Question about Maytag Neptune MAH5500B Front Load Washer
Neptune MAH3000 Stops
I just installed a Waxmotor Kit in our MAH3000AWW without success. Installed the Waxmotor and the Q6Transistor. The R-11 Resistor was not cooked it was exact same resistance value as replacement resistor. Here's the scenario: Our Neptune will start when set to a normal cycle and begins filling and about 30 seconds or so later it quits and the on light goes out. If you move the Timer to Spin and push start the light comes on and the door lock light and locks. The water begins pumping out. It seems to run the pump until all water is out then the machine stops and lights go out. It does this on all cycles and at all settings. Will not spin when timer moved to spin cycle. Do I need to replace the MCU or ???? I believe the Timer is fine. I am capable or troubleshooting.....just not sure where to go next. Thanks, GARY
  • 5 more comments
  • Anonymous Dec 22, 2007
    MAH2000 does the same, starts, slow rotattion for prewash, loud and slow, then after a while the motor kind of whines and kind of gets stuck as if it had centrifugal starters that do not work. Stops and lights go off.
    I changed the board and timer, do not know what else to do.
    any ideas?
    Thanks
  • Anonymous Dec 31, 2007
    I have the same problems and the washer stops and does not spin . Exactly as you described. I thought it was the timer or waxmotor , so knowing you changed it and it didnt work keeps me confused. Does anyone know what to do? I have unpluged and pluged every wire and checked circuit boards. Not sure what to do. My husband can't bend under washer so tring to fix myself.
    I also had the same problem . I heard some loud growling noises and grinding noises now it doesnt spin at all. I thought is was because the load was heavyer then usual. Doesnt seem to work at all now and will start for a minute then shut off on any cycle and does not spin. I have checked through everything. About six months ago this happen and I was checking wires and felt the wire on the back of the motor had loosen (three wire connection) , I pushed it back in and then it worked fine till now. Can anyone help? I dont want to just start replacing parts. Should I buy new washer.
  • G-Mike Jan 05, 2008
    Maytag neptune mah3000aww stops between each cycle and I have to push the start button for it to start again..... HELP!
  • Anonymous Oct 25, 2008
    same problem here
  • Anonymous Nov 11, 2008
    mah2000 stack. Buttermore's in Auburn,Indiana cannot fix, motor and controller, top controller both put in.
  • stereosnd Nov 14, 2008
    Mah 3000 aww. Washer fills for 30 seconds or so and then stops. Replaced the machine control board, still same thing. Motor and motor control were replaced under recall as well as wax motor. I can pull jp4 and set in delay and it tumbles no problem. Help me please.
    Scholar:
  • 79 Answers
You probably need the motor conversion kit 12002039. This Neptune motor / motor control board has a high failure rate. To determine this you need to remove the front cover and inspect the motor control board near the floor on right side for burnt components or a blown 10 amp fuse. If you have burnt components or a blown fuse then your motor control board has failed and needs to be replaced. See www.neptunewaxmotor.com for Neptune disassembly pictures and to order the 12002039 motor conversion kit.
Posted on Jan 05, 2008
    President:
  • 1,314 Answers
Did you just replace the fried part or did you get the board kit guest you may have a bad tacogenerator in the motor check the resistance of the motor
Posted on Dec 30, 2007
My Maytag Neptune Washer Model MAH3000AWW, Serial 35269627WB drains the visible water that can be seen inside the drum, but then does not drain the rest of the water that remains between the drum and its...
Hello, The earlier Maytag Neptune front loaders have a balance ring on the inner tub that has liquid in it and that causes the sloshing sound when you turn the tub by hand. That is normal.
I noticed that you have a MAH3000... Have you replaced your door latch wax motor yet? If not, it will fail and damage your control board located behind the timer. See NeptuneHelpSong for a video that explains the failure.
I hope this helps...
