Washer will not agitate with full loads
I have an older Whirlpool washer that will not agitate full loads unless you are pushing down on the agitator. It is a heavy duty super capacity, about 8-9 years old. It will agitate smaller loads, otherwise no problems.
  • tlbranc Dec 12, 2007
    Throwing it out or wasting water is not a solution. Thanks.
You have to replace 4 plastic PIECES located inside the housing of the agitator. 443-522-7619 (FLOYD) for further assistance
Posted on Oct 26, 2014
  • 25 Answers
Getting old - thow it out or just use small load
Posted on Dec 12, 2007
Whirlpool ultimate care II agitator seems as if it is not woking properly
this is for the whirlpool washer,if you grab the top of the agitator can you spin it both ways without it grabbing,it should only spin one way,if you can spin it both ways you have bad dogs,the agitator cam kit part number is 285809 and it's around 13 dollars.pop off the center cap of the agitator,remove the 7 1/6 inch screw in the middle and pull off the top of the agitator to get at the dogs,you'll see them there are 4 of them,they waer down and the top of the agitator doesn't work.watch this video.
http://www.youtube.com/watch?v=ensJz0h6wLM
Jan 10, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Does not agitate unless pushed down on
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
First, I'd pull the agitators and check for worn or damaged splines inside the agitator or on the agitator shaft.
Following is a description of how to take them out.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the agitator and shaft are OK, the problem may be in the transmission.
See the following Whirlpool / Kenmore installation and service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I'd also look at the troubleshooting section of the manual.
Starting at page 10, you'll see a description of how the transmission changes from agitate to spin mode.
The key (and likely problem) is the "agitator spring".
The spring holds the agitate gear down so that the two sets of splines on the agitate gear are connected and the agitate rack can turn the agitators.
See the following Whirlpool parts list for a blow-up of the transmission and how the various gears and springs connect.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
See the following for how to remove the transmission and clutch.
Tearing apart the transmission is a bit messy but if the problem is the spring or agitate cams, it's a lot less expensive to fix than a $170 transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight gear oil.
Remove the transmission cover and drain the oil.
Pull off the spin pinion.
Carefully remove the clip that holds the main Spin Gear on and remove it.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
Check the spring, Agitate Cams and the cams in the Neutral Drain Assembly.
Re-assembly is obviously the reverse of taking it apart.
Dec 12, 2010 | Kenmore 22422 Top Load Washer
Our older top loading Whirlpool washer skips FILL
It sounds like you have a timer going bad.
Mar 06, 2010 | Washing Machines
My 80 series kenmore washer will not agitate unless I push down on the center of the part that agitates. it pins fine. is this something I can fix myself? is it worth fixing or should I look at replacing...
This problem points to a couple of places:
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
In answer to your other questions:
If you're reasonably comfortable with tools you can fix it yourself.
When we had a problem with ours, we ended up spending less than $30 replacing the agitate cams, neutral drain assembly and oil instead of $170 for a transmission. It was worth fixing.
As an aside, tearing the washer apart will give you the opportunity to completely clean it.
Oct 24, 2009 | Kenmore Washing Machines
My washer wnot agitate unless i slam lid
is the lid up during the filling process? the new washers will not agitate unless the lid is down. no need to slam the lid.. There is no pin to push the activator switch.. they are controlled with a magnet...
Jul 31, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Ge whdsr315 top load washer will spin but not agitate unless pushing down on agitator
Sounds like the nut that holds the agitator on to the shaft is not tightend down or the agitator is not fully "locked" into place on the shaft.
Jun 16, 2009 | General Electric WHDSR316G Top Load Washer
Agitator does not agitate unless I add presser downward on the to
There are 3 plastic dogs that have teeth. They become worn smooth and will not engage the agitator. Change these for about $12 and you will be back in business.
Jun 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer does not agitate
Push down on lid to activate door switch.
May 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Trying to change the cam dogs on whirlpool LSQ9659PW2
some of units were pushed together and the tabs were smashed you have to use a flat screwdriver and push them through they may even break but it will not hurt the agitator the tabs are only used in the factor to hld the agitator togethor when not on the machine the bolt does the work after it is on the machine. good luck
Mar 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator slipping
change your agitator dogs in agitator
Nov 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Open Questions:
Washing Machines Logo
193 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
