Question about Electrolux Washing Machines
Electrolux wascator w160 stuck in the middle of a program Machine stuck on rinse
    Top Expert:
  • Electrolux Master
  • 10,321 Answers
See if belt under unit bad or agitator cogs under agitator first see if pump and hose ok
Posted on Oct 19, 2019
4 Suggested Answers
SOURCE:
SOURCE: Hi, I have an Electrolux
Hi.Is it in working order?
Posted on Feb 01, 2011
SOURCE: i have a electrolux w 160, i need electric diagram
Give me your email address and I can send you the full service manual.
[email protected]
Posted on Mar 28, 2011
suga_tatto10
SOURCE: We have an electrolux Wascator
I T3530 electrolux drying machine when the machine starts working , the only fire flickered about 5 seconds the fire dies and the lights lit reset button , if pressed the reset button again his lights off and returned fire flame me ,
Posted on Nov 20, 2015
I have this wascator. And I need the manual.
try here http://www.laundrysystems.electrolux.no/Files/pdf_files2/ljungby/service%20manual/SM_438920151_W365_3300H_Clarus_EN.pdf
Feb 10, 2015 | Washing Machines
Doesn't work after storage
First if the water tank is fitted correctly.then run the rinse and descaling program to clean the machine.
Also check the display if there is any error code.
Oct 26, 2017 | Electrolux Coffee Makers & Espresso...
Electrolux EWF1074 7kg washer stuck on drain cycle
The first thing I would check is the drain line, not for a blockage but to see if the drain line isn't pushed down in the drain so far that its below the level of the pump. If it is you'll have a siphon effect going and the machine will never advance past rinse
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 26, 2012 | Electrolux Washing Machines
We have an electrolux Wascator T3530 . It is showing a fault F1 on the display. What does this mean?
First thing you can try is to unplug the dryer for fifteen minutes or so. If that still bring up the error code then it is your board inside your dryer.
May 03, 2011 | Electrolux Dryers
My new electrolux front loader is not filling with water during the wash cycle. The clothes are soaked, but there is NO extra water in the bottom of the tub. It does have extra water in there during the...
front loader washers fill accourding to how big the load size is on all front load washers.There should be no water above the center with a full load.If it is spinnig out and draining then it is working properly:)
Apr 21, 2010 | Electrolux EIFLW55HIW Front Load Washer...
Unusual display on panel (padlock) machine can't be programmed door is not locked however
i just went through the same thing.......you need to hold the option and extra rinse buttons simultaneously for 6 seconds, this will unlock it.....so turn the machine on and press the two icons, dont worry about the beeping and flashing after 6 seconds the padlock symbol will go and you can use the machine as usual.....i wish they put that 'minor detail' in the manual...cheers!!
May 31, 2009 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
Top Electrolux Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Poppa Maddo
Poppa Maddo
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
