Question about Cameras
Can I buy the USB cable that fits my computer and the DPF's mini usb port? I have lost mine and cannot download photos to photo frame without it. Thank you.
    Genius:
  • 1,063 Answers
Yes there are a variety of USB cable you can buy, It will be important to know if the DPF has a Mini USB B or a Micro USB B female port, or a proprietary USB port like some Olympus cameras. Once you know what type you have on the unit, then cables are avaialble through your local computer store or Amazon Without knowing make and model its hard to say more.
Posted on Oct 19, 2019
SOURCE:
  • 79 Answers
SOURCE: I just purchased a digital
hi there
your photo frame has not got a built in memory so it can only read pictures from the card you put in and only while the card is inserted. these extra pictures are either on your card, which you can delete yourself via your p.c., or they are stock demo pictures on the picture frame which can't be deleted.if you insert your card before you switch the frame on it should read only the card.
hope this helps
beergut707
Posted on Oct 09, 2008
Bubbabear64
  • 2794 Answers
SOURCE: downloading photos from G1 phone to laptop
At the top of your phone display you will see a USB icon. Click on the top of the screen and mount the memory card. Your computer will recognize your memory card as a disk drive.
Click on my computer and select the letter for the memory card. Look for the photo folder.
T-Mobile is doing an over the air upgrade to fix some syncing problems this week.
Contact 611 from your cell phone and select G1 support for more information.
Posted on Nov 22, 2008
  • 4 Answers
SOURCE: Can't download pictures on the digital photo frame
Try another memory card. Or the frame might be bad. I have seen them not work before. If another card works you might just need to reformat the bad card.
Posted on Dec 27, 2008
  • 58 Answers
SOURCE: DOWNLOAD PHOTOS FROM LG PHONE TO PC VIA USB CABLE
You have to have an SD card and also a port for your computer to read SD Cards. You could send them through pic message but that takes awhile. Good luck.
Posted on Jan 11, 2009
  • 53 Answers
SOURCE: Can't get photos from MAC to load to Digital Photo Frame
To connect to a Macintosh computer:
1 Plug in and turn on the digital picture frame.
2 Connect the small end of the usb cable to the usb port on the side of the digital picture frame.
3 Connect the larger end of the usb cable to a USB port on your Macintosh computer. The Macintosh will recognize the digital picture frame as an external storage device, and an icon will appear representing the device.
4 Drag and drop your photos on to the icon...
5. After you finish, press the eject button, and disconnect the usb cable once the icon has dissappeared
If there is still a problem, try restarting the macbook. and make sure no other programs are running in the background that may interfere with the process. Also, make sure the laptop is plugged in, or the battery power is sufficient.
Hope this helps!
Let me know!
enov8
Posted on Mar 04, 2009
How do i transfer files from my cobra digital mini 150 to a pc?
Yes purchase an USB micro SD card reader.
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Dec 09, 2012 | Cobra Digital Mini 150 5.0 Megapixel Mini...
How do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of digital photos. You can view photos with or without a computer using just a memory card, but it's always a good idea to transfer the photos you'll want to view frequently to the internal memory of your frame. This is also a handy way to back up your favorite images.
  1. Transferring Photos from a Memory Card
    • Your digital photo frame's built-in software will recognize six types of memory card: CF I/II, SD, MS Pro, MMC and XD. Locate the slot on the back of the frame (to the left of the stand) that corresponds with your type of memory card. These are labeled as follows: SD/MMC/MSPro/XD, CF I/II, USB and mini USB. Insert your memory card into the appropriate slot, power on your digital frame, and it will automatically begin a slideshow using every available image on your memory card. Note that only JPEG formats under 16 megapixels are compatible.
    Transferring Photos from a PC
    • Use the USB cable that came with your frame. Connect the mini USB end to the mini USB port on the back of your frame; connect the large USB end to your computer's USB port. Double-click the "My Computer" icon on your desktop or in your Windows "Start" menu. You'll see that your computer has automatically assigned a drive to your digital frame---look for a device called "Removable Disk" followed by a letter (Removable Disk E:, for example). This is the folder that represents the internal memory of your digital photo frame; you will be dragging your photos into this folder.
      Next, open the folder in which you store your photos ("My Pictures," for example). Select the photos you want to transfer to your frame. Drag them to the drive associated with your digital photo frame---this is the "Removable Disk" drive you located within the "My Computer" folder. Every photo you selected will then be copied onto your digital frame.
      After the files are copied, disconnect your digital frame properly. If you don't, your frame's internal memory could be damaged. Look for the system tray in your desktop's lower right-hand corner. Left-click the icon that shows a gray box with a green arrow on top of it. Select "Safely Disconnect Hardware." A dialog box will appear, asking you to select the device to disconnect. Select the digital frame and click "OK." When the dialog box appears, click "Close." You'll see a message in the lower right hand portion of your desktop telling you it's safe to disconnect your frame.
    Copying Photos to Your Frame's Internal Memory
    • You can use your frame's remote control to copy photos from your memory card or computer to the photo frame's internal memory. Connect your photo source (computer or memory card) and have your frame's remote control handy. Access the "Home" screen on your frame using the "Home" button on your remote control or by pressing the "Home" button on top of the frame. Next, choose "Photos" and press "Enter." You'll see all your photos in thumbnail form. Scroll through them with the up and down arrows. Press the "+" key to mark photos you want to copy (use "-" to de-select a photo). When you've selected all the photos you want to copy, press "Set Up," then "Copy Photo," "Enter," "Selected" and "Enter." A dialog box will ask you to confirm your selection; with the cursor on "Yes," press "Enter." The photos you selected will be copied to the frame's internal memory.
