Question about Dell Inspiron 2200 Notebook
Upgrade Inspiron 2200 Memory From 512mb to 1gb
I want to upgrade my daughter's Dell 2200 Inspiron memory from 512mb to 1gb. I have the 1gb SODIMM memory but I'm not sure how to physicall replace it. The existing SODIMM is difficult to remove. Any guidance would be greatly appreciated.
  • 2 more comments
  • wchao Feb 09, 2009
    I have the same problem w/a Inspiron 2200 there is fixed memory in one slot with a metal plate that also covers the empty memory slot this is not easy accessability! What is the solution, and why does this metal piece cover the empty slot with no directions in the manual on how to remove?
  • Anonymous Mar 22, 2014
    what are the steps to swap out the existing 1gb memory stick with a 2db stick? I've never worked on this or any other laptop.
  • tony_gibbs Apr 26, 2014
    Hi I'm using an Inspiron 2200 that I have upgraded the memory and hard drive on, and have also installed Windows 7 Home Premium.
    Inspiron 2200 cannot take 2GB SO-DIMM, but can only take 1GB + the 256MB on motherborad, making 1.25GB in total. should this when I scanned the laptop when I bought the RAM, and it all works fine. so 1.25GB RAM is the max on this laptop. I didn't have a metal plate in mine.
  • 324 Answers
Good afternoon!
If you follow this link, you can download a copy of the users manual. Page 78 should give you the help you need.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Posted on Dec 12, 2007
Dell is not helpful on this problem at all. Their manual (and accompanying videos) do not show the metal plate, so, guess what? Problem solved. Assume away the existence of the metal plate ("it shouldn't be there") and the problem goes away. Unfortunately the metal plate is there on my model and can't be removed via the memory panel. So it looks like I'm going to have to go in to the main computer and try to get at it that way. Not good.
Posted on Mar 12, 2010
I suspect STCOLE has the same problem I'm having. Inspirion computers come with standard "fixed" memory which can't be easily upgraded. Dell "fixed" the memory by making the stick physically larger than then the opening between the clips holding it in place. Options appear to be breaking out the old memory with needle nose pliers and risking damage or opening the case, removing the main board and dealing with the memory in a more open environment. I opened the case but removing the main board appears to be risky proposition. My new memory is still in the desk drawer. Any suggestions?
Posted on Jul 04, 2008
I have just done the RAM upgrade on my Dell Inspiron 2200 laptop, and it was very straight-forward.
I would start by downloading the Service Manual from as it tells you how to do it.
A summary is that you remove one screw and a removable panel from the underside of the laptop, and then push-aside 2 clips to remove the SO-DIMM RAM module and replace it.
- There is only one slot for momory, so I had to remove the 512MB module to replace it with 1GB.
- it took me about 30 minutes to do it, once I had the service manual and the parts.
I bought the new RAM module from , because they have software to scan the laptop to work out what the correct RAM upgrade is.
So you can do it, but read the instructions in the service manual first if you feel unsure.
Posted on Jan 31, 2010
Whether DDR is compatible for hp pavilion dv1000 or only sdram is compatible. With which ram can i upgrade.
According to the maintenance manual only 266Mhz Ram can be added to the notebook.
This would be SDRAM.
Hope this helps!!
Kind regards!!!
Jan 06, 2010 | HP Pavilion dv1000 Notebook
What is the fastest motherboard out today for a Toshiba Qosmio G25-AV513 laptop upgrade/replacement?
if you are planning to change your motherboard assembly that would be costly.. but i suppose you wont want that, maybe your are referring to an ugrade? try the memory first, here i found some deals for you.. memorystock_certified.gif Memory Size Chip Description Part Number Price OEM Part# 512MB Module 512MB-400MHz DDR2-400 PC2-3200, 200p SODIMM, 1.8v
716ms-716 view_details.jpg $12.95 KTT533D2/512 1GB Module 1024MB-400MHz DDR2-400 PC2-3200, 200p SODIMM, 1.8v 717ms-717
Dec 09, 2009 | Computers & Internet
Can I upgrade the RAM of this laptop and the grafic card?
Your memory can be upgraded to a maximum of 2Gb of memory.
You have 2 slots, and they can each take a 1Gb stick of PC2-4200 laptop SODIMM memory.
Your laptop has integrated graphics and can't be upgraded
Nov 03, 2009 | Dell Inspiron 630M Notebook
How do you remove and replace dell laptop memory? (d600)
I dont know this particular model, but usually it's underneath the computer, there is one screw to remove and you can take out a door which gives you acess to the memory slots. If it's not there, you will need to remove the top cover to get there. But it's most likely a small door underneath the laptop.
Jun 03, 2009 | Dell Latitude D600 Notebook
Dell memory issues
if the ram chips are not compatible you need to get ones that are.
your unit supports this type
Memory type 1.8-V SODIMM DDR-2
Minimum memory 256 MB
Maximum memory 2 GB
you can still put 2 gigs in it but it has to be the above type
here is a link to a manual
and are you surprised that they say it will work. Thats why you have techs here, because the manufacturers hire people that don;t know from adam. same thing with apple. the techs you call are usless. Return your ram chips to dell and have them send you the ones that work.
Jun 02, 2009 | Dell Inspiron 6000 Notebook
Where can I find proper memory to upgrade Gateway laptop MX3225 to 1GB? Best Buy tried to put in wrong memory today and it did not work
512MB Module 512MB-533MHz DDR2-533 PC2-4200, 200p SODIMM, 1.8v 1GB Module 1024MB-533MHz DDR2-533 PC2-4200, 200p SODIMM, 1.8v So you need DDR2-533 PC2-4200 200P SODIMM'S
1.8 Volts
Aug 31, 2008 | Computers & Internet
Memory location Dell inspiron 2200
The memory inside is fixed but there is an open slot . Just open the access panel on the back and the slot is there. You can add up to 1GB
May 02, 2008 | Dell Inspiron 2200 Notebook
Reg ram upgradation
Each memory slot on the C555NR can support a maximum of 1GB of RAM. There are actually 2 slots, but only one is easily accessible to you. By upgrading both the primary and secondary DIMMs, you could achieve a total of 2GB of memory but you would have to remove the 512mb chip that is already installed and replace it with 1GB (+1GB in the expansion slot as well.)
If you don't plan on taking the computer to a professional to be serviced, you will probably only want to upgrade the memory in the secondary slot located under the memory cover on the underside of the computer. It can handle a 1GB SODIMM.
FYI the memory is:
200 Pin DDR2-533 PC2-4200 SODIMM
Apr 21, 2008 | HP Presario C555nr Notebook
Memory upgrade for Dell Inspirion 4100 notebook
buy 1Gb -one ram, the rices for 512 and 1gb are more or less same now
Apr 21, 2008 | Computers & Internet
Acer L100 memory upgrade
you can open it up and see, take out the ram to see what kind it is
Dec 24, 2007 | Acer Aspire L100 PC Desktop
Dell Inspiron 2200 Notebook Logo
1,989 people viewed this question
Alun Cox