Apr 25, 2011 | Maytag Neptune Washer
Maytag washer wiring diagram
machine start when you push the start button but stops 3 or 4 seconds after the button is released help me dennis montgomery maytag neptune model #mah3000aww
Aug 27, 2010 | Maytag MAH8700AWM Neptune Front Load...
Hi just got a set neptune model mah3000aww the
your main control board and the actual lock,
open the three screws on the top of the control board..
you will see the machine control
without disconnnecting the wires , inspect the board as closely as uou can your looking for physical burn on the board,,,, this usually takes place on the lower left area of the board
there you will see a burnt resistor, r-11
you will need to replace that control http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46137&diagram_id=692382#d692382
the board is 138.00
you will also need to replace the wax motor lock above the door
but is sounds like you just bought them
do you have a wrrenty of sdome kind
if you wish to make the repai let me know i will walk you through it it prety easy but can be tricky
Oct 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
Neptune MAH3000AWW washer will not drain
First and foremost unplug the unit
remove back panel
remove hoses from pump (expect water have towels handy)
open pump by removing screws
remove foreign objects if any
check impeller blades to ensure that they arent worn down
rebuild and reinstall pump
or replace pump reconnect hoses, replace rear panel
you should be good to go
Sep 10, 2009 | Maytag Neptune Washer
Mah3000aww leaking water
You need to replace both tub bearings and the seal. Not an easy job. Good luck, though.
Jun 15, 2009 | Maytag Neptune Washer
Sometimes there is water that fills in my washer after I use it. It does not happen right away but by the next day. I don't know the model but I do know this is an old washer....gold....I have had it for...
Q - My washer seems to keep filling  with water, the water keeps coming in the washer and going out the drain without the washermotor running.
A - This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
  1. Boot change helps
  2. Consumer Display Code Table on the Electronic Display Maytag Neptune Front load washer
  3. Free on-line repair manual for the Neptune washer MAH3000, MAH4000, MAH5500, MAH7500  ( Acrobat reader required )
  4. How to access the console on the mechanical timer models
  5. How to access the workings of the washer
  6. My washer door is locked and it will not open up...HELP
  7. My washer will start when I push the start button, but a few seconds later, it will shut off
  8. My washer will not pump out + pump noise problems
  9. My washer will not spin
  10. Odor complaints from the front load Neptune washer - mildew complaints + a new "freshen up" procedure
  11. Parts breakdowns/exploded of the Maytag Neptune front load washer ( mechanical timer models )
  12. Problem chart for MAH3000 & 4000 Neptune washers
  13. Readers repair tips
  14. Trouble shooting tips from the Neptune manual for MAH3000 and MAH4000 models
  15. Tips from our friendly engineer on changing the boot and re-installing that clamp and spring
  16. Tips on changing the washer belt  ( acrobat reader required ) Belt parts link
  17. Tips that show what components need to be checked/replaced if a certain resistor on machine control board is bad. It is as follows: Burnt resistors in Maytag Neptune washer models MAH4000 and MLE/MLG2000
  18. Washing one item in a front load washer
Apr 01, 2009 | Maytag Washing Machines
Maytag neptune washer MAH3000AWW
order the wax motor kit and replace parts from the internet. there are plenty of videos how to do this. it does require minor soldering and a little mechanical aptittude.
Dec 30, 2008 | Maytag Neptune Washer
Maytag Neptune m/n MAH3000AWW burnt R11 resistor
STOP
There is a short in the door lock (very, very common problem )
Go to ebay and search neptune washers and im sure youll find a site i was selling a kit to repair this. If you cant find it let me know ill look .
Jan 18, 2008 | Maytag MAH6500 Neptune Front Loading...
Stops between cycles
sounds like a bad motor control board. It is located at the front rt bottom and will probably show a burnt spot in it or the fuse will be blown. You must replace motor kit.
Jan 05, 2008 | Maytag Neptune Washer
Maytag Neptune MAH5500B Front Load Washer Logo
800 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
