Question about 3Com AP2750 802.11a, 802.11g/b (3CRWX275075A) Wireless Access Point
Access Point AP2750 Problem
Access point will work for about 20 min.s then has to be restarted to get to work after this. The Access point is setup with POE connection. Have over hundred that work no problem with a few only working for short time then needing to be restarted. Any suggestions?
Hi 2bob_watch, I'm having some problems with my AP2750, where did you get the firmware update? I've been searching in google, 3com website, etc but found nothing....
Thank you very much
Posted on Jun 06, 2008
  • 55 Answers
I would try updating the firmware on your router and access point. I had the same problem and did this to both and they are now working fine. Let me know how it goes.
Posted on Dec 16, 2007
Bosch Nexxt 500-series electric dryer problems - Dryer never finishes complete cycle of drying clothes. When attempting to restart, the display will show 20 (mins) even though I've pushed something di
did you clean the LINT filter? try vacuuming the lint trap area. wet or damp lint can get built up in the lint trap area. it is good to regularly clean the area as it is a Major fire hazard.
Mar 12, 2014 | Bosch Nexxt 500 Dryer
How many access point can bridge with tl-wr941nd router
Depends on the access point, and how you configure it. If your access point can do NAT, then theoretically you could have up to 255 access points, each managing their own private network, and connecting to your router on whatever its current subnet is. But, if like most home setups, you just are looking to extend distance capability, then your limit, as a practical matter, is 255 minus the total number of devices you intend to reach. So... if you have 20 devices on the network, you could have 235 access points. Silly, yes, but you could.
As a REAL practical matter, however, consider that the throughput of the main router, the TP-LINK you cite, can probably only handle 20 or 25 TOTAL devices before it slows down to a point of being unusable.
Oct 26, 2013 | TP-LINK TL-WR941ND Advanced Wireless N...
Password and user access point ap 2750
Default Settings for accessing the AP as admin:
  • Default Username / UserID: (leave blank, try admin if prompted)
  • Default Password: admin (lowercase only)
  • Default IP Address: 192.168.1.1
  • Default Netmask: 255.255.255.0
Jun 10, 2011 | 3Com AP2750 802.11a, 802.11g/b...
I had problems with my linksey wireless router. I had to redo the router connection and now i get wireless not in range using my laptop even if i'm using the lapto in the same room. Before i had problems i...
mcdevito75 here, The router signal depends on the 4 sattelites that have to be in range for it to connect to the internet, shut down your computer or just restart your computer. If this doesn"t work un--plug router from the computer itself for 20 seconds and plug in again.
Jul 16, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
(Work this one out) My access point works but I have never been able to set security settings on interrogate it.
try typing 192.168.1.1 in your internet browser..the login and password are usually admin  and admin respectively.you can then configure further settings without using any cd etc.hope it helps!
Oct 22, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
2000 caravan 3.0 stall after 20 min no spark restarts few hours later
This sounds like a bad (probably cracked) ignition coil.
First, the coil gets hot when operating, and this is normal.
If it is cracked, it gets hot to the point where its resistance gets so much higher that it cannot provide enough voltage for spark.
When it cools back down it starts working fine again.
Aug 19, 2008 | 2006 Dodge Grand Caravan
3Com AP2750 Problem
try the manufaturer website first, but if it is Senau ECB -xxxx models, tough luck, they write the worst firmware, lots of it has java errors and is unusable.
Jun 14, 2008 | Computers & Internet
Set up
Hi Rbosley,
I found the real manual here,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&cc=us&dlc=en&product=218413&os=228&lang=en&
Second one down.
Are you using Cable, or DSL. DSL requires you to setup a PPPOE connection, putting in your Username and password for you DSL connection.
Are there any other routerrs on the network? Just making sure you are not trying to use the router then there is one already one on the work.
I would suggest your use the reset button on the back, resetting it to defaults. That way, you should be able to plug in your modem to the WAN port, plug your computer into the LAN port.
Then restart the modem, wait 2 min, power up the router, wait 2 min, and startup the PC. Make sure your IPs are set to automatically get IPs and DNS. The router's DHCP should supply them to your PC.
DSL requries you setup a PPPOE connections, which really just consists of selecting the pppoe option, putting in the infomation, and the doing all the rebooting.
It you still are having issues, get back with us!
Jan 09, 2008 | Compaq iPAQ Connection Point CP-2W...
3Com AP2750 802.11a, 802.11g/b (3CRWX275075A) Wireless Access Point Logo
796 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
