Question about RCA 20F510TD 20 in. TV/DVD Combo
Input password will not respond to manual or remote functions screen display showes only ch 31 cable then input password then **** when any four numbers are pressed then back to blank screen green screen displaying ch 31 then input password
  • 259 Answers
Problems with V-Chip/Parental Controls
The rating limits don’t work
• For rating limits to take effect, you must lock V-Chip settings to activate them.
I don’t remember my password and I want to unlock the TV
• If you forget your password you can reset it. Enter 5898 as the password and then change it
to a new one.
Posted on Dec 13, 2007
Accidently changed something and not able to get antenna tv now - do not ahve cable here at work
I am unable to see at a glance how to correct this but it is between its menu, channel and volume buttons to alter the settings it may be worth to run through the re-tune sequence below?
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable channels.
? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the
screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner
will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by the receiving conditions. In this
case, try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input,"NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
[ADD/DELETE FUNCTION]
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
3) Press the VOL(ume) ? button so that "ADD/DELETE" is selected.
4) Use the CH(annel) ? or ? button to select the
channel you wish to put into memory or to erase from memory.
Note: The menu will disappear in about 10 seconds.
Perform "ADD/DELETE" function while this display appears on the
screen.
? Press the VOL(ume) ? or ? button to light up the channel number
in LIGHT BLUE if you wish to add the channel into memory.
in LIGHT RED if you wish to erase the channel from memory.
5) Press the MENU button to exit the menu.
Hope this helps.
Jun 29, 2015 | Durabrand DWT1304 13" TV
How to turn off child lock without remote control jvc lt-32sh6
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
OR
Select "TV" from the menu then select "V-Chip" from the drop-down list on the screen. "Please Input Password" will appear on the screen.
Enter your four-digit password by selecting numbers on the 10-pad that appears on the V-Chip menu display or your remote control. Create a new password if you forget it by unplugging your TV power cord from the outlet then reconnect the power cord. This procedure resets your password to "0000." Enter four numbers for your new password using the keypad on the screen or your remote and select the arrow to advance to the next number. Press "OK" on your remote or select "OK" on the screen to set your new password.
Unlock a TV rating or TV channel by selecting "MPAA" or "TVPG" from the V-Chip menu. Use the up or down arrows to select the locked rating then select "OK" on the display or press the "OK" button on your remote control to unlock it. The MPAA represents the U.S. Motion Picture Association of America rating system, such as "NC-17," meaning not intended for viewers 17 years or younger.
Nov 01, 2012 | Televison & Video
I have an 32 rca t.v my son has locked and won't
I got this from the manual. Page 26.
Press MENU to see the main menu.
Press CH+ or CH- to highlight preferences.
Press OK to enter the preference submenu.
Press CH+ or CH- to highlight Par. (Parental) Control.
Press OK. Enter Password will appear on the screen.
If you want to set a new code, go to steps 6-8 directly. (You can press the number buttons to enter a four-digit code. The code "0000" is the default password. If you have not set a code previously, then "0000" is the code.)
Resetting Your Password
Press VOL+ on the remote and the CHANNEL + on the front of the TV at the same time. Enter New Pwd. will appear on the screen. (You must be in the Enter Password screen when attempting this.)
Press the number buttons to enter a four-digit code. The code will appear on the screen as you enter it.
Press OK to save the code.
Press MENU repeatedly to exit the menu or the menu will automatically disappear within a few seconds if no buttons are pressed on the remote control.
If you need more, get the manual here:
http://www.retrevo.com/support/RCA-32V432T-TVs-manual/id/402ci372/t/2/
Pages 25 through 30 are all about lock and channel/show blocking.
Jun 05, 2012 | RCA Televison & Video
There. Is a channel lock on my tv. So I can't change the channels. How do I take it off?? Help!
Hello
you have to unlock your jvc set, and reset the V-Chip settings. There are two ways to unlock JVC TVs, you have to find out which proceedings frome below mentioned will work with your TV.
[1]
[2]
Unlock a TV rating or TV channel by selecting "MPAA" or "TVPG" from the V-Chip menu. Use the up or down arrows to select the locked rating then select "OK" on the display or press the "OK" button on your remote control to unlock it. The MPAA represents the U.S. Motion Picture Association of America rating system, such as "NC-17," meaning not intended for viewers 17 years or younger. TVPG provides you
May 10, 2011 | JVC AV-27020 TV
Can not find codes for toshiba remote for my sony dvd home theater changer nor any specifics on hooking it up properly and it has s video but no hdmi hook ups help By the way i already pd 1459.00 dollars...
To find the code for the Toshiba remote to the Sony DVD changer.
If you do not know the device code for a particular device, you can view each available code for that device mode and sample the functions to find the code that operates the target device. 1 Press a mode select button on the remote. 2 While holding down INFO button , press 8, 5, 0, 0. The remote control enters program mode. 3 Point the remote at the target device and press Power button, 1, VOL UP, CH UP or PLAY. Some keys are ignored if they are not applicable to a specific device mode. 4 If the device responds to the remote control: Press INFO button to store the device code. The mode select button blinks twice. The remote exits program mode. 5 If the device does not respond to the remote control: Press UP. Press POWER. Repeat this step until the device responds to the remote. Press INFO . Note: When a search cycle is completed, the mode select button blinks 3 times. The remote displays each available code again. If no key is pressed within 10 seconds, the remote exits program mode and returns to the previous code.
