Symphonic WF20L6 20" tv powers down about 30 seconds after turning it on. I found on this site someone said it was the "Power supply faulting for internal problem". My question is how do I get that repaired? Is it something I could do and is it costly?
  • 2 more comments
  • gato bravo Feb 29, 2008
    Eap and bot a power bord for 399 and lasted 1 month and they do not fix it or return the money or replace the power bord very bad company like throu money on the dip river RIP OFFFFFFFFFFFFF
  • schwartzie Apr 05, 2008
    My one year old symphonic WF20L6 tv was fine one minute and the next minute it will only stay on about 5 seconds and shut off. We turned it off for a while and still not resolve. Does anyone know what this might be?
  • Anonymous Apr 20, 2008
    Symphonic WF20l6 flat screen tv, powers down after being on only a couple of seconds. It was fine one day and not the next. tv was less than one year old when problem began.
  • John Hodges Jun 15, 2008
    no power on symphonic WF20L6 wonder if transformer is out and how to get part and replacement instructions
  • 558 Answers
I think the transformers in these units are the problem not the "power board" I have a symphonic that had a bad transformer in it two legs were not putting out any voltage so I replaced the whole main board for about 50 usd. I may put a small fan inside to move some air around that transformer so that it stays cool
Posted on May 04, 2008
    President:
  • 4,402 Answers
One thing you can do is go to radio shack and buy a can of freeze, spay individual components in the power supply till the tv stays on as long as you keep the part cool.
Posted on Dec 12, 2007
Panasonic TV TC-50PX24
Did you try holding the power button down for about 30 seconds and release it? There are a lot of videos on plasma sets like yours that have this issue. I would wager the power supply before the main board.
Apr 30, 2018 | Panasonic Televison & Video
Tv/vcr shuts down after 5 secs.
There is likely an issue in either the primary or the secondary power supply that is causing the TV to shut down. Unless you or someone you know is good at repairing switching power supplies, there's not much you can do to save this unit.
Oct 07, 2016 | Symphonic SC-3813 13-Inch TV/VCR Combo
Last night watching tv, picture cut off (black screen) but power light on set stay on. then after bout 30 seconds the power button went off. Turn set back on , powere light lit but no picture and again...
Power supply board is dying not giving the tv correct voltage anymore.The power supply board,that the board power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 10, 2010 | Sanyo DP50747 50 in. Plasma TV
Powers on for a couple of seconds while the green power light flashes 3 or 4 times. Just long enough to see "DIGITAL TELIVISION" at the bottom right of the screen very clearly. Then shuts off.
if this is an LCD TV then its either a power supply or an inverter for the backlights that has gone down.
Bad capacitors on the power supply board is a very common problem with pretty much all makes of LCD TV's
Sep 01, 2010 | Symphonic Televison & Video
Plasma LG 42PC1D just clicks when you power it on and will sometimes turn on after 30 -40 attemps
This sounds like you have a known issue with the power supply board. The power supply is seeing a problem (typically with the 5vdc) and will shut down the TV just after you try to turn it on.
If you keep trying to turn on the TV, eventually you will catch the 5vdc circuit working and the TV will work until you turn it off.
Soon, the power supply will fail to where the TV will not come back on.
The power supply is around $160 and up. I can find your part number if you give me the rest of the numbers after the model number (example "A.SUSLLJR").
Or, you can have someone in your area fix you TV.
Good luck. I hope my information has helped you.
Jul 10, 2010 | LG Televison & Video
I turn my symphonic flat screen television on and it immediatly shuts off after about 30 seconds or less
This is a classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an a Symphonic, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have original parts on hand.
Jun 19, 2010 | Televison & Video
We just bought a used Symphonic 13" TV/VCR. turns on for 3 seconds and shuts off! Help. There's a tape stuck in it also. Help! Thanks, Jay
http://www.pechorin.com/m/2006/12/19/Service_Manual-280043.html
This is a classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an Akai, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. In any event, this is most likely, a fairly inexpensive repair, but as related ask for a "Quote" before proceeding with any repair.
May 08, 2010 | Symphonic SC313D 13 in. TV/VCR Combo
16 in symphonic lcd tv wont stay on. Itcomes on for about 30 seconds then shuts off. But it will come back on by itself and do the same thing.
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jun 27, 2009 | RCA F27450 27" TV
When you turn 'on' the tv...the tv continuously 'clicks'
The clicking noise is caused by the relays on the power supply board trying to power up the system. Your TV has detected a problem that's causing the power supply to shutdown. Someone knowledgeable in electronics can track down the problem. The SOURCE of the problem could be another board other the power supply.
Mar 15, 2009 | Samsung 46 in. Flat-Panel LCD HDTV
I have symphonic tv model sc3918 it will turns off after 5 or 10 second being on
This can be a power supply problem, if you have knowledge on electronics try to check the power supply, but if not better ask for someone who knows electronics to check the power supply.
Good luck.........
Aug 24, 2008 | Televison & Video
Televison & Video Logo
411 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
