Question about Cell Phones
How do I put a widget on my lock screen - Cell Phones
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 25 Answers
Sentuh yg lama pada ikon gambar, lalu gulir ke kiri atau ke kanan.
Posted on Oct 09, 2019
    Master:
  • 408 Answers
Hold your finger on an area of your home screen that doesn't have an app on it already.
The widget option will pop up on the bottom of your screen.
Select the desired widget and place on home screen
SOURCE:
Restoring date, time, temperature on home page Samsung Tablet st330nu
Press and hold on the home screen, then select Widgets.
Scroll through the list of widgets until you find the one you want, then press on that widget to put it on your home screen.
Dec 30, 2017 | Samsung Tablets & eReaders
Tip
How to edit / remove the Attribution Widget from a blogger page
Most if not all blogger templates come with a attribution widget that you are unable to remove however you can edit it although this is limited and you need to know where to look on the HTML template.
When you have completed this simple edit you will be able to remove the widget like all the others.
First search for these lines of code about 3/4 way down the template.
With the older templates all you need to do is to Comment-out the code that displays the Attribution gadget, by putting it inside these characters <!-- --> so it ends up looking like this you must also make sure that you have checked the Expand Widgets Box. Accept it then save the widget.
Then save the template and that is.
In the newer XML all you need to do is to change the locked='true' to read locked='false' this will allow you to remove it should you choose to.
on Jul 12, 2010 | Google Chrome
How do I get rid of a silly graphic weather widget which overrides my weather photos after I accepted it?
Adding & Removing Widgets and Items from iOS Notification Center
Don't care to see Reminders or Stocks in your Notifications screen? You can add or remove anything:
  1. If you haven't already, unlock the iOS device swipe down to bring about Notifications panel
  2. Select the "Today" tab and choose "Edit" at the bottom of the list
    • Delete Widgets from Notifications: Tap the red (-) minus buttons alongside items to remove them from the Notification panel
    • Add Widgets to Notifications: Tap the green (+) plus button to add a widget to Notification Center
  3. Choose the "Done" button in the upper corner to set the changes in place
Any adjustments made to Notifications Center here will be visible when accessed from either the lock screen or elsewhere in iOS.
Dec 07, 2014 | Apple iPad 32 GB WiFi Tablet PC
Blinkfeed is hard to customize and would be better as a widget I could access so it doesn't take up my limited number of five screens. Can anyone help me remove BlinkFeed from my screen options?
With my phone I think blinkfeed is annoying. I just held the screen and opened the widget tab, put the home page as a blank page, put the clock widget and then added my own icons and widgets and such. Put blinkfeed far away to the left. works better for me looks more like my htc one x
Nov 07, 2013 | HTC One
HOW CAN I REMOVE WIDGET FROM MY SAMSUNG GT C6712 ON SCREEN
I think the Widget in the Home screen is in-built.
Just click the widgets button, you can see the bottom, available widgets appears... just drag and Drop widgets to keep in screen and remove from screen.
Jul 23, 2011 | Samsung B5722 Cell Phone
Lost my original clock how do i get it back
You can restore the clock using the same procedure as putting any widget on your phone.
Go to the screen where you want the clock and then do a "long press" on an empty portion of the screen. Basically hold your finger on the screen for 3-5 seconds until the widget menu appears.
- Tap Widgets (it may be under a separate menu like "Sense Widgets"
- Scroll to the widget that you want and tap to select it. If there are any customization options, they will come up now. Choose the options you want and then select Done. Your widget will now be on your screen.
You can move your widget by doing another long press on the widget and dragging it where you want it and then releasing.
Mar 06, 2011 | HTC Desire HD Cell Phone
How do I delete widgets off home screen if I have put them on by mistake
Just tap and hold the widget you need to remove.Then you will get a remove option below the screen ,drag the widget and put in remove.This will remove the widgt you need to remove.
Thank You
Jan 05, 2011 | HTC Wildfire Cell Phone
How do I remove and manage widgets from my home screen? Also, how do I delete the photos and music that is already on my phone?
To remove widgets from your screen, long hold the widget, and drag to the Remove button at the bottom of the screen.
To move a widget around, long hold and drag the widget to a different part of the screen. If you want to drag it to a different screen, use your track ball while long holding the widget.
To add a widget, press on the (+) button and the select HTC Widget or Android Widget.
To remove music and wallpapers (which are stored on your SD card), you first need to connect your phone to the computer via a USB cord. On your phone, go to your notifications screen (swipe down from the top of your screen). Select "Mount" and your computer will now recognize your phone as an external storage device.
The music files are in the Music directory, and the graphics are located in the Wallpapers directory.
Remember to Turn off USB Storage by going through the notification screen again.
Hope this helps and good luck.
Jan 13, 2010 | HTC Hero Smartphone
How to disable airplane mode
the hero has some setting widgets you can put on one of your screen to get to these settings very quickly and easily. no more needing to go into the settings and hunting them down.
go to add (+) > htc widget > settings > airplane mode.
there will now be a widget you can push to turn on airplane mode on and off. you can also put the others on your screen as well. turning these widgets off will also save your battery life.
Nov 05, 2009 | HTC Hero Smartphone
Can't get a Widget back!
This should help you...
Open your widget bar by touching the "W". Once it's open, add all of your widgets to the home screen. Stack them from top of the screen down. that should allow you to scroll down to the one you can't get to otherwise. Now simply move that one up higher, then begin to put back the ones you don't want into your widget bar in order from bottom to top. Once you have them docked back where you want them, click the "X" to close the widget bar.
Problem should be solved.
Jun 26, 2009 | LG KC910 Renoir Cell Phone
Cell Phones Logo
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
