I have a Kenmore 11066912690 dryer that stops about 15 minutes into the load. If I use the permanent press setting it will run longer, but sometimes still stops. The timer still runs, but the inside stops spinning and the heat turns off. I have checked the exhaust and it is clear. Any ideas as to what to do or replace?
If you are using the sensor drying cyle this could cause the unit to stop. it will detect the most dry clothing first usually light clothes that dry faster.if not and you are useing timed dry the most likely cause is a faluty timer,or a thermostat sesnor is going bad and turnoing off the dryer before the clothes are dry
