Question about Philips Cell Phones
Philips chassis 16.3 E LA bootloop.
TV Philips (2017 y) 24pfs52631/12 continues restart. Show logo and turn off. So again and again. How to fix it?
SOURCE:
ThaMp3Doctor
  • 8596 Answers
SOURCE: logo of the company/philips
you can see it at www.usasupport.philips.com
Posted on Jul 24, 2008
  • 3230 Answers
SOURCE: format my gps usb restart show logo and restart
Well to avoid this problem you can do a hard reset, that reset set all the settings to factory default and it again format in fat file system, Turn the unit off. Hold your thumb on the bottom right of screen and turn it on, keeping your thumb there. Say "Yes" when prompted. Please post comments if further you have the same problem......
Good Luck!!
Thanks
Posted on Feb 15, 2010
walesarumi
  • 6993 Answers
SOURCE: when i turn on my sansa e260 and show the sandisk
Hi, welcome to fixya!
You need to reset your sansa for it to be in order again.
Learn how to reset the your various San Disk models;
Resetting a Sansa Fuze+, Clip+, c200, e200, or e200R player:
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
Resetting a Sansa View, Fuze, or Clip player:
1. Slide and hold the Power switch up for approximately 20 seconds.
2. Release the Power switch.
3. To turn the player on, slide the Power switch up then release instantly.
Resetting a Sansa Express player:
NOTE: The device can be either ON of OFF.
1. Press-and-hold the Volume Up (+) and Select buttons simultaneously for approximately 20 seconds.
2. Release the buttons.
If resetting doesn't solve the problem, please let me know for more assistance.
Good luck.
Posted on Nov 03, 2011
  • 2559 Answers
SOURCE: does not run recovery menu. I update firmware but its not solve my problem and phone. My phone is #bootlooping # restarting hang on logo # Automatical restart HTC 820n
Bad battery will cause boot looping.
Posted on Nov 29, 2016
Testimonial: "But I still have the same problem when my phone is charging"
  • 2800 Answers
SOURCE: Samsung UE40D5500RW stuck in on/off with start logo SAMSUNG
I don't think this is a software issue, I would check the PSON voltage and see if it stays at either a low or high reference. Get a meter on that pin, turn the set on and you will see it change when the set comes on, does that voltage go back to the level it was at when the set was off or does it stay the same even though the logo goes away
Posted on Oct 31, 2017
Flashing my Motorola Dafy Plus failed... made a factory reset... battery doesn't charge/charges very slowly... How can I make it work again???
Nico
This site doesn't help with this sort of thing but others have found solutions on XDA developers for this sort of thing. I don't endorse it but it may work.
Motorola Support
Dec 27, 2014 | Motorola Mobility Defy Plus Android 2.3...
I need to reset my projector. It is bazook after I disconnected it incorrectly from my MacBook. It now shows the grid and then it twinkles maddly and the gris reappears, and the whole sequence is...
hy , i have an optoma pk 102 projektor and i have a promblem i start the projektor , shows me the "optoma logo" and than it's starts flashing and restarting , and show again the optoma logo. i try to connect to the laptop and show me the extend monitor for 10 secounds and restarting again, how can i fix the problem,maybe i cand upgrade the firmware?.Thanks
Apr 26, 2011 | Optoma PK102 Projector
What do you do if you have a window that say's, "Warning Event Notification;" "chassis intrusion detected. This typically does NOT indicate a hardware failure. 1. Contact your help desk if you did not...
Resetting the Chassis Intrusion Detector Turn on (or restart) your computer. When the blue DELL? logo appears, press immediately. If you wait too long and the operating system logo appears, continue to wait until you see the Microsoft® Windows® desktop. Then shut down your computer and try again. Select the Chassis Intrusion option and then press the left- or right-arrow key to select Reset. Change the setting to On, On-Silent, or Disabled. Hi, Above is the procedure for resetting the switch. This is directly from the on-line manual. If this does not work, just comment back. Thanks for using Fixya,.
May 13, 2010 | Dell OptiPlex GX280 PC Desktop
Format my gps usb restart show logo and restart
Good Luck!!
Thanks
Feb 15, 2010 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
My 16 gb gogear froze
1 On your computer, select Start >
Programs > Philips Digital Audio Player
> Aria Device Manager > Philips Device
Manager to launch the Philips Device
Manager.
2 Turn off GoGear Aria before you
continue.
3 Press and hold the volume button
while you connect GoGear Aria to your
computer.
4 Keep holding the key until the Philips
Device Manager acknowledges GoGear
Aria and enters the recovery mode.
5 On the computer, click the Repair
button and follow the instructions of the
Philips Device Manager to complete the
recovery process.
6 When the recovery is completed,
disconnect GoGear Aria from your
computer.
7 Restart GoGear Aria.
The full manual is found here: http://www.p4c.philips.com/files/s/sa1ara16k_17/sa1ara16k_17_dfu_aen.pdf
Oct 29, 2009 | Audio Players & Recorders
My phone is stuck in on and off mode
Step 1. Turn off your iPhone.
Step 2. Hold down the power and home button.
Step 3. When you see the Apple logo, release the power button but continue holding the home button down.
Step 4. Open iTunes and wait for it to tell you that its in restore mode.try
Aug 17, 2009 | Apple iPhone 3G
Dl an app and now it trys to boot but cant
Aug 01, 2009 | Apple iPhone 3G
Iam erase all content and settings whne it is finesh now jast logo of apple is comeing not more can u help me how can i fiex this problam ???
try this ssir...........
Dec 07, 2008 | Apple iPhone 3G
Connection to gogear
Sounds like the firmware is corrupt.
Try this:
Make sure you have installed Philips Device Manager from the product CD.
With the player powered off:
Press and hold VOL+ whilst connecting to the PC.
PC will show drive as Recovery Device (or similar) and device manager will start and show "Your device has an error...."
Click repair and follow the on-screen prompts.
When prompted, disconnect the player and power on.
Player will show "Loading" and then shut down.
Power on again.
Player will show "Updating" and then shut down again.
Player can now be powered up as normal.
Restart
Feb 27, 2008 | Philips GOGEAR SA6045 MP3 Player
Cell Phones Logo
18 people viewed this question
Top Philips Cell Phones Experts
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Are you a Philips Cell Phone Expert? Answer questions, earn points and help others
