to tune your DVD Recorder is to play a prerorded VCR tape. Turn the channel on your DVD Recorder unil you see the prereorded tape playing. )
Jul 21, 2009 | Toshiba Audio Players & Recorders
Need an RCA Adapter for a TOSHIBA D-VR610KU
If the RF Modulator will convert a coaxial signal to an RCA output signal, fine however, you still need a tuner to select the channel on the TV you want to record. This unit is primarily for dubbing or copying DVD to VCR or VCR to DVD. There is no tuner in the unit to get the cable signal. Try hooking up an additional VCR, that probably has a tuner in it and use the RCA out of the 2nd unit to the RCA in of the Toshiba. Hook the coax to the input coax jack of the 2nd then RCA out to RCA in of the Toshiba. Choose what channell you want to record on the 2nd unit. You may have to choose Auxillary mode on the toshiba the press instant record on the Toshiba. Again, this unit is a Player or Dubber. Not designed to record TV shows without an external tuner. I hope this helps. If you use a 2nd VCR just to get the TV Signal, you won't need the modulator.
Jan 21, 2009 | Toshiba DVR610 DVD Recorder/VCR
Recording with comcast hd box and toshiba VCR/DVD
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
Jan 17, 2009 | Toshiba DVR610 DVD Recorder/VCR
Hooking a vcr player to toshiba rd-xs35su
hi, connect it via a scart lead and switch to av channel.
Jan 13, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Can't get VCR to record
You may have to push the channel buttons on the source and check the video unit until you see whats playing on the main unit once you have a picture comming thru you should be able to record. if not let me know we can figure out some other solutions to get you up and recording.
Dec 14, 2007 | Toshiba SDV395 DVD Player/VCR
Televison & Video Logo
275 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
