Question about HP OfficeJet G55 All-In-One InkJet Printer
HP OfficeJet G85 print help
How do I set up print order, as in page 1 prints last, Last page prints first. I have been through all the setting etc. and cannot find output preferance. I know it exists, just not where.
Thanks,
Ciawna
    President:
  • 1,901 Answers
When you go to print, select "Preferences". If there is an "Advanced" tab, click it. Look for a menu item "PageOrder". Click it and you should get a drop down menu to change it.
Posted on Oct 15, 2008
Prints last page first
The solution for your problem is simple. When you print you have to uncheck the option where it says "Print last page first". Or use the following steps: 1. Open Microsoft Word
2. Open the document to be printed
3. Click the Tools menu
4. Select Options
5. Click the Print tab
6. Check the Reverse Print Order option
7. Select OK
If you need further assistance, just leave a comment.
May 23, 2010 | HP Officejet 6310 All-In-One InkJet...
HP officejet 9130 printer: pages keep printing
Yopu can change the rprinting order from the Print Dialogue box or Printer driver.
Look for the following to change page grouping when printed
and the followintg to change printing from first to last and last to first pages
Nov 13, 2009 | HP OfficeJet 9130 All-In-One Thermal...
Prints backwards
You mean your printer prints from last page to first page, right?
Check your printer settings/preferences and change the page print order settings.
You can change the printer preferences from most Windows applications (click File/Print ..., select you printer, then click on Preferences).
You can also change the settings from Control Panel/Printers or else click Start/Settings/Printers, then select your printer icon and right click on it, then click on Properties and, under the 'General' tab click the printing preferences.
Sep 07, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
My Officejet G85 does not from a document
Ensure it is installed (use the driver CD) and set it as the default printer in Control Panel > Printers.
Jul 08, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
Printed copy in correct page order- HP officejet 6110
Hi :)
This may work and its only a few simple clicks :) but it will take less time then re ordering you pages :)
IN the printer settings or Print preferrences there should be a tab for "Advanced settingings"
Go to Control Panel and select "Printers"
Select the general tab and at the bottom of the window select "PRINTING PREFERENCES"
another window will open
from here select the Advanced tab
Find Layout Options in the list
click it you should see "Page Order" and a drop down menu for front to back or back to front.
switch it to whatever order it is that you need and test it out.
or if that doenst work try this:
Set the most frequently used copy settings as the default. This includes changes to Copy Setup options in the menu system, as well as other front panel copy settings.
  1. Make any desired changes to the copy setup from the menu or the front panel copy option.
  2. Press Menu .
  3. Press 1 , then press 4 . The settings are now saved.
these are the only ways I have found to correct the problem.
May 18, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I keep getting a test page before printing my doc or picture
To resolve test page prints every time issue, perform the steps provided in the below webpage:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01065136&cc=us&lc=en&dlc=en
Now, perform the steps below to change the settings from last to first page:
===== From the HP Solution Center software =====
1. Open the HP Solution center.
2. Click Settings--Print Settings --> Printer Settings
3. Click Advanced Tab.
4. Under layout option select the page order from "front to back".
5. Click OK and try printing.
From application
a) Select tools
b) Goto Options
In that select print tab
c) Check the Reverse Print order option.
d) Click Ok.
Apr 17, 2009 | HP DeskJet F380 All-In-One Printer
CONNECTED HP OFFICEJET G85 DIRECTLY TO LAPTOP, WON'T PRINT
Make sure this printer is selected as the default printer. Check printer preferences to make sure all settings are correct then try printing a test page using the windows software. Hope this helps.
Dec 26, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Hp printer
ok...first thing...go to www.hp.com and download a fresh set of drivers for your printer, and then restart it and see if that helps. I have that happen to my G85 whenever the power gets awful(not saying that's your reason, but can be an issue)..
got backup?
Feb 15, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP OfficeJet G55 All-In-One InkJet Printer Logo
79 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