Dec 04, 2011 | PANDIGITAL 7270FW Tablet
I can't find the cord needed to download photos to my DPF -0802 can I get a replacement ?
Go to any place that sell cables ( Best Buy, Staples etc) and ask for a
USB to Mini USB cable ... about $10
Aug 03, 2011 | Westinghouse DPF-0802 Digital Picture...
How do i download photos from pc to digital photo frame
1. Connect the digital photo frame to an available USB port on the PC. Turn on the PC and the digital photo frame. Connect one end of the USB cable to the USB port on the digital photo frame (this end is usually smaller) and connect the other end to the USB port on the PC itself.
2. Wait for the PC to automatically detect the USB-connected digital photo frame.
3. Move any photo files that you want to display on the digital photo frame. Do so by copying and pasting each file into the connected USB device that you can view in "my computer". Many photo frames have built-in memory for this feature.
Jan 07, 2011 | Microsoft Computers & Internet
Uploading photos
Both the thumb drive and the picture frame are USB slave devices, not USB masters. They both need to be connected to a USB master in order to transfer files.
Do you have a standard USB cable from some other device, any other device? If so, that should fit into the picture frame. If not, you'll have to buy one.
Connect the thumb drive to your computer. Create a folder on the computer and copy your photos to that folder. Then connect the picture frame to the computer and copy the photos from the folder to the frame.
If you have two or more USB ports, you can skip the folder and just copy photos from the thumb drive directly to the frame.
Jun 04, 2010 | Pacific Digital MemoryVue MV-800 Digital...
Westinghouse DPF-01411 Digital Photo Frame
Things I have learned after messing with 3 different Westinghouse DPFs (1 -14" & 2 - 10").
1. Just tap the buttons. Exit first and then Menu or one of the other functions. Holding them down too long seems to nullify the functions. Only the Power button needs to be held down for a second or two to turn the device on or off.
2. Use a USB to mini-USB cable to access the internal memory. Expect flakiness when you plug in the cable. Sometimes it will warn the USB 2 device is plugged into USB1 port. Ignore this and just look for a string of removable drive letters to show up in My Computer window. The one named FLASH Drive is the internal memory.
3. I reformat the internal memory (FAT32 seems to work fine) and this gets rid of the troublesome canned pictures that may be causing your lock ups.
4. I have had good succcess the xD memory cards from 16MB to 1GB.
5. I have not seen any prblems with edited photos or long file names - just be sure they are named with .jpg extension and not .jpeg. - go figure?
Hope this helps...
Mar 30, 2009 | Westinghouse DPF-1411 Digital Picture...
Can't find my usb cord to download more pictures. Can I buy a ne
I am certain you will need what's called a USB mini b cable. You can find it at any electronics store.
Rob
Jan 10, 2009 | PANDIGITAL 8.0" Digital Photo Frame...
Downloading from pc to digital photo frame
Solution:
1. I don't think the USB Cable was given to Download Photos from the computer - I think it was given to upload photos to the Computer.
2. The manufacturer has either gave you the wrong cable for a different type of Operating system or you are trying to put it in the wrong port.
Suggestion:
1. Call a Technical Support Line (Probably found on back of instruction booklet.)
or
2. Send the Product back to the company.
Dec 18, 2007 | Cameras
Innovage Digital Photo Album w Keychain driver
Summary of Solutions posted here and elsewhere:
I just received a Innovage Digital Photo Album Keychain as a gift and ran into some of the issues posted here. I am going to summarize the solutions I have come across in hopes they will help others.
Installing/obtaining the software:
The keychain requires you to use custom software to upload pictures. The keychain includes a mini-cd with the software. If you have a computer with a slot loading cd (i.e. laptop, imac, mac-mini, etc) do not try to put the CD into your computer, it may become stuck! Either call the service line and order a full size cd, or try downloading the software from either:
Coby DP-151 software
Digital Foci - Pocket Album software
(While these are different digital photo products, the transfer software appears to be same as the Innovate software)
The software should be installed before you plug in the keychain into your USB port.
Software Issues:
Some users have complained that they can't see the whole transfer window. You might have your screen resolution set too low (like 680x480 or 800x600) try increasing to 1024x768 or bigger.
Finding photos: The software is quite simple, it does not integrate with your photo software (e.g. iphoto) it simple reads image files. You will need to point the software to where your photos are stored on your computer. For most people this is either "My Pictures" or simply "Pictures" folder.
Transferring photos: There have been some recommendations to transfer the photos to the keychain in small batches (like 6-10) rather than queuing up 60 images to transfer all at once. Apparently the software has crashed on some peoples machines when transferring many images.
Device Issues:
Charging: The device has an internal battery, it must be charged via your computers USB port. In must be in the charge mode, it will not charge when it is in the update mode. When you first plug the device into your USB port a menu should come up on the screen. You can use the arrow buttons to change the selection, then press the power key to select your choice. For charging you should select "USB Charge". In this mode the keychain will display images and won't let you power off. The red light will supposedly turn green once the keychain is fully charged.
Transferring images:
The keychain must be in the "USB Update" mode before your software will talk with it. Try unplugging the keychain, plug it back in, wait for the menu, use the arrow keys to select "USB update", press the power button. Now try running your transfer software
Bad USB cables: Many people have reported that the supplied USB cable doesn't work. If you are having problems with charging or transferring images, first try another USB cable from a similar type device if you have one (many cameras have the same sized mini usb connectors)
Hope this helps someone!
Nov 30, 2007 | Baby Gear
Cameras Logo
23 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
