Question about Microwave Ovens
Sharp R-510AK Microwave Oven Fuse Blows
Have a Sharp R-510AK Microwave Oven. When the Start button is pressed the main fuse blows. Thanks is advance for any and all help.
  • bhamel Dec 13, 2008
    mine blows the main fuse almost immediately after the cooking function engages. I checked the HV capacitor and it reads .9 ohms in both directions. I also ohmed out the diode that goes from the HV capacitor to the case. It reads an open circuit in both directions and it appears to have gotten warm on one side. I believe the HV capacitor is bad along with the diode. My concern is that the magnetron is also bad - if so - not worth repairing. Can a simple ohm check tell me if the magnetron could be the main cause of the bad cap and diode?
  • Anonymous Mar 28, 2014
    When I press the start button on the microwave the oven temp indicator comes on. The microwave does not start.
  • Microwave Ovens Master
  • 9,098 Answers
If it went dead almost immediately after pressing the Start pad, that\'s usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that\'s usually a failing high-voltage transformer.
Here are some links you or a friend can use for test help, but read their safety warnings first:
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
You can probably find an exploded view by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
You can order Sharp parts from Sears or from Tritronics at http://www.wehaveparts.com
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
THE MICROWAVE KEEPS BLOWING FUSES, AS SOON AS I HIT THE START BUTTON THE FUSE BLOWS.iT WILL KEEP THE TIME AND THE LIGHT WILL COME ON BUT AS SOON AS i HIT START IT BLOWS
Sorry to read about your problem, I hope this helps you out.
you have a defective control board
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | Kenmore 63792 Microwave Oven
I believe mine blew a fuse as well
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
many people have been electrocuted with an unplugged microwave due to the enormous residual charge inside.
you can now get a new microwave at walmart for fifty bucks..........why monkey with a ten year old unit.
Aug 17, 2009 | Sharp R-963 Convection/Microwave Oven
No power and no clock or light
Internal fuse, Dangerous for the untrained. Have to find the cause for the fuse blowing. Eric
Aug 08, 2009 | Microwave Ovens
Fuse blows-up in my microwave
First you check AC main line ZNR blast,then check diode short
Jul 08, 2009 | Kenmore 62702 Microwave Oven
Sharp Model 1451 blown power fuse
1.Problem with monitor door switch or
2. Problem with high voltage condenser.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Nov 30, 2008 | Sharp R-1874 Convection/Microwave Oven
Makes a loud humming sound and blows fuse behind controll panel
Most likely a shorted capacitor is causing the fuse to blow. Easy and cheap to fix.
Check with www.martinmicrowave.com or call toll free 1-877-894-0035 for parts info
Sep 02, 2008 | Sharp R-1460 Microwave Oven
Kenmore over the oven microwave
check high voltage section diodes and capacitor or high voltage circuit,
Nov 03, 2007 | Kenmore 62702 Microwave Oven
Sharp R-9H66C Microwave Convection blowing fuses
check high voltage transformer and high voltage diodes, condencer, and magnetron.,
Oct 27, 2007 | Sharp R-963 Convection/Microwave Oven
Microwave not works
WARNING: Microwave ovens are the most dangerous consumer appliance to service due to up to 5,000 V at high current inside. Even with the power off, there is a HV capacitor that can produce a lethal kick. This capacitor must be discharged before touching anything in the microwave generator circuitry. DON'T remove the cover yourself unless you fully undertand the SAFETY issues involved in working inside a microwave oven. A microwave oven is possibly THE MOST DANGEROUS common consumer product to service. About the only "easy" fix would be a blown fuse, if it keeps blowing, don't go any further unless you know what you are doing. Your likely options are a blown high voltage cap, diode, or the magnetron. Good luck(but luck has nothing to do with it ;] )
Apr 01, 2006 | Sharp R-320H Microwave Oven
Microwave Ovens Logo
442 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
