My machine keeps stopping during its cycle with error codes. I cannot complete a full cycle without having to keep turning it on again after each error message. At least 3-4 error messages per cycle?
    New Friend:
    Problem Solver:
  • 9 Answers
To help you, you must add the brand, model, and error codes that come out
Posted on Oct 09, 2019
SOURCE:
  • 74 Answers
SOURCE: Washing machine keeps stopping
pull the machine out and put the drain hose into a bowl to empty the water out when you have emptied it try cleaning the pump filter and check the drain system for blockages if that is ok then it looks very much like your door interlock is duff good luck and rate me.....
Posted on Feb 17, 2008
  • 42 Answers
SOURCE: aeg electrolux error message E20 has just flashed
it might refer to any blockage in the water supply. So cleaning the pump could primarily resolve this. but it might also be a blockage in the soap tray (when available), the tap or the hose attached to the tap or the air-gap or any water control structure. but most of the times, it is simple blockage of pump. just pull out the manual, remove, clean and replace the pump. this will solve your problem.
cheers
Posted on Jul 26, 2009
barkencoa
  • 3463 Answers
SOURCE: F-08 Error message keeps appearing
Error code F08 indicates that the heater relay cannot be activated.
Check connections on
1--pressure switch.
2--heater element.
3--control module.
If you still cannot get it to work, then you are probably going to have to call an engineer.
Please rate my solution.
Thanks.
Posted on Nov 23, 2009
  • 119 Answers
SOURCE: KEEP GETTING E70 MESSAGE
Are you sure its a E70? If so, the hot and cold lines are reversed.
Posted on Apr 26, 2010
SOURCE: SAMSUNG 845 - ERROR MESSAGE HE2 - not in manual
heater or wiring
Posted on Aug 19, 2010
Kenmore Front Load Washer won't complete cycle F06
Have you cleaned your machine lately? They make an in wash boost- it gets rid of the extra suds built up inside the machine that you cant see but your machine detects it and causes faults such as that. Also, there is a small wire on the control board that may need replaced if it keeps kicking the error code.
Apr 07, 2016 | Kenmore Elite 45986 Front Load Washer
Fisher and Paykel 7.5 washing machine keeps powering off during rinse and spin cycles
The pump has a thermal safety cut out on it.
If the pump gets too hot it cut out.
Just put a new pump in and your all going again.
Aug 05, 2012 | Fisher and Paykel Washing Machines
Keeps stopping during wash cycle
Hi Kathy,just read your posting.When the machine stops during the cycle does the machine beep and show an error code?Could you confirm the model number of your machine.Now if you have an LCD screen on your machine the fault code will appear in it but if you have no screen then the error code will appear as lights .These lights will be a row of 8 lights.Starting from the left to right which lights are on when the machine is beeping.Is it the 2nd and 4th or the 1st and 7th ---etc---?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Sep 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool Duet washer, during the wash cycle, get H F error code
Hi
Thanks for using FixYa. Error code F/H means no water was detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. It can also happen if the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. You’ll need to Press PAUSE/CANCEL twice to clear the display. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 31, 2010 | Whirlpool Washing Machines
Getting a code F then H
Hi, "FH" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. Check whether the water taps are turned on sufficiently, the inlet hoses are not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
Apr 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code F H keeps being displayed about 8 minutes into a cycle. What do I do? Please help laundry is mounding up!!!!
flashes if the washer loses power during a running cycle. The washer does not flash FH" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost
-OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Mar 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
"F" error code in WTW6600SG1 Cabrio Washer
I don't have a solition and am looking for one my duet whirlpool keeps coming up code F
Jul 07, 2008 | Whirlpool WTW6600SW Top Load
Washer keeps stopping during any cycle
the humming noise could be from two sources and it is worth while doing a few simple checks first the drain pump is jammed with a foreign object. check nothing caught in the impellor second water not available - check taps turned on. also turn water off, undo fill hoses, put in a bucket and turn water back on try on drain or spin programs to check water drainage as well
Jun 19, 2007 | Tecnik TKL9260 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
