Question about Cameras
OUR RESET WILL NOT RESET HAS NEW BATTERIES AND RECENTLY SERVICED ; CAN / WILL YOU HELP
  • Cameras Master
  • 6,086 Answers
A) Please do not shout
b) Without knowing the make and model of camera which you are using, we are in the dark.
Posted on Oct 08, 2019
SOURCE:
My Toshiba TV, Model 57HX81 quit responding to any remote control. How do we repair that or how much will it cost to have it serviced?
Does the rest of the TV work fine? If so, the problem is likely with the remote control. Have you replaced the batteries and made sure they are installed correctly? Did batteries recently leak in the remote to where the new batteries may not be making good contact with the metal springs? Has the remote been dropped a lot? If so, a solder joint may be broken for the IR transmitter.
If you have a universal remote that can be programmed to the TV model, that should make it easy to confirm if the issue is the remote or the TV.
Nov 26, 2016 | Toshiba Televison & Video
Why doesn't our Melex golf cart start after replacing batteries.
sounds like you have either a relay or computer that is bad, needs to be serviced
Nov 30, 2015 | Golf
Coolpix 3100. I changed t batteries recently and since then when I try to take pictures lens closes in and camera switches off. I changed settings but to no avail. I have used same cheaper batteries before...
try some new batteries not cheap ones, if still you have the same issue try to factory reset it, if you will need more help with your camera download a factory service manual from the below link:
http://goo.gl/pVDpD
Good Luck
May 20, 2013 | Cameras
Where do iget clock serviced clock does no run
mcdevito75 here, You can check out the serice repair right here at fixya, bottom of page click on repair service dorectory, then watches / clocks.
Jul 19, 2010 | Seiko Mantel Clock
Display not working after battery change
some have a small reset button on the back where you push it with a pencil tip. That may help!
Oct 28, 2009 | Honeywell Programmable Thermostat Heater
Transmission slips bad on 2006 ford explorer
u will need to get a new one n i could help u out if my dad stills have one from my old ones its still in good shap
Sep 21, 2009 | 2006 Ford Explorer
My remote does not work
Reset remote. If universal remote, put on dvd mode.
  • If your remote has a Reset button, take out the batteries and press the Reset button for 2 or 3 seconds. Re-inset the batteries and try using the remote again.
  • Note: Many remotes have a small hole marked Reset instead of a raised Reset button. To activate the Reset function, you need to push a thin, rigid wire (for example, a straightened paper clip) into the hole to "press" the Reset button. Also, the Reset button or Reset hole may be located under a sliding cover on the lower section of the remote.
  • Remove the batteries and hold down the POWER button for 1 minute. Insert fresh batteries and try using the remote control again.
  • If this does not solve your problem, remove the batteries again and press and release each button on the remote control once, then repeat. Re-insert the batteries and try operating your remote again.
Otherwise you need a new remote. If under warranty call manufacture to see about getting one free of charge. They can also help you purchase a new one if not under warranty.
Jun 12, 2008 | Cyberhome CH-DVD 300 DVD Player
Cameras Logo
22 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
