Question about Moffat Half Size Electric Convection Oven 110V w Broiler Single
Moffat Electric oven
We have an old Moffat electric oven and it won't turn on. it stopped working suddenly. Can you advice on fixing it. or someone to contact
Thanks,
  • benz007 Dec 12, 2007
    we can turn the oven light on. but when turning the knob the red ON light doesn't turn on and no heat either
  • Anonymous Mar 18, 2009
    My oven also quit working. And the light doesn't work, either (and it's not the breaker)..
  • 25 Answers
Check your breaker
Posted on Dec 12, 2007
Where is the fuses located on a moffat stove
There are none. It is wired into the buildings electrical panel. You have to know where the circuit breaker panel is to find a tripped breaker
Aug 10, 2016 | Moffat E32 Full Size Electric Convection...
Moffat oven fan wont turn off. just keeps blowing cold air but eveything else is working
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
: I offer free advice bcuz God is so good!
Jun 03, 2015 | Moffat Ovens
1965 Moffat Electric Built-in oven - model #21K90. No manual and no information on any of the websites I've searched. There is power (oven light, warmer light, rotisserie, power rack), but clock and...
My father solved this one, those clocks were such a hassle, ours buzzed for days til he fixed it. It requires opening the control panel and bypassing the wiring that allows the clock to turn the oven on and off. Of course you lose this function. Is that the complete model number?
Oct 26, 2013 | Ovens
Oven won't turn on because someone played with timer
Try turning the mains supply off and it will probably reset everything.
Feb 01, 2018 | Moffat Ovens
My oven stopped heating, and the range element won't turn red when you turn it on but it does have some heat coming from it. What's wrong with it?
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101 [
Aug 08, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Oven rated for 208 voltage 220 volts available will this work or will I cause trouble
Yes it will work.Its nothing to worry. If the oven voltage is high and house old voltage is less then it will not work. But in your case its oven volt low and hose volt high.You can use it.Its a standard volt,you can use it. 'Most" equipment will work with a -15% / +15% voltage variance.--------- thanks.Helpmech.
Feb 05, 2011 | Moffat E32 Full Size Electric Convection...
I have Moffat E32ms 208V ,but my singal fase 240v. What I can do.
Those voltages are interchangable...you can hook it up with no problems...
heatman101
Aug 18, 2010 | Moffat E32 Full Size Electric Convection...
I need a operations manuel for and E32 moffat
Try this site. http://www.moffat.co.nz/Catalogue/SalesPDF/E25.pdf
If this isn't it let me know and I will keep searching. Hope this helps.
Aug 27, 2009 | Moffat E32 Full Size Electric Convection...
Moffat 3000 oven
Can you please provide a Model number. Moffat has a huge appliance line. I do realize this can also either be a gas or electric oven. Possibly E32MS/2 or G32MS/A25 as a model number. Thanks
Oct 06, 2008 | Ovens
Moffat Half Size Electric Convection Oven 110V w Broiler Single Logo
1,281 people viewed this question
Top Moffat Ovens Experts
Bee4Mee
Level 1 Expert
Marvin
Marvin
Lawrence Oravetz
Are you a Moffat Oven Expert? Answer questions, earn points and help others
