Question about GE Refrigerators
Where is the GE refrigerator condenser fan located
    Habit-Forming:
  • 28 Answers
Type this into your Google search and it will bring up several you tube videos ge condenser fan location
Posted on Oct 09, 2019
SOURCE:
duby1990
  • 370 Answers
SOURCE: location of condenser coils
They should be under the unit.
Posted on Nov 19, 2008
  • 1417 Answers
SOURCE: My 1998 GE refrigerator condenser fan keeps
A common question on on our site is about different fan sound that happen and the causes. These noises are often fairly easy to fix and some are the result of other problems.
If you are hearing a rattling sound or a squeaking, high pitched squeal coming from the bottom or back or the refrigerator then the condenser fan motor is probably going bad. Sometimes the bearing in the fan motor will even get so bad that the fan blade will start to hit anything that is close to it down there. This can create a very loud noise. This fan normally will be running when ever the compressor is running also.
As with any other problems you will want to get these things fixed promptly. If the problem is just a squeal a bit of light motor oil will do wonderful things for you. Many times though, you will have to order the parts needed to fix the problem. When repairing the problem make sure to remove all power the the unit and to wear gloves is possible, as there are many sharp edges in close quarters that will butcher you hands in no time.
The other fan that can cause sound is the evaporator fan. While this fan too can get worn and become noisy, it also can sometimes start to hit ice that is building up because of a problem with the defrost system of the refrigerator. Checkout my tips about defrost problems if you find a build up of ice and the fan is hitting the ice and making noise. This fan can also be oiled if needed, and it will also wear out and need to be replace occasionally. This fan usually will go off when the door is opened, so sometimes it makes it difficult to figure out exactly what is happening. By holding the door switch in manually, you can get the fan to run and troubleshoot it more easily. Make sure to remove all power before trying to service the fan. Spinning fan blades do not play nice with your hands!
For many refrigerators you will have to remove some covers or even the whole bottom of the freezer to get to this fan for replacement. Checking the exploded views at appliance parts websites can give you an idea of where the fan is located and what must be removed to get to it for replacement.
Both of these fans and the associated parts are available for most refrigerators online. Look for them at the appropriate spots in the exploded views of the units.
Good luck and thanks for using fixya.
Posted on Jan 19, 2011
  • 157 Answers
SOURCE: removing the GE refrigerator condenser
Unplug unit. first you have to disconnect the wires. sometimes there is a connector plug if not cut the wires. then you can take out the three screws that go into motor or remove the brackets with motor, take motor out of brackets, install new motor in brackets and reinstall. there is usually one screw that is hard to replace. you don't have to worry about which wire is which since it is AC. takes me about 30 -40 minutes to do
Posted on Jun 22, 2011
  • 5370 Answers
SOURCE: GE refrigerator GSS22QGMD CC I have
Try this way.-------- Read this carefully.The actual connection is as follows.The main power cord of your refrigerator connects to starter/overload relay and wire from starter/overload relay connects to compressor.So over load relay is the mediator between main power connection and compressor.----- You disconnect over load rely and connect power cord wire direct to compressor and then turn on unit and see,If the compressor runs or not.The compressor should run that way.Dont run compressor for more then few seconds.This is just to test if compressor is working or not.But if compressor not turning on that way then its problem with compressor .If compressor comes on that way, then its faulty over load relay, replace it.---------- ---------- If the refrigerator has power then compressor should run.If compressor is ok, then over load relay is faulty.-------
You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Posted on Aug 30, 2011
Sea Breeze
  • 4656 Answers
SOURCE: Where is the air circulator or fan on a ge profile refrigerator
Behind the rear wall of the freezer side....Sea Breeze
Posted on Mar 08, 2013
Ge profile bottom freezer (model GFSS6KIX) not keeping freezer cold enough. Water under veggie drawers.
First, check the condenser coils for any lint and dirt buildup and see if the condenser fan is running fast.
Post back your results.
Nov 04, 2012 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerator making squeeling noise once in a while. Noise is like someone complaining in a Charlie Brown cartoon.
. The next time the noise starts , open the freezer door and see if that is where the noises coming from . If yes , replace the circulation fan located in front of the evaporator assembly . If the noise is coming from the bottom of the unit and you can hear it clearly with the doors closed , more than likely it would be the condenser fan located next to and sometimes even mounted on the condenser assembly . If the unit has a static condenser , which will be indicated by the metal lines running up and down and all around the back of the unit itself , there is no condenser fan . The squealing noise you hear is a bad bearing in one of the motors . As the motor shaft spins , it actually wobbles within the bad bearing as too much clearance between the two exists .
Feb 19, 2011 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
The fan on my Side by side GE Hotpoint HSM25GFRFSA refidgerator was making a constant whining noise from the condenser fan. I replaced the fan and the nose stopped but it seams the fan is running...
the fan only runs when the compressor runs . are the coils clean. and if fan was bad maybe it was running all the time . run time is controled by the min pc control. .it may have to be replaced it is located in the back on the left side under the plate cover .. mm hope this helped .
Oct 21, 2010 | GE HSM25GFTSA Side by Side Refrigerator
Refrigerator makes naoise intermitently. Could it
Most cases it is coming from evaporator fan or condenser fan motors. 80% is coming from evaporator fan or condenser fan motor, 5% from compressor and 5% from flow of refrigerant ( gurgling ), 10% from the rest.
Mar 07, 2010 | Refrigerators
I have a GE Refrigerator model PD520SFSBRSS that
Strange sounds can be deceiving as to their actual location. Your problem could be one of several:
* icemaker
* freezer fan motor
* compressor
* condenser fan motor
Contact an appliance service company.
Feb 15, 2010 | GE Profile PDS20SFS Bottom Freezer...
GE Eterna stopped cooling. Not even 2 years old!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Check the fans especially the condenser fan. The noise if you listen close is probably the klixon cycling because the compressor is hot. If the condenser is plugged (real dirty), sign of a clean house, and/or the condenser fan is bad you will not get cooling. If the condenser fans operating properly and the fans inside the freezer and refrigerator are operating that would indicate serious problems assuming the compressor is operating.
Good Luck,
Gilshultz
Dec 01, 2009 | GE Refrigerators
GE TBF19ZB won't cool. Motor is running, But, refrigerator and freezer are not getting cold enough. Refrigerator and freezer are set at middle settings
dirty condenser coils or condenser fan not working most common problems,condenser is at bottom of refrig. next to compressor.
Sep 07, 2009 | GE Refrigerators
GE Refrigerator external fan - air flow?
This really depends on the manufacturer and their preference on design. First, the fins at the compressor are part of the condensing coil. Most all makers have air pulled into the condenser coil and blown across the compressor. You should be moving room temerature air across the condenser and the air from that is usually then moved across the compressor.
Hope this helps clear it up .
May 08, 2009 | Refrigerators
Can't find refrigerator coils/ cooling issues
There're two coils ,the condenser coil wich you already clean (also make sure the condensing fan motor works properly and the fan blades are also clean).The other is the evaporator coil wich is located inside the freezer behind the back wall cover.
Apr 21, 2009 | Refrigerators
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Tmik
Tmik
Level 1 Expert
