Question about Refrigerators
Hi, kenwood friedge / freezer ksbsx17, the top of the freezer is not working and the bottom of the fridge is freezing up is it the fan in the freezer, and how do you get the cover off. thankyou
SOURCE:
eagle338
  • 4889 Answers
SOURCE: Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Posted on Oct 09, 2007
  • 125 Answers
SOURCE: Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Posted on Feb 07, 2008
  • 88 Answers
SOURCE: FRIDGE COMPARTMENT FREEZING
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
Posted on Dec 06, 2008
  • 351 Answers
SOURCE: top half warm while bottom half freezing in a side by side fridge
bad evaporator fan and or a defrost problem
Posted on Jun 23, 2009
aasc
  • 1606 Answers
SOURCE: Fridge/Freezer - fine bottom half, warm top half
Sounds like the fan in the freezer is not working ( pt# WR60X190 ) .
Posted on Jul 30, 2009
KENWOOD KSBSX17 American-Style Fridge Freezer Error code e4
My kenwood ksbsx17 has a e4 code wot is this please freezer making excess noise
Apr 21, 2018 | Refrigerators
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Everything freezes in the refrigerator bottom drawers - no matter what we set the temp in the freezer or refrigerator, everythign freezes.
Make sure the vents from the freezer to the fridge are not blocked by ice etc. One is at the bottom and one at the top. The on at the top is adjusted open or closed when you adjust the fridge temp. Make sure it's working. Also make sure the fan in the freezer is circulating the air from the freezer through the vent at the top.
Aug 25, 2009 | Whirlpool ED2GHEXN Side by Side...
Top of freezer not freezing, bottom of fridge is?
Could be the evaporator fan motor is not working. This is what circulates the air from the freezer to the refrigerator section.
Aug 24, 2009 | Refrigerators
Jul 30, 2009 | Refrigerators
Fridge not cold
my freezer is over freezing and my fridge is not cold. I have a whirlpool where the freezer is on top and the fridge is on the bottom. I need guidence in trying to figure out the problem.
Sep 29, 2008 | Kenmore 64802 Top Freezer Refrigerator
My side by side fridge, fridge side is feezing up...
HI,GOOD JOB CLEANING THE COILS IT HELPS ALOT,MOST TIMES IF YOUR FREEZER SIDE IS FREEZING UP THERE ARE 5 THINGS TO CHECK,WHAT MAKE,MOST GE HEARTERS GO BAD FIRST,EASTEST TO CHECK FIRST IS THE FAN,OPEN FREEZER DOOR,IS THE FAN RUNNING,SOME MODELS YOU WILL HAVE TO HOLD THE FREEZER BUTTON DOWN FIRST,MOST ON INSIDE TOP,NEXT REMOVE FREEZER BACK PANEL WALL,IF YOU SEE A SHEET OF ICE,YOUR DEFROST HEATER(ON BOTTOM OR SIDE) AND THE HEATER TERMANATOR(LITTLE ROUND CLIP ON BALL WILL HAVE TO BE CHECKED WITH A OMES METER,YOU CAN DEFROST IT WITH A HAIR DRYER,WHEN DEFROSTED YOU CAN SEE IF THE DRAIN(MIDDLE BOTTOM OF FREEZER IS CLOGGED,LAST DEFROST TIMER(TOP FRONT,BACK BOTTOM,INSIDE FRIG.TURN CLOCKWISE SLOW TILL YOU HEAR A CLICK,SEE IF FREEZER FAN WENT OFF,WAIT 25 MINUTES,SEE IF FAN COMES BACK ON IF SO IT'S NOT THE TIMER,LET ME KNOW WHAT YOU FIND AND I WILL HELP YOU FARTHER-MIKE
Jun 21, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
