Question about Cell Phones
What is the lock out code - Cell Phones
I have forgotten my unlock code to lg revere
This is copied directly from the manual - check out #5 at the bottom.
Hope it helps!
7.7 Security
The Security menu allows you to
secure the phone electronically.
1. Open the flip and press
[MENU]
2. Press Settings & Tools.
3. Press Phone Settings.
4. Press Security.
5. Enter the four-digit lock code.
The lock code is the last 4 digits
of your mobile phone number if
it is set. The lock code is the last
4 digits of your MEID if your
mobile phone number is not set.
Aug 02, 2012 | LG Revere MobiPhone - Black Verizon...
My cellphone is locked n i can unlocked please help me :{
Its locked to security code or Network Lock,it locked to Network means get the Network UNLOCK CODE from here
theunlockspot.com and Unlock it,It locked to security code means get the default code from service provider and reset it,you can also use the master reset code to reset Phone from security lock and password Lock,get the master reset code for Nokia and Alcatel Mobile Phones there itself and reset from security lock.
Aug 15, 2011 | Cell Phones
HI MY NOKIA C6 LOCKED I FORGET LOCK CODE OF C6-- PLZ HELP ME IMEI NO. is___ 355398042831551
my nokia c6 is locked and i forgot my lock code ....imei no. is355398047589410
Apr 26, 2011 | Nokia C6 Smartphone
Dont know the lock code
which lock code, sim lock code ,phone lock code ,network lock code , privacy lock code
Mar 13, 2011 | Samsung G810 BLACK 5MP WIFI 3G camera...
Found a master code lock
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Jun 26, 2009 | Master Lock 5400d: Portable Select Access...
Need to unlock a Nokia 6103b
Unlock your phone
  • Press Menu, enter the lock code, then press OK.
Answering a call when the phone is locked
  • Press Answer.
To change the lock code of your phone
Your phone's lock code is used to lock and unlock your phone.
The default lock code is 1234.
  1. Use Menu 4-3-2-3 (Settings - Security settings - Access Codes - Change lock code) to change the lock code.
  2. When the phone requires the lock code, it displays "Enter lock code:".
  3. Enter the code, then press OK.
If you enter a wrong lock code five times in succession, your phone prompts you for the security code.
Saving the unlocked phone number
Use Menu 4-3-2-2 (Settings - Security - Settings - Unlocked phone number) to save a number that may be called even when your phone is locked. You will be required to enter the lock code.
  1. Calling the unlocked phone number.
  2. Press the Up or Down arrow keys or or manually enter the number exactly as it is saved, then press Call.
Note: The More key will pause the automatic scrolling of the help text. Pressing the More key or the Up or Down arrow keys will toggle through the pages. The More key is only displayed when the help text is displayed.
Jan 26, 2009 | Nokia 6103 Cellular Phone
Nokia 6500 slide help i need restriction code
PLEASE READ FULL INSTRUCTIONS BEFORE DOING ANYTHING
TRY WITH NO SIM CARD IN THE PHONE
Doing this is at your own risk!
Every code unlocks a certain lock. Code number 7 usually unlocks them all but some phones are 'buggy' and will not accept code 7 at first then use code 1.
Usually you only have to use code 1 or code 7.
#pw+xxxxxxxxxxxxxxx+1#
1. Press ( # ) on your phone
2. To get ( p ) press ( * ) 3 times within 1sec
3. To get ( w ) press ( * ) 4 times within 1sec
4. To get ( + ) press ( * ) 2 times within1sec
5. Enter the 15 digit code
6. To get ( + ) press ( * ) 2 times within 1sec
7. Enter code number
8. Press ( # ) on your phone
Now your phone is unlocked!
If your phone isn?t unlocked after code 1 or code 7 then you have either entered the wrong IMEI or Network. Sometimes there could also be a problem with newer software versions. Then you can try another 'Boxserial' Remember! You have only five tries to enter the right code. After that you will need a cable to unlock your phone. So please, be aware
Phone type: DCT4
IMEI: 352027025104628
Model: 6500
#pw+319926630701132+1#
#pw+702310427045122+2#
#pw+754840072200550+3#
#pw+093433717136641+4#
#pw+199064315752575+5#
#pw+286305406405613+6#
#pw+307016424512121+7#
There is 4 locks on a Nokia DCT4 phone.
Lock 1: MCC+MNC (Network och landsspecific)
Lock 2: GID1 lås (SIM-card typ)
Lock 3: GID2 lås (SIM-card typ)
Lock 4: MSIN lås (SIM-card specific lock)
The generated codes open up one or several locks.
Code 1 open lock 1
Code 2 open lock 2
Code 3 open lock 3
Code 4 open lock 4
Code 5 open lock 1 and lock 2
Code 6 open lock 1 lock 2 and lock 3
Code 7 open lock 1 lock 2, lock 3 and lock 4
Let me know if you have any problem follow these instructions and you should be ok.
I think it needs to be done with no sim card in the phone remember you only get 5 goes after this if its still not unlocked then the only other option is with a lead and unlocking software.
This should solve your problem let me know how you get on ok
This is done at your own risk!
Aug 02, 2008 | Nokia 6500 Slide Cellular Phone
Lock Code Recover
i am trying to format my n70 it asks for the lock code, how do i find it thanks
Jun 21, 2008 | Nokia N70 Cellular Phone
Codes
Samsung Secret Codes
*2767*688# = Unlocking Code
*#8999*8378# = All in one Code
*#7465625# = Check the locks
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
*7465625*28638# = Auto Network lock ON
#7465625*28638# = Auto Network lock OFF
*7465625*28782# = Auto subset lock ON
#7465625*28782# = Auto subset lock OFF
*7465625*2877# = Auto SP lock ON
#7465625*2877# = Auto SP lock OFF
*7465625*2827# = Auto CP lock ON
#7465625*2827# = Auto CP lock OFF
*7465625*28746# = Auto SIM lock ON
#7465625*28746# = Auto SIM lock OFF
*2767*3855# = E2P Full Reset
*2767*2878# = E2P Custom Reset
Mar 08, 2008 | Samsung Blackjack SGH-I607 Smartphone
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
