Model ddr30b2gdb keeps giving me an error code of EC. I unplug then plug it back in and it works for a little while then error code comes back. What is EC? How do I fix it?
SOURCE:
SOURCE: Machine Error 41
Error code 41, Print cartridge is bad and gone out. Needs to be replaced by authorize dealer for just under $100.00 ($55.00 part & $40.00 Labor).
Posted on Jul 23, 2007
SOURCE: Frigidaire Dishw. Error code CL
this just happened to ours and it turned out to be the gasket that seals the door.
when you see the CL error and the door is indeed shut, pull gently back on the door. if you hear a click and the unit starts running again, it may be the gasket.
ours lost it's ability to keep the seal, allowing enough 'play' in the locking mechanism for it to think the door was not closed.
Posted on Sep 09, 2008
SOURCE: Error message 50c on printer
I had the same error message 50c and "color Ink low". I knew that I still had Black Ink, and that is what I just needed for the moment, so I removed the color Ink cartridge and it started working. You'll get a message 'print cartridge missing' but just press continue.
Hope this helps,
MPTMPeru
Posted on Apr 08, 2009
  • 1015 Answers
SOURCE: F7 code keeps coming up.
The F7 code is due to a stuck button on the touch panel or a bad control module. You will need to unplug the range and remove the back panel. The first thing you will need to check is that the ribbon connector that goes from the touch panel to the control module is seated correctly. If it is found seated correctly then you will need to remove the ribbon connector and try cleaning the contacts with an eraser then re-install the connector and power the range back up. If the error code comes back then you will need to determine if the touch pad or control module is defective. You can do this by disconnecting the ribbon cable and power the range back on. Then wait 24 hours and see if the error comes back. If it does then it is the control module(ERC) and if it does not then the touchpad is the problem. Doing this work will require you to remove the back panel of the range. Make sure that you do not work on the range when it is plugged into the electrical outlet. You can be injured or worse if you attempt to make repairs on the range and you do not know what you are doing.
Posted on Apr 07, 2010
SOURCE: My Service light is blinking and there is an EC 50
Try powering refrigerator/freezer off for 1 minute and then repower back on which will clear the error code. If EC 50 rror code does not come back, it was posible you 1) had a house power failure interruption for a period of time and the compressor had to work extra hard to catch back up. or 2) also check to see that a door is not being held slightly ajar and is being blocked by food making the compressor run too much.
Posted on Jun 16, 2010
Kenmore Elite Microwave Model No: 79080373310 giving E-11 error code
I do not know what an E-11 code is on that unit. But the fact you say no buttons are working gives me a clue that you may have a bad touch panel. Could be a Goofed up Microprocessor on the board. A Lot of units will give a code for a bad pad. If an air pocket in a pad colapses, the microwave thinks you are pushing and holding down a pad, so it will give a error code. An E-11 code may mean a bad touch panel on your unit. Try to unplug the unit, give it a minute and plug it back in, try to set the clock first and see what it does. When setting the clock try all of the number pads and see if they all respond. If one doesnt that mey be your bad pad. Or if a number comes up on its ownwithout pushing it, that pad could be shorted.
Aug 18, 2017 | Kenmore Microwave Ovens
Washer has stopped at the end of the agitation cycle. pressing on the custom memory buttons or any other buttons did not change anything.
Error codes? Owner's manual troubleshooting? Warranty? Call MFG customer service usually they are helpful.
Mar 04, 2015 | Washing Machines
I have a ge air conditioner model AHM24DPH1 WITH an error E2 / E1. What do I do to possibly fix.how do I reset maybe
E1 is humidity sensor error unplug unit and then plug it back in.
E2 is Temperature sensor error unplug unit and then plug it back in this will clear codes. if codes come back on then you will need to replace sensors.
Jun 24, 2014 | Heating & Cooling
EC ERROR CODE
It means the unit is low on gas
May 19, 2014 | Midea Heating & Cooling
Ge pss26sgpass keep in defrost error code bc ?????
That is actually a "tc" error code.
This error means that the display board isn\'t communication correctly with the temperature control sensors which is why it\'s giving the error. It may stop cooling so you need to keep an eye out. Either way, try to unplug the unit for 5 minutes (don\'t plug it in early it\'s hard on the compressor). Plug it back in and see if the error goes away. If it doesn\'t, you need to order and replace your display control board because it\'s just not working correctly unfortunately.Here is the board to order.
Dec 01, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Keeps coming up paper jam code 3528 new printer no paper in back cover removed no jam found
There may be a small piece of paper in the back that is causing the sensor to give you the error message.
Printers give jam messages when a sensor is being blocked by and object.
If there is no paper causing this, you probably have a sensor problem.
Try unplugging the printer and plugging it back in.
Mar 02, 2011 | Office Equipment & Supplies
Superbox problems ...screen keeps saying that data is being updated...and screen remains blank!! Help!
unplug the box and when you plug it back in press menu and then key in 1570 and when the other menu comes up press nagravsion and then key in codes 00-- b0 b8 4f 04 e6 5f 87 80
01--a3 eb ec 07 d6 49 d2 eb
This worked today for me, many thanks
Dec 19, 2008 | StarTech.com StarView SV211K 2-port KVM...
The box super
hi unplug the box and when you plug it back in press menu and then key in 1570 another menu comes up press nagravision and key in these codes 00-- b0 b8 4f 04 e6 5f 87 80
01--a3 eb ec 07 d6 49 d2 eb press ok to store and then exit
Dec 19, 2008 | Televison & Video
Machine Error 41
Nov 14, 2006 | Brother IntelliFAX 1800C All-In-One...
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
