Question about Nokia N90 Cellular Phone
Restarting after updating my nokia n90 firmware from nokia site .. it began to restart by itself every now and then .. is there anything i can do to solve the problem
  • 3 Answers
Re: restarting
Some thing must have gone terribly wrong and might have affected your SP i should think because I'm having the same trouble with mine and i haven't found a way to fix it
Posted on Jun 12, 2008
0 characters
3 Points
My nokia n90 will hang up and no display after it start
You need to update the phone firmware,take mobilephone to a service center
Nov 26, 2013 | Nokia N90 Cellular Phone
How to upgrade the firmware of my 6680
Please visit the Nokia site and download the software called " PC Suite "
after you have installed PC Suit, Plug in your phone to your computer and find the " Software Updater " option and use that to update the firmware of your phone.
I hope this helps.
May 23, 2011 | Nokia Unlock N70 N71 N72 N90 6630 6680...
My Nokia 5530 restarts itself when i push 'answer' for an incoming voice call and when i make an outgoing voice call it restarts itself. I have tried a factory reset and i can not find a software update.
i have the same problem too. after months of using my 5530, i cant remember having it dropped or anything that can make it dysfunctional during calls.
Dec 06, 2010 | Cell Phones
Nokia 9500 get restart when click Internet Broser / WLAN setting
Your firmware is ANCIENT. If you have installed Nokia PC suite in your PC connect your (fully charged) phone and click on Software update. If don't have it, then go to Nokia web and download it. YOU NEED FIRMWARE UPDATE.
Oct 16, 2009 | Nokia 9500 Communicator
got this from the net, maybe it helps:
The Problem with Nokia 3110c – Switching off and automatically restartingThis is what happens. Nokia 3110 hangs, gets switched off andrestarts randomly. More often, it restarts around 3 times or so andthen gets switched off.
Possible Causes and SolutionsCause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500KB, so as to keep things running smoothly on your phone and preventNokia 3110c from restarting.
Cause 2 – Changing Themes – Some people havereported that the phone restarts automatically when they try changingdisplay themes on the phone.
Solution – Don’t get your phone loaded with toomany themes downloaded from the internet or atleast, don’t switchthemes frequently. These themes, mind you, also load up things intoyour already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB datacable (or) Updating Music Library – A few people have reported thattheir Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but considerconverting all your MP3 music files to WMA and then store them on thememory card. Some users suggested this.
Disclaimer – Follow the suggested solutions at your own risk. The author is not responsible for any damage caused to your phone.
Jul 23, 2009 | Nokia 7610
It may be due to some software errors.Please try reinstalling your phone's software or updating your phone's firmware.
Mar 27, 2009 | Nokia Unlock N70 N71 N72 N90 6630 6680...
Nokia 6030
try giving restore factory settings ... when you give the restore factory settings it will ask for the security code give that and after the restore of factory settings restart your phone once ...
if you still persist any problem ... then you can update the firmware(only if you have the data cable for your cell) by downloading the " nokia software updater" from the nokia site ...
you can upgrade the firmware by downloading the "nokia software updater" from the nokia site given below it is free
firstyou must download that application to pc and then you must the cell topc and then you can upgrade the firmware of your cell ...
NOTE:neverdisconnect or power off during the firmware update this willdamage yourcell phone completely and after that even if you visit thenokia alsothey cant help you with that , so while doing that do it carefully ..
thank you
rate m solution
Sep 14, 2008 | Nokia 6030 Cellular Phone
Constant Restart and problems updating firmware
Try formatting your phone. Turn it off. Then hold the following keys WHILE it's turning back on: (3 + * + green call key). Don't let go till it asks you about your location. Be aware that it will delete everything saved in your phone memory. Let me know how it goes. :)
Jun 25, 2008 | Nokia N95 Cellular Phone
Nokia n90 problem
What version did you flash into it? There are many new updates and if need be we can arrange that for you
Jan 22, 2008 | Nokia N90 Cellular Phone
Nokia N90 Cellular Phone Logo
35 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
