a couple of problems could cause this heating element or possible that one of the thermostats has gone bad.bset thing to do is check the continuity of the element and thermostats.if you meter has a tone one it when you check this they should all have a tone if they are good.if they do not tone out then you have found the problem
Was this helpful?
Yes
No
Popular Solutions for Kenmore Elite HE3 Steam? 8674
Have Kenmore 62812101 on the timer side of the dial dryer works great on the auto moisture sensing...
(More)
Have Kenmore 62812101 on the timer side of the dial dryer works great on the auto moisture sensing side dryer heat up but dial will not advance and wont shut off
Kenmore Elite He3 Model #11092824100 Dryer is no longer heating. Checked vent for airflow , good...
(More)
Kenmore Elite He3 Model #11092824100 Dryer is no longer heating. Checked vent for airflow , good airflow. No error codes on display. How do I access the internal components. (Front or Back)? Is there access through the front of the dryer? Very difficult to move dryer with washer side by side in small laundry room. Igniter? Heating coil?
