I have a Bosch PB10-CD, it was working fine, but now when I plug it in to the AC outlet the GFI outlets reset button clicks on and off rapidly with a clicking noise and does not stop. What could be the problem? Can it be repaired? Is it worth the expense?
Disconnected the GFCI outlets, and everything works just fine. Ridiculous that Bosch manufactures GFCI outlets that does not last for 2 years. The cheepest American made GFCI outlets last practically for ever. Beeing "Bosch", the replacement outlets cost $38 plus shipping.
It is ridiculous.
Was this helpful?
Yes
No
Popular Solutions for Bosch PB10-CD Radio/CD Boombox
everything is working with the radio except the redio itself any suggestions what might be wrong...
(More)
everything is working with the radio except the redio itself any suggestions what might be wrong with it
My PB10-CD power Box was overloaded due to bad ground connection in garage breaker box. The GFCI...
(More)
My PB10-CD power Box was overloaded due to bad ground connection in garage breaker box. The GFCI does not indicate or test or reset. There is no voltage output from the GFCI. Can it be bypassed to allow normal operation of the Power Box without GFCI protection?
When the outside temperature is below 60 degrees my Bosch Boombox will not turn on. Once I take it...
(More)
When the outside temperature is below 60 degrees my Bosch Boombox will not turn on. Once I take it indoors where the temperature is above 60 degrees, after a few minutes it will turn on and work fine for the rest of the day.
