Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite he4t
The unit stops midway through cycle and give a code of f6. do you know what f6 is
  • 1 more comment
  • macaque Dec 22, 2007
    f06 comes up before it can finish spinning
  • redirene Nov 20, 2008
    i had this problem and it turned out that the spin would not go. our washer is only 15 months old and just out of warranty, go figure! i had sears come out after three failed shows one finally made it! i threw him a parade! anyways there is a box in the bottom of the washer it is white and it cost $215, our washer also liked to flash the F11 and the controls wouldnt work only one would even light up so the control board was another $251. our service man went back and forth with sears explaining it was impossible for us to damage and the washer is not old and they should pay for the parts! which sears ended up doing! this washer looks like it is known for it problems and that is stressful as we are a large family and very dependant on the washer working! i hope this helps. my husband was effortlessly able to change the white box and the control unit, basically it was a process of unplugging and then repugging into the new units! Good luck and get the extended warranty!
  • Anonymous Mar 18, 2014
    First F5, cleaned filter on the right lower corner.
    Then F6 occured in the display.
    Genius:
  • 1,003 Answers
CHECK DRAIN HOSE coming from washer TO ENSURE WATER IS DRAINING PROPERLY down drain.
USUALLY YOU CAN RAISE DRAIN HOSE A LITTE AND RESET WASHER TO RINSE & SPIN F6 is caused by water not draining Fast Enough
Posted on Jan 24, 2008
I had the same code F6 and what I found was that the pump screen had a rag in it. The screen is located behind the front panel next to the pump.
Posted on Mar 16, 2008
My kenmore elite smartwash/he4t
The "F11" fault code will display if the Motor Control Unit (MCU) has an internal failure; repeating under or over voltage, or over current conditions. If failure occurs during high speed spin the door unlocks after 3 minutes. The MCU (Motor Control Unit) is located beside the motor. Here is the part to order.
Dec 02, 2012 | Kenmore Elite 45986 Front Load Washer
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore HE4T won't stop on the Spin Cycle. Stays
Replaced the relays with the 16Amp rated ones from Digitel.
Aug 15, 2009 | Kenmore Elite 45986 Front Load Washer
Washer stops with F11 code; door won't open
F-11 ERROR CODE MEANS :
Serial Communication Error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
TO RESOLVE THE PROBLEM:
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
May 05, 2009 | Washing Machines
Kenmore HE4t Won't continue drain cycle Code F6 & beeping
Take off the bottom panel (unplug unit first!) and unscrew the cap on the drain cylinder, be sure to have plenty of towels to soak up the water! pull out the center piece and check out all the treasures stored inside. Be sure to use a flashlight and lift up the black hose behind it to get any leftovers in the hose. I just did it today and could not believe how much stuff was in there...coins. pens, buttons, lost of wet lint had it clogged. The clothes finally don't smell!
Feb 03, 2009 | Kenmore 46462 Front Load Washer
HE4t Washer
"F06" is a Motor Speed error. The following link explains how to troubleshoot and some common causes:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
The first step to troublehsooting should be to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that it takes to correct momentary glitches with the unit. If the error code reappears following a computer reset, follow the advice given in the link I provided.
If you have questions, or require additional assistanc, please let me know. I hope this helps you.
Jan 23, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t washer won't spin
The motor controller board is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
F6 Code
f6 communication error in ht emotor controll board, located in the lower left front of machine
Nov 07, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3t
The machine control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check Wire harness connections between the Drive Motor/Tachometer and the Motor Controller, and between the Motor Controller and the Machine Control
• The Drive Motor has failed
• The Motor Controller has failed
Jun 14, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
1,906 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
