Washing Machines Logo
Annette Posted on Oct 09, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an LG front load washer. At first it wasn’t spinning at all so I replaced the door lock mechanism. While it now does spin it doesn’t spin fast and the clothes are still soaked. I tried the diagnostics test and am getting a bE error code. Trying to figure out how to resolve this issue. Can you pls advise? Thanks in advance.
robert
Level 3:
  • LG Master 2,548 Answers
  • Posted on Oct 10, 2019
robert
LG Master
Level 3:
Answers
2548
Questions
0
Helped
869967
Points
8043
Are you sure it isn't a "tE" error code? A common error. It can cause your type of symptoms.
5 Related Answers
Anonymous
  • Posted on Dec 23, 2007
SOURCE: Doesn't spin the clothes dry on the final spin but spins at high revolutions without a load of clothes
I have read that if the pump is not draining the tub completely, there is an interlock that prevents the high speed spin from engagin. I have had debris caught in my pump several times (kids!!) with similar issues. There is a trap on the line leading from the tub to the pump which is "supposed" to capture debris, but it doesn't work all that well. Check your pump.....
Anonymous
  • Posted on Jan 08, 2009
SOURCE: LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Chris Goulet
  • 41 Answers
  • Posted on May 14, 2009
SOURCE: Kenmore 417. 4405200 Front Load Washer error code E43
It's a bad wax motor inside the door latch. The diagnostics are buggy and do not test it properly. It should measure about 1.5K ohms, and when 120 VAC is applied to it, it should extend in about a minute. Part number 12002535 is $10 to $15.
Anonymous
  • 6784 Answers
  • Posted on Nov 29, 2009
SOURCE: LTF2940ES3--Washer drains, but will not do a final spin.
Hi. You have done a great job diagnosing your unit. This unit is designed to not allow a full scaled spin out, if there are issues with the on-board door lock mechanism. This is standard safety equipment for most units. Once this damaged door lock mechanism is replaced, the washer will operate properly. The full scaled spin out will return.
Testimonial: "Big help! Thanks a lot!"
Anonymous
  • Posted on Dec 02, 2009
SOURCE: Frigidaire Front Load Washer won't Spin
i fixed mine about 5 times and its always some thing diffrent.
try buyng the inexpencive parts first and leave for last the electronic control panel.
it could be that your washing a smaller amount than the recomended.
Take it to a profesional. dont do like me a DIY guy. Some times i need to take pictures when taking the monster appart and then because they are somany screws missing duct tape, rope or hangerwire becomes usefull.
All mechanics are wise guys you and me are thevictims.
1helpful
2answers
How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin | eHow.com http://www.ehow.com/how_6496482
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
Washer wont spin
see this possibles cause:
It doesn't pump or spin
frozen pump pulley+drive pump belt broken replace
It pumps, but doesn't spin
lid switch open, or defective +motor coupler broken+belt broken+clutch worn+motor defective.+transmission not shifting properly+basket worn
It spins only with the lid closed
safety the machine will run with the lid door closed.
God bless you
2answers
LG WM2487HRM washing machine will not do spin cycle. Get a loud humming noise, no error code. Just replaced the hall sensor, but still getting the same results. No change. Any suggestions?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
I have an LG WM2277HS which will aggitate, but will not spin & rinse.
make sure the door safety switch is working correctly ,, if it doesn't show as locked, the machine won't spin
4helpful
2answers
My front load washer won't spin. It goes thru all the rest of the cycles except spin. It doesn't spin between wash and rinse either. It drains great, I've already checked that and no restrictions.
the next thing you will need to do is replace the door lock mechanism this will fail and cause the issue you are having the only other thing would be the main control board,but replace the door lock mechanism first.
LG- WM2355C Wont lock and start spinning. Shows
Unplug the washer for fifteen minutes and if that doesn't it is your lock mechanism. You will need a repair man or if you are handy you can do it.
Will not spin on spin cycle
It sounds like there's a problem with the door lock mechanism. If the washer the thinks the door isn't locked, it won't spin. You might be able to just replace the whole assembly by yourself.
14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
5helpful
2answers
Kenmore front loading washer/NOT SPINNING in cyle
replace your door lock switch it will run fine till you git to final spin then stops if i not missing the point the model no. will start with a 417 even door locks the switch is bad
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
