Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
My red ink will not come out
My red ink won't come out, I was told I needed a purge, as the telephone support line had me try everything and this is the last shot I have. I voided my warranty when I filled my ink cartridges with ink from the local ink spot, and cannot afford to pay a tech to service my printer. Help!
  • Broke Guy Dec 13, 2007
    The purge did not resolve my problem, but I at least know what is the most likely issue. Thanks for your timely response, Mix-it-up.
  • 832 Answers
The big prob with generic ink is that some additives are missing which are needed to keep the ph working.
try this:
press menu then start bk copy then 4 times arrow up. machine will be in maintenance mode. press 7 then 6 then 4 then OK or start bk copy. machine will supply fresh ink to tubes and ph. when finished press 7 then 6 then 3 then ok or start bk copy. machine will run a power purge. leave maintenance afterwards by pressing 9 then 9. Do run a test print by pressing ink etc.
If there is still no mag. the valve or part of the ph is rotten and cant be fixed anymore!
Posted on Dec 13, 2007
How do i need to purge the ink lines on an epson 3880
Purging Procedure - If you have just installed a new archival or Quadtone cartridge you must purge the Epson print head of all of the old, non-archival, ink before you can begin to print with the full archival effect. The print heads in the Epson 200/400/440/500/600/640/740/800/850/860/900/1160/1520/Photo/Photo 700/Photo EX/Photo 750/Photo 1200 printers hold about 3 to 5 pages worth of ink. Always run a Nozzle check before printing. Even if you get a perfect nozzle check on your first try after putting in a new cartridge, run at least one or two head cleaning cycles. This will prevent any excess ink from over filling the print head. After the cleaning cycles, use the purging test patterns below to purge your system of the old ink. After printing about 5 (8.5x11) pages of this pattern, 98% of the old ink will be gone. The rest will come out slowly and may take as many as 20 or more pages, but at the 98% point you will see good results. If you have an Epson 3000, 5000 or 9000. See below
Sep 11, 2015 | Epson Stylus Pro 3880 InkJet Plotter...
My printer wont print any yellow.everthing else is fine .the test print page is good exept there is no yellow test print on it
Hi Geoff, geez is been a while since i worked on a 110..... we were forever replacing heads on these under warranty from them getting stuffed from dodgy inks letting air in ink lines...
Chances are the head is requiring replacement which is not economicial to do, please ensure you using a full genuinne yellow brother ink and try to do a initial purge on the head ( i think from memory its..menu * 2, 8, 6, 4 then 76 enter, and 4 enter/ok ((init purge/all)), this will chew ink but fills the head and ink lines.
If it still fails the head is broken, it is like a micro toaster element and the ink keeps element cool, if air gets in the ink line the head overheads and the element breaks in any of the four colour chambers. This is not a repairable part nor is it cheap or easy to replace and also requires programming and a purge of about 1/4 of each colour ink.
Please let me know if you can do a purge and what brand inks you are using and what inks and what happened prior to the yellow issue.
Cheers
Steve
Oct 05, 2011 | Brother DCP-110C All-In-One InkJet Printer
I keep trying to fax a letter and it won't do anything? I thought I put everything in the right order? If it is low on ink will it still go through as a fax. I have a Canon MX340. What can I do?
Yes the low ink has no bearing on why you cannot fax.
First check that you have the telephone lead plugged into the "Line" socket and not the "Tel" socket. Place your doc on the feeder and select Fax. now dial the number and press black start. All should be well and it should go.
May 24, 2011 | Canon PIXMA MX340 Wireless Office...
Our Brother MFC-490CW printer prints yellow, blue and red but won't print black even though we just replaced the black cartridge. We've checked everything about the new cartridge -- we took off the...
you have air in the air line tubes. you can try doing a couple cleaning, wait 24 hrs, and try a couple more cleanings and then do a test print.
you can try doing a ink purge, but it will **** up a lot of ink, but it might be your last resort.
press menu, and then *2864 quickly, then type 76, use the arrows to select black and then press 0.
when all done press 99 to exit.
It may work it may not, its possible you may even need to do it again, however, your inks will be depleted.
Aug 12, 2010 | Office Equipment & Supplies
Most of Group 1inks,(except red) won't print
Over on the right is not waste ink pads, waste ink is under the print engine covering the whole bottom of the printer. On the right is the purge assembly and there is ink on the filters on top and on the squeegee that wipes the printhead. You may need a new purge assembly, or just re attach a hose in the purge unit that may have come off. That printer is well worth the repair...
Sep 10, 2009 | Canon i9900 InkJet Photo Printer
Emissions purge canister
if I remember these juice cans as I call them did have two hoses that were conected to the can and back to something I just dont remember that far back with out looking at the engine area.
Jul 23, 2009 | Chevrolet El Camino Cars & Trucks
My printer told me it was out of ink on the yellow and photo cyan. So I replaced the cartridges with brand new genuine hp cartages. and it still tells me I'm out of ink but only on those two colors. Any...
I have a reset procedure posted on my web site at: www.ccl-la.com/hp.htm The reset works on several HP inkjet printers. The problem is air in the ink feed tubes. The reset purges the lines. This should get you back going.
Buddy
Corporate Computer
Jul 20, 2009 | HP Photosmart C5180 All-In-One InkJet...
Brother MFC 5840 won't print red. ink is full. printer head clean
If the regular cleaning does not work, you can try the power purge. Perform it by doing the following:
  • Press Menu, 2, 8, 6, 4 quickly (within about 1-2 seconds from the menu-press, all five buttons should been placed, in order).
  • The display and some buttons should start flashing, and it should say "Maintenance".
  • Press 7, 6.
  • It should say "CLEANING ALL", press right arrow key until you get "CLEANING MAGENTA" or similar.
  • Press 3, it should now change to POWER_P or P_PURGE. Press Mono/Black Start.
  • The display should say "Cleaning", when it's done, it will say Maintenance again.
  • Press 99 and you will leave Maintenance mode, you can now try and see if magenta works again.
If it doesn't work, you'd probably need chemicals to clean the ink tubes. But, this power purge should work.
Jun 05, 2009 | Brother MultiFunction Center MFC-440CN...
Red lines keep printing through all text of my print-outs. I've tried everything suggested in the manual such as cleaning and alignment an I still get red lines wherever there is text.
There is a spong that catches the ink when doing a head clean. I took some Q tips t soak up some of the ink from within the spong. Try to clean as much as you can from the spong. Even use a soft rag iif possible. You also may have to change the brand of ink that is being used.
Sep 06, 2007 | Epson Stylus Photo R200 InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
107 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
