Question about Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television
Vertical problem I have a Pioneer SD-582HD5 and the vertical hold on it has been incorrect since day 1. The problem is the top of the screen is always missing in important parts of my tv watching experience such as, well, pretty much any sporting events. I can never see the whole score so I am always guessing how many minutes are left or if I am joing a game in progress I have to guess what the score is. I use component cables so the screen is always in "full" mode which prohibits me from adjusting the V-hold myself. Any ideas?
  • 25 Answers
Should have taken it back day 1
Posted on Dec 12, 2007
Pioneer SD-582HD5 Picture looks 3D with red and blue copies of images seperated on the screen..
Replace BOTH of your convergence ICs they are big black ICs will have part number on them if 110s use 180s.
Feb 18, 2009 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer SD-582HD5 - screen went black, no sound, Poor remote feed
The blue tube might be leaking coolant in the high voltage area, that is the cause of the POP. This repair might not be a DIY because of the lethal high voltage surrounding the CRTs tubes.
The slow response from the remote could be because the coolant has affected the main board where the IR signal are going to the remote sensor.
Let me know if you require further assistance.
Dec 20, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer 58" SD-582HD5 1080i -Rear Proj TV
Like most problems with this model, check and re-solder the connections on the power supply board on the right rear of the tv, just behind where the main power cord goes in. Most problems are around the upper left corner where the white connectors E-12 and others. Check all of them from loose and cold solder solder connections on the board. Hope this helps.
Jun 02, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer 610HD Turns on the will shut off to stand by after 1 second
You have problem in the power supply section of your set. You can obtain a service manual for 12.99 at the following link and they provide free help in diagnosing your problem. They will also email the manual to them if you click n the contact us link and request they email it.Hope this helps.
http://servicemanuals.vstore.ca/
Dec 31, 2007 | Pioneer SD-582HD5 58" Rear Projection...
2 fuses blow on power up
Its the power pack on the system board. It has a short in it and causes the fuses to blow.....if your farmilar with replacing it you can order the part though the manufacturer.
Nov 15, 2007 | Pioneer SD-582HD5 58" Rear Projection...
HV adjust
DANGER do not adjust anything but screen voltage to each gun do this is the only adjustment you need to make
Nov 09, 2007 | Pioneer SD-582HD5 58" Rear Projection...
How to open pioneer sd-582hd5
from back good luck most problems are cold solder connections and i some models you have to replace three small caps in the video circuit
Oct 31, 2007 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer SD-532HD5
This fault happens with just about any tube type projection set. The convergence IC's simply need to be replaced. They are two black, 2"X3", stand up ICs that will start with the letters STK on the surface of them and are mounted up against a large metal heatsink. If you have the soldering skills this should not be so hard for you to do, but please if you do not have the skills or experience to replace these IC's call in a pro to assist you with this repair. Good Luck
Mar 28, 2007 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television Logo
95 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