The previous section was from the manual p.86: http://www.iusermanual.com/tv/toshiba-46vx700u-tv-manual.htm
Hooking the DVD changer to the TV: The TV has composite video inputs and can accept s-video by a adapter cable as in: http://www.amazon.com/S-Video-3-RCA-Composite-Cable-Laptop/dp/B002ZKTCUM/ref=pd_cp_e_1
May 05, 2011 | Toshiba 46VX700U LCD TV
During my recent transfer to a new flat i lost my remote control for my panasonic dvd recorder type DMR EH67. I bought a universal remote control but i did not have the full functions of my lost one. In my...
You can try changing the command mode of the (genuine Panasonic) remote itself, press and hold [ ENTER/OK ] and the number [ 3 ] button together for 5 - 10 seconds, then release. Then try the remote with the unit. If it still shows DVD 3 on its display, no matter which button is pressed, reset the main unit to factory default as outlined in the user manual (assuming this model recorder has a tuner, there would be channel buttons on the front - try pressing and holding [ CH/UP ] and [ CH/DOWN ] together - for 5 - 10 seconds, until 'SETUP' appears, then release). This may or may not restore your DVD unit to the default (DVD 1) command mode. (Don't forget to reset the remote back to DVD 1 if you do reset the main unit - press and hold [ ENTER/OK ] + the number [ 1 ] button together as above).
Your new remote may be set to DVD 1 by default while your unit is DVD 3 = different remote command modes.
May 02, 2011 | Panasonic DMR-EH67EG DVD Recorder/HDD...
The remote and control panel are locked on my 52" LED LCD tv.
Hello
To unlock the remote control function do the following.
On the front pane touch control pad
1 Press MENU to display the MENU screen, and then
press VOL[--/+] to select "System Options".
2 Press CH [UP/DOWN] to select "Operation Lock Out", and
then press INPUT.
3 Press CH UP/DOWN] to select "Off", and then press INPUT
4 Press MENU to exit.
• To unlock the buttons on the TV, press MENU on the
remote control, and then select "Off" in "Operation Lock
Out".
OK.
Feb 16, 2011 | Sharp LC52LE810UN 52 in LCD TV
My tv won't play my DVD player. I don't have the original remote, but it is programed to a universal remote. Whenever I press the "TV/VCR" button all kinds of numbers pop up on the screen and the tv...
Your TV is responding as if the Game button was pressed on the original remote. The additional stuff on the screen is to let you set the best brightness and other settings for video gaming. These screens should disappear on their own in 10 seconds if no buttons are pressed on the remote. See the manual http://www.symphonic.us/support/manuals.aspx and fill in the model number. If the remote were still controlling the TV, the CH up and down buttons would let you choose the Picture settings to change and volume up and down buttons would change the setting.
The TV/VCR button on the universal remote may be swapping the remote to control the VCR only. (Thus losing the ability to control the TV.) (What does the manual say about the button for the universal remote?) You may want to consider a different universal remote - programmable or http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=ST419E&uuid=12844254442790 which has an exact substitute.
Check your cables for the sound issue (try new ones) and make sure that they are fully seated in the jacks.
I hope this helps.
Sep 14, 2010 | Symphonic ST419E TV
Dont have the remote and cant change the input to video
I believe you press the ch up and ch down keys at the same time, and then you'll get the menu displayed on the screen, use the same keys(ch up/ch dn) to select input on the menu listing and use the vol up to enter. you can still get an owners manual for this tv from retrevo.com and you can still acquire a remote(original) from estore.fox-international.com
Jan 14, 2010 | Memorex MT1127 TV
Magnavox tv not responding to remotes
I came accross this question, because I've been looking for the remote code for my cable remote. I had originally put the TV remote somewhere in a box when I was moving years ago, Since my cable remote changes the channel, I've been doing the same as you all this time. Therefore, I totally understand your frustration on trying to understanding how to navigate within the menu: It's not what you would think would be a standard or logical way....
Anyway, in my research, I did come accross the TV manual, and I found the instruction on how to reset the TV. I tried the steps, and THEY"RE STILL confusing, so I've added my own hints....hope this helps:
Your TV can be reset to the factory settings in case you forget your Smart Lock password, or want to change the picture, sound, or features settings.
1 Press the MENU button on the remote control to see the onscreen menu.
In the left panel, you will see four icons (from top to bottom)
  • TV INSTALL (a tv)
  • PICTURE (icon of film)
  • SOUND (a piano)
  • FEATURES (icon of pliers and a hammer)
When the Menu screen is showing the left panel as highlighted light grey, the Chanel buttons have Page up/Page down Functionality
2 Press the the (CH UP) or_(CH DN) buttons to highlight the FEATURES menu.
Navigate to the FEAUTRES menu (icon of pliers and a hammer - bottom of left panel) and you should make sure it is highlighted in blue
3 Press the (VOL+) button to enter into the FEATURES menu.
The right panel should now be highlighted in a light grey
4 Press the (CH UP) or (CH DN) buttons to highlight the FACTORY SETTINGS control.
This will select items in the right panel, FACTORY SETTINGS in on the bottom
5 Press the the _(VOL+) or _(VOL-) buttons to reset the TV to the original factory settings.
6 Press the MENU button repeatedly to clear the menu from the screen.
The entire manual is found at this link: http://www.m4c.magnavox.com/files/1/15mf200v_37/15mf200v_37_dfu_aen.pdf
BTW, of any one know how I can program or get an RCN remote to use on this TV, please let me know!!!!
Feb 21, 2009 | Philips Televison & Video
RCA 20F510TD 20 in. TV/DVD Combo Logo
268 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
