Kitchen Appliances - Others Logo
ANH VINH Posted on Oct 09, 2019
Fan not working in brand new Air fryer HD9240/34
emma jackson
Level 1:
  • Contributor 2 Answers
  • Posted on Oct 18, 2019
emma jackson
Contributor
Level 1:
Answers
Questions
0
Helped
393
Points
If your fan not working contact the customer support number.
1helpful
Is it normal for the air fryer fan in my Maytag stove to keep turning on and off every few seconds?
Question edited for clarity (typos, fun to fan, of to off).
Maytag doesn't mention, but BestBuy says it is normal.
Using the Air Fry Feature
Maytag https://producthelp.maytag.com > Product_Info > Usin...
Jun 29, 2022 - Using the Air Fry Feature on Maytag Range or Oven Convection fans will circulate hot air very quickly around the surface of the food, which ...
Just used my Whirlpool convection oven air fryer - Q&A
Best Buy https://www.bestbuy.com > site > questions > question
Dec 6, 2021 - Hello, this is a normal operation for the fan to turn on and off to help with air circulation. We hope this helps. ... Sorry, there was a problem.
I got one off your air fryers for christmas last year. Aabout aa month ago it stopped working.
Hello, Phyllis -
Fixya.com does not sell air fryers or anything else, for that matter.
You will need to look on the air fryer to find the brand name and check the warranty information which is probably printed in the user manual which came with the air fryer. There may be information in the user manual regarding authorized repair centers for your air fryer brand. I hope you saved the manual and know where you stored it.
Best wishes.
I need a Manuel for cooks essentials air fryer 3.4 qt.
Hello, Debbie -
Cook's Essentials is a brand which is exclusive to QVC (when sold new.)
Luckily, I found a link for the user's manual for the 3.4 qt. digital air fryer on the QVC product page:
http://www.qvc.com/Cooks-Essentials-34-qt-Digital-Air-Fryer-w-Presets-%26-Pans.product.K46611.html
Scroll down the page to find the link for the Manual. Note: You will need Adobe Acrobat Reader (free) installed on a computer. Click or tap on the link for the Manual to view and download it to save or print.
Best wishes.
Is my fan supposed to run while the air fryer is cooking. I can’t get mine to come on
an air fryer uses a fan to circulate the hot air
without the fan , it will not work properly
2answers
I need an instruction manual for a cooks essentials air fryer
How to Use Your Fryer:
  • Remove all packaging materials, sticker, and labels.
  • Clean the basket and pan with hot water, soap and a non-abrasive sponge. These parts are dishwasher safe.
  • Wipe the inside and outside of the appliance with a clean cloth.
  • Place the air fryer on a flat and even surface.
  • Put the basket in the pan.
  • Plug unit in to an approved wall socket.
  • Place the ingredients in the basket and then put the basket and pan back into the appliance. The fryer LED will light up.
  • Set your cooking time and temperature by either choosing one of the 8 presets or manually set it with the "+" or "-" buttons. See "Cooking Guide" to determine the right time and temperature.
  • Once you have set your cooking time and temperature, press the "Start" Button.
  • The heating icon and fan icon will be blinking and this means that the fryer is starting and is circulating the hot air in the fryer. NOTE: During hot air frying, you will notice that the heating up icon will blink and stays from time to time. When the heating icon is on, it means that the temperature inside the fryer has reached the set temperature. When the heating icon is blinking, it means that the temperature inside the fryer dropped and is below the set temperature and is currently heating up to the reach the set temperature.
  • Some ingredients may need to be shaken halfway through the cooking cycle (see "Cooking Guide"), To do this, pull the pan out of the air fryer by the handle, the air fryer will automatically shut down. Then shake the contents in the basket, then slide the pan back into the air fryer and it will resume the cooking cycle. CAUTION: Do not press the button on the handle during shaking; this will detach the basket from the pan.
  • When the cooking time has been reacher, the air blower will stop in 20 seconds.
  • Pull the pan out of the fryer and place it on a pot holder. The cooking pan is VERY HOT do not put on surface that can burn. NOTE: Oil from the ingredients will gather in the bottom of the pan, so be careful when pulling the pan out of the fryer.
  • To remove the ingredients, press the button on the handle of the pan to detach the basket. DO NOT TURN THE PAN OVER. PLACE ON A POT HOLDER.
  • Upon placing the cooking basket back into the air fryer, the air fryer will automatically go to the previous cooking cycle and will repeat the previous cooking cycle, press the cancel button to stop and reset the air fryer if desired.
Brand new and won't heat up blows out cool air
Brand new and does not work = return to store for replacement. I never waste my time in cases like this.
Halo fryer noisy
Mine too did you ever find an answer
I have purchased 11 brand new imperial fryers and i continually keep having pilots that dont stay lit wnhen i try to turn it to on and its not always the same fryers that have this problem they continually...
Hi there.
With regards to your brand new fryers, I'm sure that the manufacturer has warranty parts and service policy that deals with your present problem. You have to communicate with them to know how far you can go in troubleshooting the equipment, most manufacturers will void the warranty if the equipment is tampered.
Just make use of the warranty.
Visit http://www.imperialrange.com for fryer Owner's Manual and for the location of the nearest distributor in your area.
Regards.
Top Kitchen Appliances - Others Experts
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
