Question about Electrolux Vacuums
Electrolux diplomat cord won't retract. It was pulled out too far.
Buffalo12980
  • 625 Answers
SOURCE: Electrolux Lux 7000 retractable power cord
The trim pieces along the sides just pull off seperating the two housings. The back portion where the retract drum is is held by two plastic tangs on top inside. use a screwdriver to pry the ring down to dislodge the tangs. the bottom part will lift off. remove the front part using two screws just below the hinge. the retract has a long coil spring wound around a free spinning hub. there are two "tangs" inside that engage a ratchet-pawl assembly. you'll need to rotate the drum to rewind the spring onto its hub.
Posted on Aug 20, 2007
Agent Don
  • 310 Answers
SOURCE: Hi , I have replaced
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=564353
Generic problem for all Vacuums
Hi, I have replaced
Posted by dryder on May 02, 2008
Hi, I have replaced the electric cord on Electrolux Lux Royal vacuum, but the rewind that retracts the cord does not pull it in. The coil spring looks ok but it will not pull the cord back in, any suggestions please.
Thanks Dave Ryder
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The question I have is it the Electrolux or the Royal cordwinder, if the cordwinder is sprung you may have to get a new one or a good used one, it’s been a while since I have done a cordwinder and I have seen it done, but I know when you remove the cordwinder you need to lock in the spring so that it does not loose it tension and re-coil ability. You may want to ask your local vac dealer to see if you need to repair or replace. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.royalvacuums.com
Customer Service
For help with a model that is not working, if you want to check an order, if you need help finding a part or service center or have any other comment, complaint or question that is not a technical question about this web site use the link above. You can also call our Customer Service department between 8AM and 7PM EST Monday through Friday at (800) 321-1134.
http://electrolux.com Customer Service
Electrolux Home Care Products – North America
PO Box 3900 Peoria, IL 61612
1-800-896-9756
Don – The Vac Man
Go Ahead. Use Us.
Posted on May 02, 2008
I own an electrolux ambassador III i spent a lot of money on it and if it broke it i would take it to an authorized electrolux repair shop because it sounds easy to fix them but electrolux vacuums have a complicated wire system and it is easy to mix them up or break is worse then it is to begin with.
Posted on Jul 26, 2008
  • 44 Answers
SOURCE: Power cord will not retract on my Electrolux UltraLux 2000
You will need to take the machine apart to correct this. Open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl covered strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl separates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come off relatively easily, and everything will be exposed. Now, assuming that the cordwinder isn't damaged, you should be able to wind the cord in by hand. Once it gets started it may start to retract automatically. Usually the spring just gets in a bind against the housing when it's over extended, and rolling it in by hand a little will free it up. Good Luck!!
Posted on Jan 05, 2009
  • 373 Answers
SOURCE: electrolux model 1401
try a local vacumn repair center or web site
Posted on Feb 04, 2009
How to fix retractable power cord
this can be tricky and dangerous if you are not familiar.The cord winder had a metal coil system that spins very fast.Sometime people pull the cord too far out causing the coil to seize.To get to the winder slide off the "Electrolux" slide off[located on the sides of the vacuum] Your best bet is to take it to a vacuum repair shop.Before trying anything take a flat screw driver and puch it in the hole where the cord comes out and push it in,sometimes this fixes the problem sorry I cant tell you more as it is hard to explain the procedure....Please be careful.
Feb 08, 2015 | Electrolux Epic 6500 Vacuum
Repair retractable cord
Depending on which model of Electrolux you have and how far out you have pulled out the cord (most of the Electrolux canisters have a yellow tape around the machine end of the cord to alert you not to pull it out any further), you might have to take it apart to fix it. However, the first thing that I would try would be to stand it on the end (the hose end at the top), and pull short jerks on the cord to see if it will correct itself and retract. If that does not fix it, I would stick a screwdriver in the hole where the cord comes out of the machine and attempt to wind the cord reel back up which will slowly wind the cord back up on the cordwinder. This usually cause the cord to wind back up. If that does not work, then the only option is to take the machine apart to fix it.
Dec 11, 2013 | Electrolux Vacuums
The power chord on the 2100 electrolux will not retract
Try standing the vacuum on end, or at a near vertical position, and gently tugging on the cord a few times. This will usually cause it to retract. The problem is usually caused by pulling the cord out too far. Avoid doing this as it can result in disconnecting or breaking terminals and/or wiring.
Jan 12, 2011 | Electrolux UltraLux 2000 Bagged Canister...
My power cord will not retract back into the housing< i would like to open the back of the unit but there no screws or bults to due so. How do you open the back of model c151d
Try standing vacuum on end, then gently tugging and releasing cord. This generally will retract it.
There are many problems that can result in disassembly and reassembly by an untrained person, including shock and fire. For those and other reasons, I don't recommend trying this yourself. Take it to the nearest Aerus Electrolux store for repair.
The back of the vacuum can only be removed by separating the top and bottom portions of the canister. The cord winder will need to be removed and the wires all disconnected. The cordwinder is then taken apart and the cord rewound and set for proper tension for rewinding. If the cord is simply stuck due to having been pulled out too far, this is generally not necessary.
http://www.aerushome.com/storelocator/
Jan 07, 2011 | Electrolux UltraLux 2000 Bagged Canister...
How do I repair my Electrolux Lux 9000 cannister electrical cord retraction? It was pulled out as far as it would go and now it doesn't retract.
First, try standing vacuum on it's back end. Gently pull on cord and release. Try this a few times.
If this doesn't work, you'll need to take it to an authorized Aerus Electrolux store and let the service tech repair it. Although it's relatively easy to disassemble, reassembling correctly is trickier. I've had several machines come into the shop disassembled because the owner couldn't figure out how to put it together again.
Also, when taking the cord rewinder apart, there's a risk of breaking tabs that hold it together.
Dec 19, 2010 | Electrolux Lux 5500 Canister Vacuum
Eletrolux lux7000 manu and how to retract the power cord?
For the user's/owner's manual, go to the below link, click on the arrow below where it says "Older Models", click on Lux 7000, click on "download". If you want a service manual, they are only available to Aerus Electrolux stores.
For retracting the cord, try tipping vacuum up on it's back end and gently pulling and releasing cord. This will often cause it to retract. If not, keep in mind that the canister portion of this vacuum has a 7 year warranty on it, so depending on when you purchased it, the cordwinder may still be covered. The warranty does not cover normal wear and tear, or abuse. There are other things that will void the warranty.
Nov 26, 2010 | Electrolux Lux 7000 Bagged Canister Vacuum
Cord has been hyper extended, will not retract
try pulling the cord a little, while holding down the cord release button. if nothing happends and it doesn't retract, suggest taking to a service center or your local vac shop for repairs.
Jul 16, 2009 | Electrolux Epic 6500 Vacuum
Automatic cord return
if it is anything like an electrolux there is a coiled spring inside that free wheels around a hub. pulling the cord too far out makes the spring slip on the free spinning hub. you may need to take apart the vac and rewind the spring.
Aug 28, 2007 | Panasonic MC-V9644 Bagged Canister Vacuum
Jun 06, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Vacuums Logo
150 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
