Question about Patton PUH680-U Utility Heater
Coils not all working
Only one coil becomes red when heater is turned on. What are possible solutions
  • bowers99 Dec 22, 2008
    I have had this apart 6 times, filament intact start to finish. connections seem good too. filamentss used to all get red, now only about 3 to 4 inched in the middle of the filament strand gets red. and about an inch in another spot. if the filament was shorting, it seems like it wouldn"t work at all or just to the point of the short? If it lights halfway through and only half way through as mine does, what could that mean?
  • cns3 Jan 22, 2009
    I bought 2 of the Patton PUH682 yesterday at Walmarts. Only the one coil in the middle gets red on either one and they throw out very little heat. Don't buy this heater.
  • 625 Answers
The heating coil may be broken and shorting out to the case. it is a nichrome resistance wire. replace it.
Posted on Dec 13, 2007
My 1991 chevy s10 2.5l want crank it's getting red spark
Hi Austin:
Counting on my fingers I make that over 25 years old, so the maintenance history and mileage become very relevant.
I'd be considering an ignition tune-up as an appropriate first step.
Changing spark plugs, plug lead harness (wires), rotor, cap, coil, Points & condenser (or solid state components.
Chances are it will show a remarkable improvement.
Jul 15, 2016 | Cars & Trucks
Our Servis Fridge freezer appears to not be working at all in the fridge bit and the freezer is working but the red emergency light is flashing?
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Aug 04, 2011 | Refrigerators
We have a hotpoint ffa71 thr red temp warning is on. The fridge seems to be working but there is a build up of ice at the back of it
NOTE: This
Leo Ponder
imufo2
Aug 03, 2011 | Hotpoint Refrigerators
Hi my name is Manny , and i have a whirlpool refrigerator/freezer MODEL # IS GD2NHGTKT01 SERIAL # IS SL2841004. and its totally down. i would like to know if the filter indicator being red and filter...
The filter will not keep it from working.
NOTE: This
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Check cold control (thats where you turn it colder)
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
Aug 01, 2011 | GE Profile PSW26P Stainless Steel Side by...
Hi I have an Amana BR18VW. I replaced the thermostat a couple of months ago due to ice build up in the back of the freezer. Everything worked fine for several weeks. I bought themometers for both the...
NOTE: This
Leo Ponder
imufo2
Jul 16, 2011 | Refrigerators
I have a PowerStar model #44-557701 tankless hot water heater. When you turn on the hot water it starts to heat and then it just shuts off. My dad thinks it might have something to do with the flow sensor....
Open following link for Bosch tankless troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 13, 2011 | Bosch & Tankless LP Hot Water Heater
Radiator/Heater Coil Issue on 2002 Chevrolet Blazer
It is very possible that your heater CORE is bad. You will smell a sweet odor of antifreeze inside your vehicle if it is leaking, and possibly feel for a wet spot on the floor boards. Need to replace heater core.
Jun 26, 2009 | 2002 Chevrolet Blazer
Modern Maid Wall Oven DGO757 ignitor gets orange,but does not fire oven.
HI, there are gas valve coils that initiate the opening and closing of the gas valves. these coils will become unstable overtime. if the coils are malfunctioning, it will cause the symptoms you are experiencing with your oven at this time. i recommend replacing the failing gas valve coils asap if possible.
It should be two or maybe three coils that are attached to the valve assembly(burner assembly). they are black and, cylindrical in design. replace these coils.
Jun 10, 2009 | Ovens
My whirlpool side-by-side is getting hot on strip between doors but everything seems to be working fine. Is there a solution? What if it becomes extremely hot??
It will not become extremely hot. It is heated by a thing called a mullion heater. It warms the area so it doesn't sweat and mold in the summertime. It is perfectly normal.
May 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My heater in living room dimplex xmc718n working about nearly 24 hr without electriciti i turn off all fuses and its still working. whay is this?
This is techcrazy
The problem is due to the overheating of solenoid coils(heating coils) in the heater.it gets energized to a greater extent that it can provide enough back up when power is turned off. so better check out with your service provider so that necessary changes can be made.
Kindly rate me on the above said solution
Jan 29, 2009 | Heating & Cooling
Patton PUH680-U Utility Heater Logo
354 people viewed this question
Top Patton Heating & Cooling Experts
Mack Baxter
Jay Finke
Jay Finke
ray gallant
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
